Factory hybrid battery replacement 2025
Discussion in 'Gen 2 Prius Main Forum' started by Del D, Jul 16, 2025.
  1. Del D
    Del D New Member
    • Hello, I'm a new member. I have a 2007 base model. My Toyota dealer says my battery is done at 223k+. I prefer to replace it with a new factory unit. Most Toyota dealerships selling on the internet list the batteries at over $3,000. However, I found a few that sell a unit, part no. G9510-47033 for about 1,700 to 1,800. The local Toyota parts department says its Japanese domestic market product. Only problem is, it seems most dealerships don't want anything to do with G9510-47033. They list it as incompatible or not for sale. A few dealers have it available but most are in the coastal cities. I'm in Minnesota and would like to install it myself. I would like to hear any thoughts from the members. Thanks!
  2. Tombukt2
    13,116
    2,354
    JDM to USA new HV will cost 3K with shipping n fees I believe
  3. Hayslayer
    Hayslayer Active Member
    419
    245
    The 47033 is the most recent updated part number for the Gen 2 HV battery and replaces the 47031 model.
    It's great to see prices are coming back down. They had jumped to 3k+ the first day of 2025. Check this link. Believe it or not ....$1800 + core and it looks like they ship
    G9510-47033 Genuine Toyota BATTERY ASSY, HEV SU
    or this one, but don't know if they ship
    G9510-47033 - Battery - 2004-2009 Toyota Prius | OEM Genuine Toyota Parts
    #3 Hayslayer, Jul 17, 2025
  4. xw20_driver
    xw20_driver Junior Member
    92
    PNW
    I'm on the west coast with my 2007 Touring. The HV battery part number you have is correct so not sure what he is smoking. The battery part is indeed Japanese since it is not produced in the USA. You can review my post here https://www.priuschat.com/threads/2007-rtod-hybrid-battery-replacement.255503/ I purchased from my local dealer parts for about $2k.When you call your local dealer parts counter give them this part number and ask for a quote and if he can sell this part over the counter for retail. There is a mandatory $1350 core charge so be sure to ask about how they handle the core charge return.
    Ultimate_Combination and bisco like this.
  5. Del D
    Del D New Member
    Thanks for the reply. I'm in Minnesota. I wish I was in California. You have so many options and at least one would driving distance. But yeah, I think dealerships in the interior states are not trying very hard to get affordable options for their nearby customer base
    A place in Des Moines Iowa says they have one in stock for about $2,200. He sounded very happy that I was interested too
    Local wants more than $3,000.
    #5 Del D, Jul 17, 2025
  6. Del D
    Del D New Member
    Hey that's a good thread. I
    I guess there's a lot more dealerships within 3 hours distance. I could call them all and be aggressive, try and swing a deal if it's possible.
  7. Del D
    Del D New Member
    I'm thinking, find one for $1,800 or less. Be willing to drive up to eight hours, preferring the closest. Bring the core with me and take off whatever they permit when I get there.
    #7 Del D, Jul 17, 2025
  8. xw20_driver
    92
    PNW
    Only other suggestion I have is to see if you have any hybrid specialist shops that focus repair Prius and other Toyota hybrid vehicles. A shop near me was willing to order a genuine new HV battery from Toyota for $2300 cash and $2800 installed. Dealer shop that quoted me $2050 but would not sell to individuals, their service dept quoted me $1600 labor to install. Outrageous considering it would only take a pro tech 2 hours tops to remove and replace the battery.
  9. xw20_driver
    92
    PNW
    Personally, I would recommend making 2 trips so you can carefully transfer all the required parts from the old pack to the new pack but understandably that would be difficult if you have to drive several hours to pick up your new battery. The brand new factory hybrid battery pack will be in a plastic Toyota crate (coffin). In it you should fin the battery pack and a bag with the new orange cables. There should be 2 small bags with new nuts.
    The parts you need to retain from your current pack:
    - Right rear end cover plate.
    - Black rubber vent tubing.
    - Left rear entire section: terminals, relays, battery ECU. Check the ecu main orange connector for burnt/corroded pins.
    CAUTION: you are working around high voltage! Wear proper protective high voltage gloves. They have special gloves for this work.
    Review this video to get an idea what the process looks like:
    #9 xw20_driver, Jul 18, 2025
  10. douglasjre
    douglasjre Senior Member
    2,192
    729
    Null, NL
    Alibaba, $800
  11. Prodigyplace
    12,593
    11,791
    Central Virginia
    Wouldn't they need to use the core to drive there?
  12. Prodigyplace
    12,593
    11,791
    Central Virginia
    Since when does a chinese vendor sell genuine Toyota parts that are only manufactured in Japan??
    jonsey1886 likes this.
  13. Del D
    Del D New Member
    I have a second
    Thanks for all the info. Factory new is the best and you've have the real experience. I'll update. May be a while.
    #13 Del D, Jul 19, 2025
    Prodigyplace likes this.
  14. Prodigyplace
    12,593
    11,791
    Central Virginia
    Next best might be a junkyard battery from a low mileage Gen 4 Prius One or Two. I know my 2017 is sitting in a junkyard somewhere in Virginia.
    Del D likes this.
  15. jonsey1886
    jonsey1886 Junior Member
    Roanoke
    As a former Toyota certified technician who just did his personal Prius yesterday I’ll add a bit more details.
    For starters you’ll also need to retain the rubber protector that keeps you from getting your hands sliced to ribbons. Oops.
    The thing that kills me is I could always remember to do it for a customer vehicle but not my own…same thing with the vent tubing. Luckily I had an extra disassembled one next to my vehicle at work so I just grabbed parts from it.
    In the box taped in their own secured bag are new:
    • 1 Main Battery Cable (long one that runs from the far end of the battery to the SMRs)
    • 1 No 2 Main Battery Cable (short one that runs from the close end to the SMRs)
    • 1 Service Plug with its attendant wiring
    • 4 Replacement Nuts for attaching them to the battery (torque 48 in/lbs)
    • 2 Replacement Nuts for where the cables attach to the SMRs (torque 50 in/lbs)
    • 1 Battery Clamp Pad
    • 1 Number 3 battery carrier cushion
    #15 jonsey1886, Jan 10, 2026 at 1:36 PM
    Prodigyplace and bisco like this.
  16. Prodigyplace
    12,593
    11,791
    Central Virginia
    I see you are, I assume, in Roanoke VA. What dealer did you work for? I currently travel from the Lynchburg area to Manassas VA for my trusted sales and service.The local dealer sales and service have proven they cannot be trusted.
