Master Warning Light and More
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusII&C, Jul 11, 2025 at 12:17 AM.
  1. PriusII&C
    PriusII&C Active Member
    374
    130
    San Jose, California
    2012 Prius 144k miles. Car has been performing well and no major issues. However it suddenly displaces a few warning lights: check engine, brake, traction control, and the master warning yellow triangle light. Pictures attached. Don't know what is wrong. Hope to get your insight. Screenshot_20250710-205906_Gallery.jpg Screenshot_20250710-205919_Gallery.jpg
  2. Grit
    Grit Senior Member
    6,452
    4,186
    Wilkes Land
    Since reading check engine codes wasn’t an option, your local mechanic will be your best option.
  3. Brian1954
    Brian1954 Senior Member
    1,808
    714
    South Central PA, USA
    Did you ever think about using a scanner to reading the trouble codes that the car is trying to tell you about?
    Is this a 2012 Prius OR a 2012 Prius c?
    #3 Brian1954, Jul 11, 2025 at 8:55 AM
    Grit likes this.
  4. PriusII&C
    374
    130
    Not sure if we should drive the car, so purchased a scanner online and waiting for its arrival. Will update once getting the codes.
    It is the 2012 Prius.
  5. ChapmanF
    17,341
  6. Brian1954
    1,808
    714
    What make and model of scanner did you purchase?
  7. PriusII&C
    374
    130
    Just got the scanner Ancel AD310, error code P0A80. It looks like I may have a traction battery problem.
    How far / long can I drive the car with the error code on? What kind of consequence will it have?
    #7 PriusII&C, Jul 12, 2025 at 8:31 PM
