Are their advantages to a NimH battery vs a Lithium Battery?
Discussion in 'Gen 4 Prius Technical Discussion' started by 9Shenandoah, May 27, 2025.
  1. 9Shenandoah
    9Shenandoah New Member
    28
    Washington State
    2014 Prius c
    I bought a Prius C 2014 last fall with 136K. It was getting maybe 45 mpg . I checked the battery on Dr. Prius and she was 65 %. I reconditioned the NimH battery last winter and I'm getting 53 mpg. I'm going to recondition again and rotate cells in August.
    I'm looking for another Prius in the 2016 range. Am I wrong in thinking that the NimH battery has its good points? If I find one where the battery is at 60 or 70 % on Dr Prius, could I do wrong?
    davev1pa likes this.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Our first Prius was a 2005 Gen 2 with NiMH. We kept it 10 years and put on 145K miles. Toward the end, the battery would not maintain state of charge (SOC) at all. The slightest demand on the battery, primarily going uphill, would cause it to fall to the bottom two bars, which turned purple if I recall. MPG was in the mid-40's.
    The opposite occurred coasting downhill. The battery would fill all the way up and required use of B mode to save friction braking, because regen braking was disabled when SOC was full. We never reconditioned the battery, and eventually sold it for a Gen 3. We had two more Gen 3's but never kept them long enough to experience decreased battery performance.
    Eventually, we got the 2016 Gen 4 with the Lithium battery when it came on the market. We now have had it 9 years and have 90K miles. There is no degradation of battery performance and still get high-50's MPG consistently. It's only one data point, but I believe this demonstrates the Li-Ion battery is superior to the NiMH.
    Deleted member 219929 likes this.
  3. bisco
    52,319
    i think lithium is the way to go.
    toyota says not for very cold places, but we have plenty of midwest and canadian members with good lithium reports.
    other than that, i can't think of any downsides.
    the gen 3 plug in prius from 2012 has shown excellent high and low mile characteristics, and great longevity to date.
    i can only think gen 4 is even better.
    amos likes this.
  4. Cartesian Bear
    Cartesian Bear Junior Member
    2018 Prius
    The inherent drawback of lithium based cells (LiFePO4 or LFP) is that it can't be charged or discharged in cold weather. By about -15°C, most LFP cells cannot put out any useful current. Most or all BEVs (Battery Electric Vehicles, as opposed to fuel cell or hybrid) have battery heaters to be able to start running and then self-heat. Minor note, a frozen then thawed LFP will still hold most of its charge.
    On the other hand, NiMh does work reasonably at cold temperatures. It has a slightly shorter life than LFP.
    In our 2018 Gen 4, the choice was NiMh with 1.25kWh capacity or LFP with 0.75kWh capacity. We chose the former.
    Relevant, note my avatar pic:).
