ABS accumulator vs modulator
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KevinMiller, Jul 21, 2025 at 3:36 AM.
  1. KevinMiller
    KevinMiller New Member
    Today
    Los Angeles
    2007 Prius, 107,000 miles
    I am not car-mechanical savvy, as you will see…
    I got all the dashboard brake lights a week ago: BRAKE, (!), ABS, VSC . Still able to drive, but doing so carefully, no freeways.
    -Brake fluid is just below max.
    -12V battery reads 11.3V when not turned on, 14.1V after starting the car.
    -It has been making noise for quite a while; two mechanics told me it was the accumulator making that noise, but didn’t say it was something to worry about. But now here I am…
    -Mileage is lower; tire pressure is fine, so I don’t know if that’s related
    Got an Autozone OBD readout: codes C1256, C1391, C2318 (secondary DTC)
    Mechanic #1 quoted me $3000 (in Los Angeles) without even looking at my car.
    Mechanic #2, did a diagnostic, cleaned voltage connector, found “faulty ABS unit”, quoted me $2600, but for a modulator valve and labor, not a brake accumulator, which is what the OBD codes indicate.
    Wondering if this makes sense. Taking it to be fixed today.
    Thanks for your thoughts.
  2. Tombukt2
    12,257
    2,162
    Whatever you're calling it you're buying the same part . It's all in one unit.
  3. JC91006
    JC91006 Senior Member
    16,676
    8,520
    Buy the part and I’ll have someone install it for $500. New part is the way to go with your low mileage car
  4. rjparker
    9,639
    5,932
  5. ChapmanF
    17,405
    Different Prius generations have divvied up the brake components differently. As long as your car is a gen 2 (2004–2009), your accumulator is part of the actuator (or 'modulator') assembly, so you don't need to worry about it. In some other generations, they're in separate assemblies.
