Reviewing & Preparing for ABS Replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by Tyler Pryjda, Jun 18, 2025.
  1. Tyler Pryjda
    Tyler Pryjda New Member
    Ohio
    I’ve been researching and studying as much as I can before getting my hands dirty replacing the ABS Actuator Assembly on my 2006 Prius.
    I purchased a used, revised module, part number 44510-47051. I ordered an Autel MaxiAP200 preemptively and am currently going over the bleed procedure; I seem to have a few options which I’ll outline below:
    Option 1: Autel
    Initially, it seemed as if I could use the scanner I purchased to complete the bleed routine; actuator reinstalled, door open, pump helps push out air, then use auto bleed function, then manual bleed - should be good.
    With more research, I’m concerned that this will mechanically fix the brakes, but result in these codes: “C1345 and C1368“
    These codes seem to appear when the Linear Valve Offset is not performed; This can be done via Techstream, or some aftermarket scanners can do the same.
    Option 2: Steam Deck Techstream
    Due to the aforementioned concerns, I have considered installing WinDeckOS (Custom windows 11 image) onto the deck, dual booting into it, and running a obdii365 blog Techstream launcher on it, then using a mini VCI cable, running the software.
    with this approach, I am concerned with compatibility. I have seen 2 videos doing this already, as in, they show a Steam deck diagnosing with Techstream. Why a steam deck? It’s all I have. With compatibility issues in mind, it may be more worthwhile to avoid mini vci costs and headaches, and to just opt for option 3;
    Option 3: ThinkDiag 2
    I have read in some threads that this scanner can perform the LVO needed. I have questions though; does the original Bluetooth model work? Can this reset the valve values so that the LVO works?
    it appears that using option 3 may yield the most trustworthy results. Does anyone have experience or feedback? Guidance would be much appreciated
    additional concerns:
    Tech manuals specify torque for brake line connectors; videos and guides do not; how important is this torque, both for mounting the actuator and then the brake lines as mentioned - I found torque specs on a Toyota repair manual I downloaded.
    is there a way to check mileage or condition of the revised part?
    does anyone want an autel?
  2. Brian1954
    Brian1954 Senior Member
    2,416
    970
    South Central PA, USA
    The Autel AP200 should be able to do the full brake bleeding process and the Linear Valve Offset.
  3. Tyler Pryjda
    Ohio
    Just following up; a new actuator was required for this repair, revised part number from Olathe Toyota. The autel can bleed the brakes just fine, but my mechanic used a different scanner.
    Good luck to anyone else with actuator problems!
    Brian1954 likes this.
