Memory Seat Issue
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by artieb, Jul 8, 2025.
  1. artieb
    artieb Junior Member
    74
    medford ma.
    2024 Prius
    Limited AWD-e
    The #2 setting will not stay in the same position I set it to
    I adjust the seat to the position I want hit SET it beeps but the next time I get in the car it reverts to same position almost but not to the back tilt position I previously set
    I’ve tried various scenarios for example
    In Park
    In gear
    Accessorie position
    Stopped
    Moving
    Any ideas?
    TIA
    Love the car 16000 miles
  2. Zeromus
    Zeromus Active Member
    553
    308
    Ottawa Canada
    2024 Prius Prime
    SE
    I know that in some cars seat positions are tied to the keyfob. So perhaps seat position 1 saves to one keyfob/user preference, and position 2 saves to the other in the prius? Couldn't say for sure, because I have manual seats in my 2024 prime SE.
  3. Mwing
    Mwing New Member
    BC Canada
    2025 Prius Plug-in
    XSE Premium
    i had to reset mine to make it work after picking it up brand new
    maybe try to reset yours first and see?
  4. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I'm sure you know but after that beep you need to press the '2' button to store the settings.
  5. artieb
    74
    medford ma.
    2024 Prius
    Limited AWD-e
    I did start out by using my key fob and seems a remember settings thanks
  6. AgentPTFC
    AgentPTFC Member
    58
    39
    PNW
    2025 Prius Plug-in
    XSE Premium
    Have you calibrated all the adjustments? I was having trouble with seat memory and then saw a post talking about doing the calibration of the various adjustments. Worked for me after doing that.
