Right side mirror broken -any suggestions?
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Jul 13, 2025.
Tags:
  1. Paul Gregory
    Paul Gregory Senior Member
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    Well, I guess it makes me stupid to describe my problem and ask for any advice.
    Apparently some of you are never happy with anything I post.
    I call that trolling.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Someone needs thicker skin.
    SM-S936U ?
    Gokhan likes this.
  3. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    Someone needs to grow up and stop getting good at trolling.
  4. Tideland Prius
    16,621
    Except several members here have asked a simple question - with or with PVM and you've failed to answer that. And then you attack the members for trying to get clarity on YOUR situation.
    ETC(SS), Brian1954, Blackat and 2 others like this.
  5. bisco
    52,393
    while these threads can be contentious, they seem relatively benign, and are entertaining if nothing else
  6. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    I did answer the question. You are apparently siding with them. What's stopping you from banning me from the forum?
    Please share with everyone how you restrict someone's bandwidth to the point where it takes 10 minutes just to log in.
    #66 Paul Gregory, Jul 21, 2025
  7. Gokhan
    Gokhan Senior Member
    6,542
    2,613
    Paramount CA
    Toward the very end, you replied to @Mendel Leisk and told him that your mirror is without PVM. Yet, you still stand by that the mirror with PVM that costs $1,200 (more than three times as much as the mirror without PVM) is the correct part, as in your linked post below:
    Right side mirror broken -any suggestions? | Page 2 | PriusChat
    For your information, w/ stands for with and w/o stands for without. So, w/PVM means with PVM.
    This and how you keep attacking everyone is what has been going here. And everyone here is a very nice person, who has kindly and generously offered you his/her help. You have never acknowledged their help but have kept relentlessly attacking them for no reason whatsoever.
    xliderider likes this.
  8. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    Nobody gets their posts nitpicked to death like mine. You don't have to like me, but a bit of respect is in order.
    I believe they may be all nice people in real life, but online, they are like a pack of wild dogs.
    #68 Paul Gregory, Jul 21, 2025
  9. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    I need a break from this forum.
    Brian1954 likes this.
  10. Kevin Grant
    Kevin Grant New Member
    Madison, Alabama
    2025 Prius
    Then take a break dude, your way into the drama side here.
    iPhone ?
  11. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    I answered the question as soon as I was able. To imply that I refused to answer, is a bit of hostility I can do without.
  12. Blackat
    Blackat Active Member
    479
    342
    Colorado
    2023 Prius
    Limited AWD-e
    The lack of self awareness is astounding.
    "Nobody gets their posts nitpicked to death like mine"
    Oh my...
    xliderider, Gokhan and Kevin Grant like this.
  13. Tideland Prius
    16,621
    I agree. But from the moment you joined, you have been defensive and argumentative. I don’t follow every thread so maybe I missed the ones you were nice throughout the entire thread but I will say, based on my limited interactions with you and reading your posts, that is my take.
    Now you can do what you want with that information. I’m not here to pick fights. I don’t know you personally and when online, I try and keep an open mind because one is interacting with a much, much wider audience than one would normally IRL. You can choose how you want to be seen online and you can choose to remain the same or change. Doesn’t matter. But I would say, if more than handful are saying the same thing, maybe chill and look in the mirror. Think about why we are responding the way we are. There’s no secret cabal or collusion to “get back at you”. Respect is earned. The members here have no problem calling me out when I misstep. I appreciate that since it helps me learn. Become a better person and talking with members builds a rapport.
  14. KCWhitney
    KCWhitney Active Member
    140
    118
    Connecticut
    2025 Prius Plug-in
    well written, Tideland. Maybe it takes a word from our Canadian cousin to take another look at ourselves.
    Tideland Prius likes this.
  15. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    Thank you for your time and attention on this matter. I plan to withdraw and reconsider my position.
    I disagree that my position on Prius neutral was just being argumentative. I tried to make my case calmly and rationally, but I became frustrated with the hostility that I saw developing against my idea. I should have realized the futility of pursuing that issue in this forum. If I still felt justified, I should have kept it to myself, and realized that pursuing it further would only result in needless rancor.
    If I do return, I'm sure that I will not try to disrupt the forum in any way I can avoid.
  16. KCWhitney
    140
    118
    Connecticut
    2025 Prius Plug-in
    Don't go away, just watch your temper. Forgiveness is a gods thing.
  17. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    I was able to order a new right side mirror. I had let the parts man know that it was only the top shell that I actually needed. He somehow scrounged up the top shell in addition to the mirror. The top cap doesn't fit quite correctly, either due to the damage on the lower part of the mirror, or because a dog chewed it up. I had left it on the hood of my car, and somehow the dog got ahold of it and chewed the packaging to shreds. There is also a bit of damage to one corner where he tried to chew it. It also has some scratches in the black paint, revealing the white plastic underneath. I can probably touch it up with a black pen. Black Gorilla tape is holding in place. I have to decide if I want to return the mirror assembly next week.
    My brother said I shouldn't have left it there on the hood of the car. I nearly hit him.
  18. bisco
    52,393
    there are loose dogs in the area?
  19. Mendel Leisk
    41,907
    Reminds me of the old homework excuse.
  20. Paul Gregory
    2,234
    593
    Alberta
    2024 Prius Prime
    XSE
    What do mean by loose? Unchained?
