Wrapping stock intake with tinfoil bubble and then heat resistant wrap?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Jul 11, 2025.
  1. frodoz737
    frodoz737 Top Wrench
    4,693
    2,492
    33
    ...again, your car, your money, your time. That said...fixing a broke car happens long before adding window tint...so to speak.
    Brian1954 likes this.
  2. h1ph0panonymous
    258
    36
    Yes I’ll report back if I see it reach 195 from those particular stop light heat soak occurrences but the only reason I kept note of it on the highway was to see if there was any cons to it at higher speeds and RPMs when everything is staying warm the whole duration of the highway trip which I did not see any . For now it definitely does seem to cool down faster in conjunction with the cabin exhaust method than just no wrap and cabin exhaust. I would have to get a stop watch to see the time difference in how long it takes for a single drop in temp and hope the weather conditions are the same, although why so many days apart, could I not just do it two different trips in the same afternoon?
  3. h1ph0panonymous
    258
    36
    I have 4 new brake rotors, 4 new brake pad sets and a pressure system brake flush put on and done on the car, I think the new front brakes can handle the weight until its new buddies in the back start working again.
  4. frodoz737
    4,693
    2,492
    33
    Cart before the horse...but that tape sure is pretty.
    #224 frodoz737, Jul 25, 2025
  5. Brian1954
    Brian1954 Senior Member
    2,165
    843
    South Central PA, USA
    I was saying to drive your car for two or three days to collect temperature data while not using the heater fan. Two trips without using the heater fan is not enough data. I am sure that you observed the temperature data for many weeks of usage before you did the gold-filled wrapping. You need to collect more data with the gold foil installed, driving in stop and go like you described at the beginning of this thread, to compare it with the data you collected before the wrapping.
    #225 Brian1954, Jul 25, 2025
    h1ph0panonymous likes this.
  6. h1ph0panonymous
    258
    36
    I can tell you already just from one day without the cabin exhaust variable that it does help the car stay below 190 degrees before getting to a stop light and the weather was 82 degrees and slightly humid. It got as low at 186 before getting to a stop light but it stays at 186-188 at the stop light due heat soak. As expected it did what I wanted, not directly combating heat soak but to reduce normal heat soak temps before getting to a heat soak idle. Now with the cabin exhaust measure that does directly combat heat soak since air is moving from the engine bay to the cabin during heat soak idles. So all in all I would average it to 3 degrees cooler than with no wrap, which is enough gain (even as small as it is) to justify the time spent doing it, still have half a roll left of it but cost me 35 dollars for a 2 inch by 15 foot roll of it. And just a reminder this was just the intake wrap, there’s more things that can be wrapped and done to further create the effect I’m looking for. Like the manual radiator fan switch and hood vents, more costly though so hard to gauge if it’s worth it but seeing as I’ll spend 35 dollars for a 3 degree lowered temp pre-heat soak effect I guess one could see me going on to do any other things with said effects I’m looking to get.
  7. h1ph0panonymous
    258
    36
    To add on to my last reply here are some more notes or data taken without the cabin exhaust.
    Coolant temp cools down faster when going fast (+50mph, the wrap is catching cold air from the wind coming in at those speeds) to a dead stop.
    Coolant temps drop faster from high demand accelerations (Goes from 193 to 191 within seconds of lowered throttle from high throttle driving demands like over passing on highway)
    Coolant temps didn’t rise as fast on uphill climbs, there’s a quarter mile steep hill I go on almost everyday and would see it reach as high as 197-200 degrees once reaching the top of the hill doing +3500 RPM @ 45-50 MPH the whole climb up the hill before the wrap, with the wrap it only reached 195 at the top of the hill and instantly dropped to 193 once I got to the top of the hill when letting up on the throttle demand, then would take 15-30 seconds to go back down to 188 degrees after that once on less hilly semi-flat roads we’re driven on.
    As stated before, coolant temps would stay as low as 186 degrees during normal driving in between lights (non-highway driving).
    Stayed at 188 when cruising at a steady speed on the highway below 70 MPH.
    At 70 MPH it would stay at 191 for less than a minute once reaching that speed than drop to 190 once cruising at that speed after a minute or two and then 188 after 3 minutes if highway is flat. (I’m guessing more speed equals more colder air beating on the wrap causing slightly cooler material to be caught by the air going inside the intake if that makes sense, might not be using the correct words)
    Can’t remember any other observations or notes but will post if I do.
  8. Hayslayer
    Hayslayer Active Member
    390
    219
    You are delusional. It's much more likely that you're just seeing what you want to see. Or maybe while you were disassembling everything, you knocked some crud off the radiator.
  9. h1ph0panonymous
    258
    36
    Again, this whole thread feels like an atheism versus theism debate. I’m not asking you to believe me, the truth claims I’m making aren’t from confirmation bias or placebo effect from the research of it. If you actually google it, there’s a Reddit post with a comment that actually states wrapping the stock plastic intake assembly actually does help with heat soak prior to coming to a heat soak idle. That’s all this thread was about, indirectly combating heat soaks, any other effects it gives me is a plus such as the intake now getting cooler faster than when it wasn’t wrapped, the wrap doesn’t reflect cold air, it reflects radiative heat. To reflect cold air, you use insulation. The gold wrap isn’t an insulating material because there’s no air gap in between it and the material it adheres to.
    Do whatever you want with that information.
    Something I didn’t mention when doing the wrap was that there was a considerable air vacuum leak where the straight tube connected to the air box, in the picture you can see I quadruple taped that connection leak with Super 33 electrical tape because the foam inside that connector was degrading and was showing noticeable air gaps, there is no way that was the increase in good effects I observed after test driving it after the wrap job, i’ve had to do this to my first car I ever owned because the stock air intake assembly sucks and always has air gaps and leaks so I seal them off with adhesives. There was no magical crud that came off the radiator especially because that’s where the radiator fans sit so no contact with the radiator can be made when taking out the air intake assembly. IMG_1155.jpeg
    #229 h1ph0panonymous, Jul 27, 2025
  10. frodoz737
    4,693
    2,492
    33
    You started this thread more than two weeks ago...and you still haven't fixed your car.
  11. ASRDogman
    ASRDogman Senior Member
    7,549
    3,897
    Let'ssss.......... wraaaapppp it up!!!! :eek::eek::D:D:D:rolleyes::rolleyes::LOL::LOL::LOL::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    h1ph0panonymous and xliderider like this.
  12. Hayslayer
    390
    219
    I think you should remove the Super 33+ electrical tape and just throw away the inlet tubing. Now the airbox can draw air directly from the engine compartment, removing all the hot air as you scream from redlight to redlight.
  13. h1ph0panonymous
    258
    36
    Make a short ram intake? I’m good, don’t need more hot air.
  14. h1ph0panonymous
    258
    36
    Do it, it’s more of a jigsaw puzzle wrap.
  15. h1ph0panonymous
    258
    36
    Didn’t know the thread was about fixing my car, funny.
  16. Hayslayer
    390
    219
    No, you certainly don't.......
