Toyota Digital Rear View Mirror 87840-0W360 (no homelink)
Discussion in 'Gen 5 Prius Accessories and Modifications' started by otatrant, Jun 18, 2025.
  1. Hammersmith
    Hammersmith Senior Member
    2,137
    2,128
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Ok, my bad. I thought the nozzles were physically part of the camera assembly and not orderable separately. Also, someone long ago(don't remember if it was an early reviewer or a PriusChat poster) said there was only one washer. But, in my defense, I went out a little while ago and looked at my car, and the washer nozzle for the rear view camera is basically impossible to see when it's all installed. I guess I'm going to have to have someone sit in the car and hit the washer while I'm watching the washer(s).
    But now I'm wondering about things. Does that mean there are some cars with zero washers, some with one washer, and some with two?
    otatrant likes this.
  2. otatrant
    otatrant Active Member
    229
    151
    San Francisco
    2023 Prius Prime
    XSE Premium
    Sounds like this may be true. You have the Limited Prius with panoramic view monitor but without a digital rearview mirror but with a washer for the one camera in the rear. Than most likely you have 86790-47180? So maybe they add the washer for the camera if you have the panoramic view monitor.
  3. Hammersmith
    2,137
    2,128
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, I've got everything. You can't get PVM without also getting the digital rear view mirror.
