2016 Prius Braking power low warning
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Asifpop, Oct 25, 2023.
  1. bisco
    51,843
    Did you ever have the 12v tested?
    amos likes this.
  2. amos
    amos Active Member
    366
    282
    los angeles
    I test d the 12v was 12.2 v
    Regardless I changed the battery 2 days ago. It's a new 12v battery now.
    All eror and displays disappear after I'm turning the car on/ off several times. It is ok now.
    I will try to replace the pump motor relay (c1253).
    #22 amos, Mar 22, 2025
  3. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    This post by Patrick might be worth a read . He has a njinja rep in this forum, even if he hasn't been around much lately.
    abs main fuse | PriusChat
    amos likes this.
  4. vvillovv
    4,321
    1,509
    NY
    The post above was only a hint. Hinting that it could be in your best interest to get a 2 day sub to the repair manual, or try to get blink codes from the brake ECU.
    amos likes this.
  5. amos
    amos Active Member
    366
    282
    los angeles
    My problem here is intermittent. Right now I don't have any dtc .
    The fusible link is just an array of fuses. Not a relay.i might be wrong .
    They sell it at the dealership for 30$.
    I don't have any blown fuses now. And car functions 100%. But I do have a feeling this problem will come back because I only changed the battery which yet tested good (12.2v) but was 6 yrs old . when this abs failure happens it sudden and it takes 1 minutes for the car to be ok again after turning on/off several times . Yet very dangerous for me. I don't think problem is gone.
  6. amos
    amos Active Member
    366
    282
    los angeles
    an uopdate
    been now 300 miles and 8 days since i changed the 12v battery. car drives fine and all dtc codes disapear, is it time to be a little optimstic?
  7. bisco
    51,843
    i am!
    amos likes this.
  8. Iron Man Prius
    Iron Man Prius Junior Member
    98
    25
    Fullerton
    Three Touring
    Any update?
  9. amos
    amos Active Member
    366
    282
    los angeles
    Yes.
    I have changed the 12v battery.
    After that, it happened twice again In the same ride.when on May , 2 months ago, I was in Sequoya park on the way down from about 10,000 ft. It was a stretch of about 10 miles downhill. Lots of slalum braking.
    After that and about 4000 miles more of normal driving, it didn't happen anymore.
    I think this long downhill was too much.
    It took me over an hour to do that stretch. Had to drive it down at a speed of 5 mph.
    last week I checked those codes with the O'Reilly's scanner. All dtc codes are still there. Car is fine.
    Thanks @bisco and all others
    #29 amos, Jul 12, 2025
  10. ChapmanF
    18,076
    MID messages like "braking power low" are talking about the power to assist your braking (that is, the fluid pressure stored up in the accumulator). Codes that are about the pump motor having to run too long, or pump motor relay problems, or fluid leakage, or sticking accumulator pressure sensor readings, all could fill in some details of that picture. When the power to assist you is low, that means the brake pedal is going to feel hard/stiff and you will have to step on it very hard to slow the car.
    The repair manual will have troubleshooting procedures for whatever specific codes you have. I can't think of any real easy shortcut to just working through those.
    Toyota Service Information and Where To Find It | PriusChat
    amos likes this.
  11. amos
    amos Active Member
    366
    282
    los angeles
    Makes sense.
    Also. Last month I decided to change the front pads and bleed the lines cause I already bought it
    To my surprise the pads (originals and 9 yrs old ) had about 70% on them.thats on a car with 250k miles. I did the bleeding too.
    All that was after I changed the 12v.
    Iron Man Prius likes this.
