2022 Prius Prime Part help
Discussion in 'Prime Main Forum (2017-2022)' started by sallynina15, Jul 12, 2025 at 8:32 PM.
  1. sallynina15
    sallynina15 New Member
    Saturday
    San Francisco, CA
    2022 Prius Prime
    Hi all!
    I am a newbie here and am looking for some guidance.
    Recently, a bicyclist hit my car and cracked the circled light portion. I took it to a repair shop and was quoted $406.07 for the part (Part #81531-47010) and roughly $500 for labor but I am unsure if this is the correct part. I don't completely trust the repairman and have been thinking about replacing the part myself.
    That being said, does anyone know exactly what part I should be looking for and if anyone has any guidance/tips/videos on how to replace this, I would very very very much appreciate it!
    Thank you everyone!
    51,155
    a dealer parts dept. can help you with that
  3. Gokhan
    Gokhan Senior Member
    5,748
    2,273
    Paramount CA
    I did this repair myself. It is not that easy. Make sure you put the bumper on a cloth so that it doesn’t scratch.
    Victim of a hit and run—again | PriusChat
    BiomedO1 likes this.
  4. Mendel Leisk
    40,587
    I see from a Canadian parts site, it’s over $700 (CDN). It’s a turn signal, and brake light? Somebody’s gotta bell this cat…
  5. BiomedO1
    2,821
    1,500
    SacTown, Ca
    It's the reverse lamp assembly and that looks like the correct part number.
    Here's the online OEM parts store I found in on $283.19: https://www.toyotapartsdeal.com/oem/toyota~lens~body~rr~turn~81531-47010.htm
    It isn't a very difficult job to replace, just very cumbersome. Lots of plastic clips to pop-off and a few wiring connectors. @Gokhan stated; you need to lay down a couple of large beach towels or rug runner, so you don't mar the painted surfaces of that bumper cover - when your remove it and lay it down.
    Good Luck....
    #5 BiomedO1, Jul 14, 2025 at 9:41 AM
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,143
    749
    Monument, Colorado USA
  7. Mendel Leisk
    40,587
    They seem to concentrate on older years.
    Or a lawn. Too, never drag it.
  8. Gokhan
    5,748
    2,273
    Paramount CA
    And here is the repair manual. The hardest parts are removing the bumper from the clips (I broke one of them) and putting the bumper back (I was successful but some people couldn’t manage it, resulting in poorly aligned parts).
    If you touch the parking sensors, it will cost you $2,000 to have them recalibrated.
    Don’t put the bumpers on a surface without a cloth, as they easily scratch.
    2017–2022 Prius Prime rear bumper—official Toyota repair manual
  9. Gokhan
    5,748
    2,273
    Paramount CA
    #9 Gokhan, Jul 14, 2025 at 3:03 PM
