Wrapping stock intake with tinfoil bubble and then heat resistant wrap?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Jul 11, 2025.
  1. Brian1954
    Brian1954 Senior Member
    1,867
    736
    South Central PA, USA
    The thermostat controls the temperature of the coolant. That is why I suggested that you remove the thermostat in the summer if you wanted your engine to run cooler.
  2. h1ph0panonymous
    246
    33
    Idk if you’re trying to fool me into killing the engine but please stop advising that. Once again I don’t need to mess with the thermostat because the thermostat isn’t what heat soaks the coolant...and you have nothing to say about the actual response I gave you instead you go to one I have to another person.
  3. Brian1954
    1,867
    736
    193F to 195F engine coolant temperature is standard for the Prius engine. The Toyota engineers designed the engine cooling system that way. Take your car on the highway and drive at 60 to 70 mph. The engine coolant temperature will be in the 195F to 197F temperature range if you are traveling on a level road. You do not need to be concerned with the coolant temperature until it gets higher than 205F.
  4. h1ph0panonymous
    246
    33
    With my cabin exhaust method I can get 188 degrees at 67 miles per hour on a 65 mile per hour speed limit highway. Yes it’ll reach 193 on slightly up hill highways when accelerating to stay up to speed limits during those stretches of up hilly-ness highways, 191 degrees if I go over 70 and cruise at that speed. It’s worse during the case of stop light to stop light driving, well because there’s less air you’re speeding through and catching but still to be getting 195 after acceleration from a stop light not even over 2200 RPM is just ridiculous and unnecessary temperatures but again that could be due to my regen braking missing for the past weeks making the engine work harder. We will see once I put a new connector in and get my DTC codes to clear for that issue and retrain the HV battery to maintain a regen braking healthier status rather than an engine that has to maintain the HV batteries health. Still going to wrap stuff under the hood, hopefully without adhesive installment and more so with clamps, might even get thicker and cooler tubing to replace stock hoses for everywhere the coolant travels.
  5. Hayslayer
    Hayslayer Member
    247
    127
    Maybe because it's the device which regulates coolant temperature?
    yeah, you need to just close the hood and let the car do its own thing. You're proving it in almost every post.
    #165 Hayslayer, Jul 16, 2025
    Brian1954 likes this.
  6. Brian1954
    1,867
    736
    195F is NOT a ridiculous coolant temperature. It is the standard temperature that the Toyota engineers designed the cooling system for.
    Trying to reduce the engine coolant temperature by wrapping anything in the engine bay or switching to thicker hoses will NOT work. But if you do not believe me, try it and try to prove me wrong.
  7. Brian1954
    1,867
    736
    The OP still does not understand how the thermostat regulates the engine coolant temperature even though I included the answer in post # 145.
  8. h1ph0panonymous
    246
    33
    Their design is a fail due to it all having a causation is head gasket failure, keeping temps lower than designed will prolong the inevitable outcomes of their “design”.
  9. ChapmanF
    17,483
    Yeah, just for reference, 195℉ is squarely between the thermostat-begins-to-open temperature and the thermostat-fully-lifted temperature.
  10. h1ph0panonymous
    246
    33
    Don’t care about the thermostat, it not the source of heat.
  11. Brian1954
    1,867
    736
    You can believe anything you want. It is time for action rather than discussion.
  12. Brian1954
    1,867
    736
    I guess you can lead a horse to water, but you can not make it drink.
  13. h1ph0panonymous
    246
    33
    Anyways, anyone have a resource and material link to that guys aero and intake mods shown in this thread?
    Just showed it to my mechanic friend who has a modified Prius and he’s really interested in doing it to both our cars.
  14. frodoz737
    frodoz737 Top Wrench
    4,576
    2,455
    33
    You need to concentrate your monies and efforts first on repairing your car...instead of discussing what-ifs and work-arounds in here.
    Reference post 159.
    #174 frodoz737, Jul 16, 2025
  15. h1ph0panonymous
    246
    33
    I just need a new connector for the ABS sensor in the rear left, not really a repair. About to order one on rock auto but I do need to replace the lower slide pins and bushing in the caliper bracket in both rears. Completely seized up. Ordering that with the connector as well.
  16. Hayslayer
    Hayslayer Member
    247
    127
    Can you tell us what the source is that heat soaks the coolant? Is it the hot air in the engine compartment?
  17. h1ph0panonymous
    246
    33
    Dissipating heat from the engine is the source of engine bay heat.
  18. ASRDogman
    ASRDogman Senior Member
    7,288
    3,805
    Oh wow! People are still soaking on this? Soak up the hox and get a life! :eek::rolleyes::rolleyes:o_Oo_O(y):whistle:
  19. frodoz737
    4,576
    2,455
    33
    He's been called out.
  20. h1ph0panonymous
    246
    33
    Called out for what?
