Air conditioner
Discussion in 'Gen 5 Prius Main Forum' started by Tande, Jul 13, 2025.
  1. Tande
    Tande Active Member
    550
    337
    Mich.
    Air conditioner on (blowing cold air) with indicator light off.....What am I missing?
    daisy555 likes this.
  2. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    When in AUTO mode for a function, no indications are shown for that function. The 3 possible states for "A/C" are OFF (no light), ON (light), AUTO (no light).
    Press the A/C button until the light is off if you want it manually off.
    Press AUTO if you want it automatic. Light will be off.
    RandyPete likes this.
  3. Tande
    Tande Active Member
    550
    337
    Mich.
    Thank You......now, how do I get it to STAY in manual/mode?......when I go to the "Climate" screen & turn "Auto/AC" off (or manual).....it won't stay ......when I turn the car off & then start it again, it reverts right back to "Auto/AC" ......no permanent "Manual" mode??
  4. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
  5. Gokhan
    Gokhan Senior Member
    6,537
    2,609
    Paramount CA
    In my 1985 Toyota Corolla LE, there were two lighted A/C buttons—blue (A/C, normal) and green (econ). The tiny bulb in the blue one burned out at one point, but I eventually got to replace it. I never figured out the difference between the normal A/C and econ though. LOL
    The following is not my car (RIP) but similar. @Mendel Leisk would love these A/C controls:
  6. Tande
    Tande Active Member
    550
    337
    Mich.
    Hammersmith said:
    I tried to explain this a few months ago, but I think I did a crappy job. Hopefully I'll do better this time.
    Short version: Don't worry about it; it's working like it's supposed to.
    Long version:
    On previous gens, the Auto button was not able to completely control the A/C. The user had to turn it on or off depending on conditions. In the gen5, the climate controls have been taken up a level to give Auto complete control over A/C. Since Auto is now in charge of the A/C system, the panel isn't going to show you when it's turning on or off by the green A/C light. The system will turn on and off automatically whenever it's needed to cool the cabin or dehumidify the air.
    However, there is a way to go back to the old system if you really want it. Within the climate options in the big infotainment screen, you'll find a setting marked something like: 'A/C on Auto'. This setting is enabled by default, giving control of the A/C to Auto. If you want to manually control it like previous models, just disable the option. Once done, the green A/C light will show whether the A/C system is turned on or off at any given time......I find this only works when I shut down the car with the AC turned off, (indicator light off) the car will then restart in manual mode; AC off, (indicator light off).......however if I shut down the car with the AC on, (indicator light on) the car will then restart in the "Auto/AC" mode (AC running, but indicator light off)......again, no permanent manual mode......
    If you leave the system in the default 'A/C to Auto' and want to manually override A/C control every once in awhile to force the climate system to leave the A/C off, you can do so by double pressing the A/C button. Pressing the button once(while Auto is also engaged) will force the A/C system on(green light on), while pressing it a second time will force the A/C system off(green light back off). After this, the A/C will remain off until the Auto button is pressed, which will give it control
    Thanks for clearing that up it’s definitely different than previous systems and not surprised by Toyotas logic…but different than before
    Hopefully that all made sense.
  7. Mendel Leisk
    41,901
    I do. Tactile, ergonomic, full adjustable without having to look down…, but the world has moved on.
    how about this: my parents 58 VW Bug’s high beam toggle was a button, down by your left foot.
    Julio_E and Gokhan like this.
  8. ChapmanF
    18,546
    I think my mom's 1972 Dodge Colt (a rebadged Mitsubishi Galant-like thing) is the first car I remember us having where the high beams didn't work like that.
    Mendel Leisk and Gokhan like this.
  9. Gokhan
    6,537
    2,609
    Paramount CA
    I also just noticed that the 1985 Corolla GT-S AE86 Limited fuel-injected DOHC coupe I pictured has two cigarette lighters. Now, that’s pure luxury! It also had cruise control and premium radio/Dolby cassette player with PLL-frequency-synthesized AM/FM. Curiously, it also had AM stereo, which is something I was unaware of its existence until today! Mine was an AE83 carbureted SOHC sedan without all that fancy stuff, with analog-tuned radio and no cassette player.
    This was the car. It currently costs more than a Gen 5 Prius PHEV:
    A 1985 Toyota Corolla GT-S sold for $40,000 on Bring a Trailer
  10. SXP
    SXP Junior Member
    31
    Huntington Beach, Ca
    2025 Prius
    The "Dip Switch" in the "English" speaking side of the globe!
  11. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    I laughed when I saw this post because I was dealing with this a while back. The AC light not being on when the AC is on seems so bizarre. Whatever you do don’t turn on the seat heater or you’ll really get confused. I turned the passenger seat heater on because I had spilled some water. It was on a towel so it only dampened the seat slightly but I wanted to be sure it dried thoroughly. After heating the seat for a few minutes I could not get the AC to come back on despite the screen stating it was on. I had to shut everything off and start over. Nothing intuitive about any of this.
    I miss the vents in my 2009. These new vents only blow air up, straight out or slightly left or right. No adjustment that allows the air to flow downwards unless mine are stuck. On very hot days my eyes are not happy.
    Tande likes this.
  12. Tande
    Tande Active Member
    550
    337
    Mich.
    Well...all these yr's (88), I have thought function indicator lights were to indicate, light on = function active .....light off = function inactive .....Silly Me!
  13. GeoJ
    GeoJ Active Member
    217
    198
    United States
    2023 Prius Prime
    XSE
    I am still a little confused. When you get in the car and it is hot, say 80 degrees, and you set the Auto at 70 will the car cool any better/faster if you turn on the AC with the light on? And, related, if you set the auto at 66 does it cool faster than if set at 70?
  14. Hammersmith
    Hammersmith Senior Member
    2,324
    2,372
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    For the first part, no. Makes no difference whatsoever. (Unless you've selected A/C to AUTO = OFF from the infotainment screen - but if you did that, you probably wouldn't be asking this question.)
    For the second part, I think it would depend on the interior temp. I think it's safe to assume that the system responds differently to different temperature variances. So if the cabin temp is 40 degrees higher than the desired temp, it's probably going to run the fan and A/C compressor differently than if it's only 5 degrees above the desired temp. And it's also safe to assume there are more than just two categories. Probably something like 4-8.
    So if the interior temp is 80 and the set temp is 70, that's a 10 degree differential. If the set temp is 66, that's a 14 degree differential. If one of the cutoffs happens to be between those two differentials, then the A/C would work a little harder at first in the car set to 66. But it probably wouldn't be different for long. It wouldn't take the car long to shift the temp the couple degrees needed to switch into the same temp category again.
    But if you wanted to force the issue as quickly as possible, just make sure the car isn't in ECO mode(so Normal or Sport) and set the climate control to Lo. That will tell the car to set everything to max cooling.
    GeoJ and otatrant like this.
  15. GeoJ
    GeoJ Active Member
    217
    198
    United States
    2023 Prius Prime
    XSE
    It was well into the 90s when I got into my car yesterday and I tested this out. Not sure why, but it was definitely the case that with the Auto on the air being pushed out was much colder when I pushed the AC button and lit it up. Not a scientific test but it was a big enough difference to know. What you said about setting climate control to Lo did make it max cool, but only with the AC button pushed.
  16. Trollbait
    12,681
    Did you happen to note what the recirculation light was doing at those times?
  17. GeoJ
    GeoJ Active Member
    217
    198
    United States
    2023 Prius Prime
    XSE
    I had the recirculating to cabin air, so it was not taking in outside air.
    Trollbait likes this.
  18. daisy555
    1,727
    715
    CT
    This is where I’m still confused. If I have the AC on auto, isn’t it automatically recirculating the air rather than pulling air from outside? If not, how do I shut off the air coming from outside? Example being when I’m stuck driving behind someone with horrible exhaust fumes.
  19. GeoJ
    GeoJ Active Member
    217
    198
    United States
    2023 Prius Prime
    XSE
    There is a button to push so you are not pulling outside air. If you don't push the recirc button, I don't believe it automatically is recirculating the air.
  20. ChapmanF
    18,546
    The flow of air through the cabin and out through the battery ductwork is what cools the battery. So the recirc setting is usually reserved for a few special moments, like when you're behind that smelly truck, or when you just started the car and want to get the cabin temperature down as fast as possible.
    By the same token, you don't have to actively worry about starving the battery airflow, because the car will just veto your recirc selection any time the battery needs more cooling.
    Tande and daisy555 like this.
