tire size question -- 195 vs 185
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by [email protected], Nov 24, 2009.
  1. bill@bfv.com
    [email protected] Junior Member
    massachusetts
    A friend is upgrading cars and wants to give us (4) snows -- 195/65 R-15 ... Our current Prius tires are 185/65 R-15 ... Can I use these slightly larger snows -- either 2 of them or all 4?
    We have 4 extra aluminum rims, so I could have them all mounted ... or just use a couple on the front.
    But it's the 195 vs. 185 question that I'm really looking to answer.
    Thanks in advance for your help.
    Bill
  2. qbee42
    3,079
    Some people run 195s on the Gen II Prius. That said, narrow snow tires are better than wide snow tires.
  3. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    Should be OK. Your spedo will read about 2.1% slower than you are actually going.
  4. craigk
    craigk Member
    139
    Golden Valley, MN
    the only change above is in tire width (195 v. 185), how does that affect speedometer reading?
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The Height of the tire is expressed as a percentage of the width, 65% in both these cases. (Other tires may have other percentages, also called profiles) 65% of 195 is just larger than 65% of 185.
    105/80R13 is as tall a tire profile I found.
    315/35R17 is as short a tire profile I found. (Neither fit a Prius)
  6. craigk
    craigk Member
    139
    Golden Valley, MN
    thank you for correcting, my mistake, i thought it was a percent of something else.
  7. rposton
    rposton Member
    139
    Nashville, TN
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Actually, his speedometer will most likely be more accurate than stock because stock reads about a couple of percent high.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yep, but the odometer will still be a bit off.
  10. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    For some odd reason only in the US Toyota supplies 185 with the Prius rest of the world gets 195. I recently replaced my tires and went with the 195/65 size and noticed the car handles much better.
  11. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes but please note that it's generally195/60/15 (not 195/65/15) that's the factory fitted standard outside of the US.
  12. Ryanpl
    780
    158
    Brooklyn, NY
    Thanks for the correction UART. My bad :doh:
  13. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    We got the 185s too, and we actually aren't part of the US.
  14. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I tried 195/65/r15's on my 206 and I found the car liked the standard 185/65/r15 better. Better FE and much better driving auto with standard size. My 2 cents! Hal
  15. MarvinHC
    MarvinHC Junior Member
    49
    Europe
    In Europe the standard size is actually 195 / 55 / 16
  16. ursle
    ursle Gas miser
    1,049
    192
    NH
    The 185 is 24.5" the 195 is 25", no big deal, more torque with the 185 better mileage with the 195
    Run all 4 the same size, either 185 or 195 don't switch them up, winter driving and braking will go smoother.
    In the tools menu on you screen you can adjust for larger or smaller tires to adjust your speedometer error.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    The MFD should read higher mpg with the 185s because they are smaller in rolling diameter than the 195s. This is assuming you are comparing the same model tires with the same wear condition.
  18. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    Bought my Prius in Jan 2008, used with 30k on it with the OEM 185's I drove it for the remainder of that winter (Buffalo NY) and thought about getting a four wheel drive before the next winter. I replaced the tires when they wore down with 195 60-R 15 Bridgestone Turanza LS-T tires from wal-mart in Sep 2008. I have now driven two more winters on them and haven't bought a four wheel drive for winter yet. I just replaced them today with four new tires same make from wal-mart for only $10 more than I paid two years and 80 some thousand miles ago. I'm not sure if it was the tread change or the tire size but I know these tires have done the Buffalo winters and the buffalo to Boston trip once a month for the last two winters with no issues on the highway. On side streets nothing moves in Buffalo without more ground clearance or four wheel drives.
    as far as mileage or speed changes I have noted a 1MPG drop over what I was getting with the 185's (I remember reading on this here so I kept track the first few months) I also noted a 2MPH change from what the "speed in Zone" signs say I'm going compared to the dash display.
    I don't know if any of this helps answer your question or not but it’s what I have noticed with my Gen II and my tires.
  19. PriuSocal
    PriuSocal Member
    289
    52
    SoCal
    Sorry to revive old thread but rather do than start a new one.
    I replaced the 185/65/15 on my Gen 2 with 195/65’s and I deff do NOT like the look or performance. The prius has decreased noticeably in MPG and performance. It is now giving me a consistent 42-43 mpg vs 48-49 mpg and tires look way too meaty for my liking. I will def be going back to 185’s at least for this prius because the 195’s being the stock tire size on Gen 3’s they def do not look good on Gen 2’s IMO and if there is any handling improvement, I cannot justify trading handling on a 90hp prius over MPG which is wha the car is made for, SAVING fuel not decreasing.
  20. Mendel Leisk
    41,824
    We’re North America though, and the US and Canadian Prius are very similar, with any variations due to different reg’s.
    yeah I now, old thread.
