Hybrid battery - how bout just changing bad cells without "reconditioning"?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrew Vanis, Jul 22, 2025.
  1. Andrew Vanis
    Andrew Vanis Junior Member
    26
    Albuquerque
    I have 2 batteries. one bad cell #7 one bad cell #13 per Dr Prius.
    Cold I just take a good cell #7 from the one with bad cell #13 and put the not-bad #7 into the one with bad cell #7?
    Ideally I would do a complete "reconditioning" like the instructions listed here - DIY hybrid battery reconditioning - where/how to start | PriusChat
    and really since I don't have a battery charger and just want to move the car now, how bout just changing bad cells without "reconditioning"?
    Thanks
  2. JC91006
    JC91006 Senior Member
    16,761
    8,562
    You're better off buying a complete used battery and replace the one you have. The way you're thinking about doing it, it won't last long and with all the work involved in doing it, it might just be worthwhile to do it correctly the first time or don't do it at all. It'll be a waste of time and the problem will come back again real soon
    Brian1954 likes this.
  3. T1 Terry
    T1 Terry Active Member
    929
    478
    The major problem is the stuck pressure release valves in each module pushing the electrolyte out through the terminal seals. The electrolyte needs to be topped up, the pressure valves feed and the module links cleaned and voltage sense wire harness replaced .... along with checking the pin stick out in the battery computer module ..... all in this post here https://priuschat.com/posts/3551878/ How to top up the electrolyte, the mix ration and how to release the pressure valves is in a thread about rehydrating battery modules Re-hydrating the battery modules. | PriusChat
    T1 Terry
    gdanner likes this.
  4. Brian1954
    Brian1954 Senior Member
    2,138
    828
    South Central PA, USA
    How far do you want to move the car? If it is not very far, you should get able to do it with the hybrid battery that is in the car.
  5. Andrew Vanis
    26
    Albuquerque
    Thanks for the replies. Specific replies below.
    Generally, I'm wondering if there would be any harm in my approach (replacing a shown bad cell with a shown not-bad cell) and/or if it might get me 80% there...then I could do the 100% as I have more time/interest/resources....and I'll have the rest of the cells in the left-over battery to replace into the battery that I'd be using to either replace other cells that go bad or to optimize them.
    The car has its battery removed so I have the 2 batteries on the bench (to recap, one has bad #7 one has bad #13
    I don't mind pulling / installing the hybrid battery, its the inside work I don't yet have experience with....and since I have it out, want to see what mostly-there options are available for the bad cell w.o diving into a full reconditioning.
    and to answer your specific question, move it from my front yard to my back yard around the block...but really, If I put the orig battery in It'll probably stay in there until I do a full recondition - though the thing I'm trying to achieve is getting a working battery in there long enough to determine what else the car needs so I could also do those things while the car in immobile while reconditioning the battery..
    It'll be interesting what I find when I open these up. One is a Dorman replacement "just out of warranty" and one is a 3rd party company Toyota refurbished.
    what it seems in the multitude of pages in this pressure valve/electrolyte thread you linked is that it really not figured out yet...thus, back to my "replacing a shown bad cell with a shown not-bad cell" inquiry.
    Considering your post count I heed your advice "It'll be a waste of time". I know it I choose this I might not get much out of it...mainly wondering what to look for/consider in the only-cell-swap approach since I'm not going to do a full recondition right now.
    Thanks again for the replies and look forward to your additional thoughts.
  6. bisco
    51,840
    some have had good luck just replacing bad modules with good, but it's a minority for sure.
    there are too many factors involving the remaining modules to know if it will last very long or not.
    if you just want to move the car, it should work, but won't disconnecting the 12v to reset the codes do the same thing?
  7. Andrew Vanis
    26
    Albuquerque
    For about a 1/4mi code clear works I'd like to get a couple tanks through at least giving it a good drive. The PO said he got an O2 code and maybe some others so would be great to get my own list of codes so I could see all the things it might need and do then while reconditioning the battery.
  8. PriusCamper
    PriusCamper Senior Member
    12,681
    5,119
    Pacific Northwest, USA
    I always explain that if it's the first bad module on a pack that's never had a problem before you can buy a high quality replacement module for $35 and put it in and get lucky for a year. Plenty of people have done that. Of course myself and others sometimes barely get a few miles down the road before warning light come back on doing that.
    As in each module you replace the more problematic the pack is going to get. However if you have access to lots of modules and you recondition and test them and match up modules of similar performance you can get several years from a rebuilt pack.
  9. Hayslayer
    Hayslayer Active Member
    387
    216
    This is the ABSOLUTE wrong way to go. If you have a HV battery that is basically original or 'unrefurbished' or has a ton of miles on it, and now has only one bad module, the last thing you want to do is replace it with 1 HIGH quality module. You want to replace it with a mediocre module, somewhere in the 5400 mah range, so it fits right into the average condition of the other 27 modules. The last thing you want is one module that's in excellent condition where the computer is comparing it to a bunch of not so excellent modules. You're inviting it to throw a code asap, because now the lower capacity (but still good) modules/blocks look like crap compared to the block with the "new" one.
    Yes, your idea can work very well, if you apply some common sense and understand how the battery voltage monitoring and faulting work. The module you install merely needs to be healthy, with no individual failing cell inside. The Dorman batteries are actually typically very decent quality, even including nickel plated busbars and the ecus have always been in great shape. I've repaired a handful that just needed one module replaced and then went on to serve years of additional faultless driving. If I need to repair a 'rebuilt' battery, I'm a bit happier when I find out it's a Dorman. In YOUR situation, with your desired outcome, that's the one I would repair and keep for my car.
    Do your simple repair, verify the condition of the wire harness and ECU socket. If they need repair, then there's going to be some additional expense, or you may be able to switch parts around between the 2 batteries to make a good one.
    Good luck!!
    gdanner likes this.
  10. Andrew Vanis
    26
    Albuquerque
    In the attached pics is the obvious reason bank 13 showed failed in the previously refurbished Toyota battery - it physically blew it's top!
    Interestingly, the dorman has additional temp? sensor in the middle of the pack.
    The fast-approach of me says to replace the showed-failed cell 7 in the dorman pack with the first easiest to remove) cell of the Toyota pack
    ....my ADD will probably have me to the complete charge/resistance on all the cells and put together the best battery from these two.
    We'll see who wins
    The corrosion on the dorman is really only on the main lead wires. The toy one has corrosion on several of the cell bars.
    Here's some pics.
  11. Carall
    Carall Active Member
    306
    102
    Harrisonburg, VA
    Weigh the modules, especially those from 2004 to 2007. If their weight is ~ 1030 grams, you should not expect them to work for a long time. By restoring their capacity, it will be restored, but it will also be lost very quickly after installing the battery in your prius.
    gdanner likes this.
  12. Hayslayer
    387
    216
    WOW. I don't know what else to say about that Dorman. I find it hard to believe that Dorman built that battery with the temp sensors on top of the modules instead of underneath where they belong. It almost looks like they spliced in Gen 3 thermistors (which are top mounted in the wells) to the Gen 2 temp harness. If so, that is still totally unsatisfactory. The Gen 2 supplies cooling air from the top, and should have bottom mounted sensors since that is where the higher temps will be. The Gen 3 supplies cooling air from the bottom and has the temp sensors on the top. That setup in your photos is jacked up.
    Actually, those temp sensors don't even look like Gen 3s. The gen 3s actually clip onto the plastic tabs on each side of the well.
  13. JC91006
    16,761
    8,562
    what should a good weight be?
  14. JC91006
    16,761
    8,562
    Any company that remanufacturers these batteries (other than Toyota themselves at one point), will not have the quality control to have consistently good product. Their job is just to put modules back together and sell them back out, fast turnover is the key to their business model.
  15. Carall
    306
    102
    Harrisonburg, VA
    1035 to over 1040 grams. The higher, the better.
    But the weight does not guarantee that the module will be good. The mileage can be 250k miles on it. I will soon weigh 2015 modules, with 270k miles.
    #15 Carall, Jul 27, 2025
    gdanner likes this.
  16. Carall
    306
    102
    Harrisonburg, VA
    Here is the weight example of the modules that were pulled from a wrecked 2012 Prius V with 144k miles.
  17. Andrew Vanis
    26
    Albuquerque
    I'm grateful for these responses. The weighing of the cells wasn't mentioned in the reconditioning thread suggested in an other thread.
    If any of you have a favorite reconditioning thread from all the diff ones out there please post a link. Since I'm going to do it might as well do it right.
    Thanks
  18. Carall
    306
    102
    Harrisonburg, VA
    Keep in mind that there is a newer type of nimh modules weighing 1000 grams (not 1040 grams), and their actual weight may be up to 1016 grams. 1016 grams can also be found on modules from Panasonic, on gen 2 prius. This is already trash. Usually, the weight does not drop below 1020 grams on Panasonic modules, the triangle lights up much sooner.
    #18 Carall, Jul 27, 2025
  19. PriusCamper
    12,681
    5,119
    That complicates things alot... Any chance someone knows the first known date of manufacture of the lighter NiMH modules?
  20. PriusCamper
    12,681
    5,119
    That makes no sense... Toyota only uses brand new modules... There's zero quality control for used modules with Toyota because they profit off of any possible excuse to sell the customer a brand new pack.
    I think it would be more accurate to say that professional battery rebuilders with 3 and sometimes 4 year warranties have spent tens of thousands of dollars on lab grade electronic gear to maximize quality control, whereas all us hobby charger folks on PriusChat don't have that higher level of quality control.
