What's on the back of engine, above oil pan? (Wet!)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Jul 19, 2025.
Tags:
  1. MrPete
    MrPete Active Member
    500
    190
    Colorado, USA
    @PriusCamper your wish came true, unfortunately. ;)
    I'm suddenly seeing a pool of wet on the garage floor after each of the last couple of drives. Not oily. No real smell.
    I need to find what this is and solve it. We leave on a 4000 mile driving trip in one week.
    My main questions:
    • what are the (wet) bolts/devices on the back-right side of the engine, above the oil pan, and below-right of exhaust???
    • Could the black bolt in photos be loose?! (I've not attempted to change anything.)
    Jacked up car. Looking at the back side of the engine I see some wet components, particularly a black bolt, and another wet one above it that's hard to see.
    In the photos, "down" is toward the front of the car. I am lying beneath the oil pan, whose attachment bolts are visible in the final photo.
    The black bolt "under" the metal plate (and clip for some wire) was quite wet. A lighter bolt above it was dirty/wet. Then in the first two photos you can see a black bolt or cap or ??? that's also glossy/wet.
    I'll search for appropriate engine diagrams...
    THANK YOU! What an amazing community :)
    20250719_104930.jpg 20250719_105011.jpg 20250719_105059.jpg 20250719_105111.jpg
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,737
    Bay Area
    It’s probably your timing chain tensioner gasket that is leaking from the top, it’s a common leak on that gasket. Mine was leaking too and I changed it when I did the head gasket.
    johnHRP likes this.
  3. MrPete
    500
    190
    Colorado, USA
    Hybrid Pitstop replaced my entire engine (with a Gold 2015 rebuilt from ground up) only 30k miles ago.
    Is that a likely gasket leak so quickly?
  4. ChapmanF
    18,115
    I saw that black-painted block, and wondered about that.
  5. NutzAboutBolts
    1,693
    1,737
    Bay Area
    looking at the first picture, it looks wet underneath the timing chain tensioner.
  6. NutzAboutBolts
    1,693
    1,737
    Bay Area
    Is that black looking bolt suppose to be where the oil pressure sensor is at? I’ve never seen that type of black bolt before.
  7. MrPete
    500
    190
    Colorado, USA
    Good question. And THANK YOU for digging in with me on this!
    Here's a new picture from the side w/ the right front wheel off.
    100% of the wettish area is around the two connectors and the black bolt (which is behind (left of) and a bit below the upper connector.. Above these, it's dry dry dry.
    I do not know if this helps w/ identification: I notice that the upper connector is at right angle to the back of the engine. The lower one is tipped by 10-20 degrees or something like that.
    I am also wondering... could this simply be condensation from the A/C unit? Doesn't really sound right to me... grasping at straws I admit!
  8. NutzAboutBolts
    1,693
    1,737
    Bay Area
    from the looks of it, I’m not sure what that black bolt is since you have the oil pressure sensor and the crank position sensor there. I’d definitely call the dealership to see if they can see what that part is because it’s not on my 3rd gen Prius engine.
    and the ac condensation line is below with a hose that goes down on the passenger side seat. It wouldn’t be on the engine like that black bolt.
  9. MrPete
    500
    190
    Colorado, USA
    Interesting. From the link below (sub-figures "C" and "D"), looks like those are "Plug, w/ Taper Head Screw" -- just a bolt that does nothing?! Perhaps they have some kind of manufacturing purpose. (NOTE: my engine is 2015 now... I looked it up. Those parts haven't changed.)
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-usa/prius/zvw30/13503/engine/1105?frame_no=JTDKN3DUXB1414344
  10. ChapmanF
    18,115
    Often, manufacturing a block requires making passageways in it, like oil galleries, that have to be bored through from the outside. Then the outside holes are closed with plugs.
  11. NutzAboutBolts
    1,693
    1,737
    Bay Area
    Yeah looks like just a bolt plug they plug up, not much you can do to it. Is it really leaking from there? Try cleaning it with brake clean and see if the leaks come back from that bolt hole or from the timing chain tensioner.
  12. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    You state the substance is not oily. It’s summertime so are you sure you’re just not seeing the ac condensate? I have a small pool under my car after driving in the summer but it’s just water. Take a paper towel and soak it up to see what it is. If it’s oil, coolant, brake or transmission fluid it’ll be pretty obvious.
  13. MrPete
    500
    190
    Colorado, USA
    That is what I am starting to think.
    My question about that: *where* does condensate drain? I thought it was in the front next to radiator/fans.
  14. PriusCamper
    PriusCamper Senior Member
    12,719
    5,143
    Pacific Northwest, USA
    Yep... Until you determine where your AC condensation drip is coming from and confirm your concerns are a problem beyond that all signs point to you trying to make up a reason to hang out under your car again. Stop it! There's better places to hang out!
  15. ChapmanF
    18,115
    A/C condensate drains from a tube that sticks down through the floor pan right about where the A/C unit is at the front of the floor pan. The drips would have to fly forward and up to get on the engine.
    MrPete likes this.
  16. MrPete
    500
    190
    Colorado, USA
    I think the engine wetness/shiny is separate from the pool of watery liquid on the concrete. Gonna treat it that way at least.
  17. MrPete
    500
    190
    Colorado, USA
    For now: treating everything as minor. Did a bit of tightening, cleaned MAF sensor etc, Going to beat up the car this week, and hopefully it'll be solid on this next trip.
    One thing learned and an improvement made:
    • For my new fancy head unit, I extended the CANbus from the OBD2 connector to the radio area...
    • Worked great, for a while. Then one of the connectors went wonky.
    • Cars do NOT like an intermittent CANbus wire!!! Got quite the error display on the dash, and a zillion DTC's ;)
    • Asked my ASE Mechanic friend how he connects extra wires. I followed his advice, which concluded with "Pete, I've never had ANY failures using this method. Ever.
    It cost a few pennies for a new crimp tool and some parts, but all is much more solid now. My new way to connect extra wires almost anywhere:
    • NON-insulated butt connectors (metal tubes. I got a set with AWG 24-8 sizes) -- makes it simple to test AFTER making the connection.
    • Appropriate crimp tool (I bought the iCrimp Ratcheting Crimping Tool Set, with replaceable jaws. Handles AWG 20-2)
    • Good heat shrink tubing (I got Eventronic 4:1 ratio heat shrink, which includes internal adhesive. Makes a waterproof, tough coating. Very happily using on lots of things now ;) )
    • (I already own a very nice heat gun, used for an incredible variety of things including 10 minute freezer defrosts LOL. Metabo HPT Variable temp gun+kit 100-1200F. $85 when I got it.)
  18. ChapmanF
    18,115
    A person might also stumble on the gen 3 having multiple CAN buses; a 2010 has the CAN No. 1 bus, CAN No. 2 bus (for ECUs involved in DRCC, PCS, and/or parking guidance), power management bus, and parking assist bus (if equipped with parking guidance). The repair manual shows what's what on each one. The Power Management Control ECU connects to three of them, so it can act as a gateway.
    You can see the factory uses these CAN junction connectors where the branches plug in to the main bus. They simplify troubleshooting, as you can unplug any branch individually from the bus to isolate problems.
    The junction connector numbers are confusing ... you can see from this picture that both "CAN No. 1 Junction Connector" and "CAN No. 2 Junction Connector" are parts of the CAN No. 1 bus. Then CAN No. 3 Junction Connector is on the CAN No. 2 bus, CAN No. 5 Junction Connector is on the power management bus, and CAN No. 5 Junction Connector is on the parking assist bus.
    I haven't confirmed this, but I think there might be unused positions on some of the CAN junction connectors, which might make for nice places to patch in new branches.
    MrPete likes this.
  19. MrPete
    500
    190
    Colorado, USA
    Interesting! AFAIK, I can talk to ECU's on all CAN busses from any one of them... are they truly separate busses?
    As for the confusion... I just solved the issue of my unknown connector, and realized that the confusion is almost certainly due to a strange anomaly of Korean/Japanese cultures. I'll discuss over there ;)
  20. ChapmanF
    18,115
    Talk using what? A full-coverage scan tool like Techstream or the Autel? Or with hand-rolled CAN queries of your own?
    The scan tools may embed a lot of knowledge about how to route messages through multihomed ECUs onto the bus they need to reach. (You should have seen the combination of networks thrown together in the pre-CAN gen 1 Prius! I think it included ECUs sharing a serial link at different bit rates ... Techstream must have known to reset the UART between talking to one and another.)
    Also, does your car have the options that go on those extra CAN busses?
    MrPete likes this.
