Newbie Maintenance Help/Advice - 2015 Prius V Wagon
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Germling, Jul 10, 2025.
  1. Germling
    Germling New Member
    2015 Prius v wagon
    Hi all!
    I am new to maintaining my car but simply can't afford to not do it myself. I was advised that I could likely handle the cabin air filter, oil change, and spark plug change.
    My car has 126k miles. It is a 2015 Prius V Three (according to calling Toyota, but Autozone VIN lookup listed it as a prius five? another mystery lol).
    I found the following videos:
    and plan to follow them to install the spark plugs.
    My questions are:
    1. Does anyone have any advice on doing this? I haven't worked on cars much at all and really want to learn, but am terrified to make a mistake costing thousands when I can't afford the regular maintenance. Are there any better resources to look at?
    2. According to the online manual for the 2015 Prius V on Toyota's website, it gives DENSO SC20HR11 as the spark plugs. Does it matter where I purchase them? Is there a newer model to upgrade to, and does that matter?
    3. Another (more general) video I saw mentioned that the wires should often be changed with the spark plugs. Is this the case here? If "it depends", how do I find out?
    4. Do I need a jack for doing oil changes?
    Thanks so much in advance. Also welcoming any suggestions for learning more about my car or how to work on it - I don't have much time or any tools (but am borrowing some from a friend!).
    52,337
    get the plugs from a dealer, an online one is okay for best price. there are too many chinese counterfeits running around the supply chain.
    you don't need to change the wires if they look okay. and they should on a 2015.
    it might be smart to use a torque wrench if you're not familiar with tightening plugs.
    how many years/miles have you owned her?
    Tim Jones likes this.
  3. rjparker
    10,438
    6,545
    The hardest part of changing the plugs is gaining access to them. To do so the windshield wipers, motor and steel mounting assembly has to be removed.
    I like the detail in this video
    Mervs egr and Wiper Cowl Video
    Disregard the intake and egr part which is more complicated and not needed to change the plugs.
    #3 rjparker, Jul 10, 2025
    Tim Jones and Brian1954 like this.
  4. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    If your car has LED lower headlamps and headlamp washers (among other features) it is a Five. Many early Five cars show up as Threes, though I haven’t seen that on a 2013+ model year.
    Tim Jones and bisco like this.
  5. Mendel Leisk
    41,850
    Video #13 linked here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    is very helpful. One thing though, he applies anti-seize liberally to the new spark plugs, and mentions torquing them to 20 ft/lbs. repair manual says 15, and makes no mention of lube, I’d stick with that.
    the BIG hurdle with gen 3 Prius (and Prius v) is the engineering oversight, that the coils atop the spark plugs cannot be removed, without first removing the wipers, windshield bottom trim, wiper linkage/motor, and the underlying metal cowl.
    A 3/8” drive torque wrench is appropriate for 15 ft/lb.
    you’ll need a 6” extension to reach down the spark plug tube, and the spark plug socket size is 14 mm (9/16” also works).
    A typical “spark plug socket” has a rubber insert designed to grip the plug. If they’re excessively grippy you can end up leaving the socket on the plug, pulling off the extension. Accordingly, it’s good to tape the extension/socket junction.
    Toyota has revised the original spec’d Denso SC20HR11 to SC16HR11, a slightly “hotter” plug. There are lots of reports of counterfeit plugs; I would buy either the Toyota branded ones from dealership parts department (they’re the Denso, just repackaged), or get the Denso, from a reputable local automotive specialty store. Avoid Amazon and eBay.
    one caution, since it happens so frequently: there’s a torque spec in repair manual for the small hold-down bolts for the coils (black gizmos that push onto the spar plugs). The torque spec is in INCH pound, which are twelvefold less than foot pounds. There are several reports here, novice DIY’rs miss that, snap the heads off. Bottom line: use common sense when installing fasteners. In this application, I wouldn’t use a torque wrench for anything other than the spark plugs, just snug everything firmly.
    attached is some info from repair manual. Not all that helpful, and the myriad parts removal not mentioned, off somewhere else in the manual. The last page I needed to paste in, was also somewhere else in the manual, had the spark plug torque spec.
    #5 Mendel Leisk, Jul 11, 2025
  6. ChapmanF
    18,486
    The early gen 3 Prius liftback trims had Roman numerals: I, II, III, IV, V.
    Then the Prius v wagon (lowercase v) was introduced, and to try even harder to avoid confusion, the liftback trims were changed from I, II, III, IV, V to One, Two, Three, Four, Five.
    Looks like some Autozone data entry routine matched up the Prius v wagon with the Prius liftback V.
    Air_Boss and Tim Jones like this.
