Coolant Bypass here in the bay area
Discussion in 'Gen 4 Prius Technical Discussion' started by AJ_182, Jul 17, 2025.
  1. AJ_182
    AJ_182 New Member
    Hello, my prius started to lose engine coolant and i went to a car shop and they diagnosed that it is leaking at the catalytic, and i got a quote for almost $3,000 for catalytic replacement. I searched the internet and found out about coolant bypass as a fix is it a safe alternative long term? And is there a mechanic here in the bay area that you can recommend that can do a bypass? Thanks!
    Deleted member 219929 likes this.
  2. BiomedO1
    4,033
    2,119
    SacTown, Ca
    Welcome...
    The exhaust gas heat exchanger is part of the emissions control system. Under CARB rules, it's warrantied for 15 years or 150K miles, since it was originally sold as a PZEV. If you meet those specifications, it's a free repair. If your just over 150K miles, you can ask the dealership for a good-faith replacement, since there's a TSB out for this issue. It never hurts to ask; worse they could do is say, NO.
    California Vehicle and Emissions Warranty Periods | California Air Resources Board
    I'm looking at your three attachments and concerned about your middle one. The exhaust gas heat exchanger and catalytic converter is a one piece assembly; the $900+ labor dollars seems excessive. Also the heat exchanger is behind the catalytic converter, so leaks isn't going to damage it; but can cause the car to overheat - due to low coolant. I'd probably shop around. According to that estimate, you could buy the OEM part outright and pay any muffler shop a couple hundred to install it. 4-6 screws and gaskets; would take them less than an hour, unless there's a lot of rust on it.
    https://parts.olathetoyota.com/v-2017-toyota-prius--two-eco--1-8l-l4-electric-gas/exhaust--catalytic-converter
    FWIW; if you bypass that heat exchanger and the smog stations sees it - They can FAIL you and/or say you were tampering/bypassing emission control device. I don't know of any 'honest' mechanic that would do that, they could lose their license and/or get fined.
    Hope this helps.....
    #2 BiomedO1, Jul 17, 2025
    AJ_182 likes this.
  3. You could in theory bypass it, then put a catshield up to cover it a bit. Most SMOG stations don't get too busy under there and some don't even check under the hood these days.
    AJ_182 likes this.
  4. rjparker
    10,419
    6,525
    It's way safer than what you are doing now by continuing to drive it. Your engine and head gasket are the big concern. I would bypass it as a diagnostic to verify no engine damage has occurred.
    A bypass will not damage the catalytic converter. A coolant leak can and will ruin your engine.
    There is a method to bypass it from the top although you have to remove the windshield wiper motor and base to access it.
    This video starts with the wiper cowl removed which is not hard. A no parts required fix you could do in your driveway.
    The alternative is replace which could be done later for thousands and not diy.
    Below Capture from Gasket Masters Gen4 Bypass No Parts Required Video
    #4 rjparker, Jul 17, 2025
    AJ_182 likes this.
  5. AJ_182
    AJ_182 New Member
    @BiomedO1
    Hello, thanks for the detailed reply, my Prius is already over 170k miles so i dont know if they'll do the warranty. About buying an OEM parts i really dont have any experience or any knowledge in doing that. About the price, what do you think is the fair price for parts and labor? And for the smog test i just had a smog test a few months ago and i think its gonna be in another two years before i get to do that again, may be in that time ill be able to afford to do the catalytic replacement. I thought of doing the bypass myself and watched some youtube videos but its too complicated for a person who dont even know how to change oil hehe. Do you think it would be difficult to find someone to do it? Id rather pay someone $500 to do bypass than to pay $3000 at an auto shop.
  6. AJ_182
    AJ_182 New Member
    I dont think i can do bypass myself i dont have any experience in doing it. If you live close the bay area lmk id rather pay you $500 than to pay $3000 for catalytic replacement hehe.
    I wish i could do the bypass myself but i dont have any tools or experience doing it. If you live near the bay area lmk ill rather pay you $500 than to pay $3000 for catalytic.
    #6 AJ_182, Jul 18, 2025
  7. Mendel Leisk
    41,833
    I believe Gasket Masters (one of the videos linked above by @rjparker) services “the bay area”.
    That said, the bypass they show is quite straightforward, for DIY. In the video that process starts around 3:00. They don't mention, but the wiper/motor and underlying metal cowl look to have been removed.
    #7 Mendel Leisk, Jul 18, 2025
    AJ_182 likes this.
  8. Mr.Vanvandenburg
    1,357
    579
    2020 Prius Prime
    They hook up to the obd port and it’s done in five minutes including drive in and out. For cars 2000 and newer.
    AJ_182 and Deleted member 219929 like this.
  9. rjparker
    10,419
    6,525
    Gasket Masters phone number is literally in every second of that video.
    AJ_182 likes this.
  10. Depends on the SMOG station, and the person running it. I've had a guy take a mirror on a stick under the car and complain about my catshield...also pop the hood and complain about a visible oil catch can.
    BiomedO1 likes this.
  11. BiomedO1
    4,033
    2,119
    SacTown, Ca
    Take your car registration into any Toyota dealership and ask them for the part numbers of the catalytic converter assembly with the two gaskets that it requires to replace it. Take those part numbers and do an online search for best price, including shipping. Make sure it's Ca EPA compliant and OEM Toyota part, NOT a no-name replacement part. If you buy a OEM Toyota part, that should be Ca compliant. You can go back to the dealership and ask them to match the online price; sometimes they will.
    Take the car to any muffler shop, they'll charge you an hour to 1.5 hours labor to replace it. Don't quote me on this, but I believe bay area labor rates are around $150/hr???? That's why I was appalled at the $900+ your first shop wanted to charge you.
    Make sure you check the coolant levels every-time BEFORE you drive the car; so you don't damage the engine. Keep an eye on the coolant levels for a few weeks after the job is done; just in case someone screwed up....
    Good Luck.....
  12. Mr.Vanvandenburg
    1,357
    579
    2020 Prius Prime
    They aren’t required to do that as far as I know. Two mins per car is the place I go. No hood popping, no looking. 96-99 measure gas at the tail pipe and do a visual all equipment is present and looks connected, maybe 10-15 mins. If they are required to do any visual then my station is cheating. They aren’t, it is a volume business for decades and it’s all they do, $52 out the door.
    Maybe it is because Prius gets cat theft and people do all kinds of things to get going again cheap. I don’t need to get mine smogged until 2028. Pretty sure the obd tells them everything.
    #12 Mr.Vanvandenburg, Jul 18, 2025
  13. You're lucky to find a pretty easy going shop like that..
  14. BiomedO1
    4,033
    2,119
    SacTown, Ca
    Technically; they aren't required to do anything but make sure all the green lights pop up on their OBD2 scanner. But when that technician signs-off, they're saying that all OEM emissions control devices are intact and there's NO illegal modifications. If a few weeks passes and someone finds rusted-on illegal modifications (that's been on there for a long time) - that technician would be on the hook for that.
    But I may be a bit paranoid......
    FWIW; the shop I go to always checks my gas filler neck and does a quick look under my hood. He's never jacked up my car or put a mirror under it.
  15. AJ_182
    AJ_182 New Member
    Hello guys! I decided that im just gonna do the bypass myself. I think i was able to do it, i just spent money on the tools that i bought and i just watched this video from youtube which i think is the most detailed one.
    Im just gonna observe if its gonna lose any more engine coolant in the coming days. Anyways thanks for all that replied, i appreciate you all!
    Deleted member 219929 and bisco like this.
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    Here's a question. Wouldn't "just" bypassing the coolant loop of the heat exchanger cause some performance problems?
    Part of the system is a thermostatic device that operates the exhaust diverter inside. The default (cold) position has the diverter closed, forcing exhaust gases back through the heat exchanger.
    As the coolant heats up, the thermostat moves and rotates the diverter valve open, allowing exhaust to go straight through - bypassing the exchanger.
    No coolant means the diverter never opens.
  17. rjparker
    10,419
    6,525
    While not essential information, the coolant leak is not into the catalytic converter as described in the last video. It is into the exhaust heat exchanger assy welded on after the cats.
    Some would plug the two coolant lines going down to the heat exchanger since a leak point could allow exhaust into the engine compartment.
    You should force the diverter valve open if you leave it longterm.
    A conceptual way to do so
    #17 rjparker, Jul 22, 2025
