Is this a bad idea? (Used OEM speed sensor)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LazuliNyx, Jul 16, 2025.
  1. LazuliNyx
    LazuliNyx Junior Member
    56
    34
    Georgia, USA
    My ABS light came on, and after scanning I found out it's a C0205, the front left wheel speed sensor circuit failed. I looked at turns out one of the mounting clips for the speed sensor's cable broke and it contacted the tire, leading to a short. I patched it up with some wire for now, so I at least have ABS and regenerative braking back. A new speed sensor is $225 from the dealer, $150 after shipping on Amayama. Would it make sense just to get a used OEM one for $50? I'm guessing it's not a part likely to fail unless something happens mechanically? If this isn't a bad idea, where would you recommend getting this from? Thanks!.
  2. Tombukt2
    12,683
    2,264
    You should be getting used ones for like free
  3. rjparker
    9,884
    6,092
    If you do a watertight repair you could use what you have otherwise a used oem assembly (89543-47030) would be my choice.
    Brian1954 likes this.
