fuel tank EVAP lines
Discussion in 'Gen 2 Prius Technical Discussion' started by Dale I, Jul 22, 2025.
Tags:
  1. BiomedO1
    3,937
    2,069
    SacTown, Ca
    Cap EVERYTHING off and do a pressure or vacuum integrity test on the entire assembly - before putting it back in the car. That'll isolate the issue to the tank connections or any joints away from that assembly.
  2. Dale I
    Dale I Junior Member
    34
    Point Arena,Ca.
    Thanks! Will do.
  3. ebikeman
    ebikeman Member
    112
    Northwest
    Just wanted to add anything I can to help. I knew a guy who replaced his charcoal canister. Put everything back together and found one of his lines had that partials of the charcoal in them.
    I think it was a line that goes up to the front of the engine compartment.
    Make sure you check all the lines before so you don't have problems again.
    ebm
  4. Dale I
    34
    Point Arena,Ca.
    I fully plan to blow out all the lines that I can. I just don't expect any different results...
