Yikes!! LOOK what they DID to my poor Prius!!
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, May 26, 2019.
  1. cyberpriusII
    1,157
    1,833
    Hyampom
    First, I do not like killing any animals -- and though I am no longer a vegetarian and I support rational, regulated and controlled hunting -- I do try to avoid killing anything.
    I would never use a glue trap. Inhumane. I gave up using poison bait. I use Victor Tin Cat live traps, which are amazingly effective. The little mice are so cute in the traps. I know the odds of them surviving after relocation may not be optimal, but it gives them a fighting chance.
    When the population soars, which it seems to have done this year, I supplement with the old style snap traps. The ones with the spring loaded bar and bait pedal. At least that is usually a quick and humane death. Caught 14 a few nights ago between the live trap and the snap traps.
    My black lab usually lets me know when mice have been around. She stands at the Prius front tire and whines and points.[​IMG]
    I usually slightly modify the trigger on the snap traps to make them more sensitive -- which means I catch myself a lot.
  2. cyberpriusII
    1,157
    1,833
    Hyampom
    I debated replying to Bisco's question about the injury. I really do not like thinking about it, looking at my arm or touching my arm anymore.
    I also do not like looking at, touching or thinking about my hip, which is actually by far the more serious of the fractures. Then there is the broken tibia (shinbone), cracked patella (knee cap), black eyes, hearing damage, numb right hand, broken rib....huh, now I'm depressed.
    Anyway, I'm purged of it and am moving forward. Slowly :p
    kris
    #22 cyberpriusII, May 30, 2019
    Merkey and fuzzy1 like this.
  3. tochatihu
    tochatihu Senior Member
    9,850
    3,809
    Kunming Yunnan China
    2001 Prius
    No names but guessing would not be so hard. Yrs trly hangs out with forest canopy researchers, one of whom lost the gravity war and was very much disassembled. Not dead but awfully close.
    She recovered slowly but completely. It's only her sensible husband who's keeping her from going vertical henceforth.
    do not know why I bring that up except dang, human self-repair is amazing. Dial in some modern medicine and wow just wow.
    Patience seems the hardest thing. Or maybe it's pain. Only much-broken folks know about that.
    Merkey and jerrymildred like this.
  4. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Sorry to hear about the accident Kris. Get well soon
    iPhone 6s +
    bisco and Merkey like this.
  5. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    She doesn't have mice, she has temperate rain forest mini-dogs. You can tell from the shape of the pellets. Glue traps don't really work on them but the screening does.
  6. cyberpriusII
    1,157
    1,833
    Hyampom
    Old thread, but...
    I just discovered mice in my Subaru Outback after six years of ownership.
    They had stuffed seeds under the insulated pad that is attached to underside of hood.
    So opened hood and heard dozens of round seeds rolling around.
    Pulled the cabin air filter and the rodents had just started construction on a nest.
    Removed seeds. Replaced cabin filter and set traps for three nights. Caught seven.
    No mice for four nights now, so am removing traps for a bit
    But nothing like old days in the Prius
    kris
    ETC(SS) and bisco like this.
  7. ETC(SS)
    7,331
    Coincidently, I just added some glue traps to my shopping list today, since the teens in my church cannot be trained to close or clean.
    Were I a better person I would opt for the not-glue kind, and I also abhor rodenticides - but only because I do not like the down-range effects on raptors and other predators.
    This limits my options unless I want to spend a lot more time in church servicing traps - and we Baptists are in the fellowship hall enough already!!!
    (IYKYK :ROFLMAO: )
    Once, I did manage to peel one of the little blighters off of a glue trap in good enough shape to release it.
    I threw it into a pond, thinking "if you make it to shore, then you're FREE!"
    It got close. ;)
  8. Mendel Leisk
    41,850
    I did that once too, swore to never use them again. Read up, and the recommendation was to drizzle cooking oil on them, it would loosen the glue. Well I got him free eventually, with gentle as I could lifting with needle nose pliers, but the poor guy was as good as dead, one gimped leg and oil drenched. :(
    Finally (knock on wood) found their point of egress to our house:
    Just need to vent... | Page 96 | PriusChat
    #28 Mendel Leisk, Aug 11, 2025
