Mixed Messages on Gen 3
Discussion in 'Gen 3 Prius Main Forum' started by c.ortiz108, Jul 29, 2025 at 3:12 PM.
  1. c.ortiz108
    c.ortiz108 Junior Member
    70
    NM
    I find myself in need a car and am shopping for a used Prius. I've had two Gen 2s in the past, and was very happy with them overall, but I'm thinking at this point they're just a little too old. When I was looking a few years back (and ended up not needing a car at that time after all), the consensus was to avoid the Gen 3, but reading some stuff online paints a different picture. Some Gen 3s are often listed as the best years of the Prius, especially the later end of the run.
    For example, 6 out of the top 10 most reliable on this list are Gen 3: Ranking The Top 10 Toyota Prius Model Years For Reliability
    This list includes 2013, 2014, and 2015 among their most reliable: Which Years Of Used Toyota Prius Cars Are Most Reliable? - CoPilot
    That's just two examples among others, and they're really at odds with what I read here.
    Is the bad reputation of the Gen 3 mostly due to the earlier years, and are 2013-2015 exceptions?
    I'm looking at a 2014 with 120k miles for $5,900 which seems very good. But not if I'm about to get a blown head gasket etc.
    Would it be smarter to really limit my search to a Gen4 and just accept spending a bit more? Or are they also starting to show issues?
    I'm looking for something under $10k and need it for taking road trips.
    EDIT: to add that I'm not mechanically inclined when it comes to cars and don't want a DIY project. Just something reliable and economical.
    #1 c.ortiz108, Jul 29, 2025 at 3:12 PM
  2. Leadfoot J. McCoalroller
    7,905
    7,375
    Pennsylvania
    2018 Prius c
    They aren't all bad. Not even most of them.
    But the ones available for purchase aren't so hot, which is exactly why they're available. Everyone is clinging to the good ones.
    Used cars are in short supply overall. Good used cars are still getting very high prices. Add in that a Prius is a sophisticated car with a lot of technology, making it harder for an inpsector (lay or professional) to sort the good ones from the bad ones, and you get the current situation.
    So it's easy to produce an article that truthfully says "hey these cars are great, the stats say there aren't a lot of problems" but they're just looking at the raw fleetwide stats rather than focusing on the inventory actually available for purchase.
    What you're reading here on Priuschat is almost the opposite: Lots of threads with results of people who are picking over the same few not-very-nice cars while everyone else whose car is running great has little need to ever post here.
    Good luck!
    c.ortiz108 likes this.
  3. bettergolf
    bettergolf Active Member
    482
    362
    Sanford NC
    I think the Gen two's are not too old anyway...find one with about 150k miles and you should be ok. Some here currently still prefer them over the Gen threes.
  4. PriusCamper
    PriusCamper Senior Member
    12,121
    4,912
    Pacific Northwest, USA
    2014 w/120K miles for less that $6K sounds great. 2010-2013 seems to be the ones that blow their headgaskets prematurely. Also the cars that have piston rings go bad prematurely. Toyota made some incremental changes to 2014-2015 to address most of these problems, but they were NOT entirely resolved until 2016 when EGR system was put further downstream of the exhaust system.
    Adding an oil catch can and regularly cleaning EGR system to this 2014 will probably address most of these issues.
    How many mile a year do you drive? If it's not too much and 200K miles is years away then go for it. But it you can drive up to 200K miles in a year or so then maybe hold out for a 2016 or newer.
  5. Leadfoot J. McCoalroller
    7,905
    7,375
    Pennsylvania
    2018 Prius c
    For a budget like yours and little mechanical ability, I'd advise you to straight up avoid the Prius and look for something simple like a Corolla. Every mechanic in town knows how to fix them, and also how to spot problems in them before you buy, should you hire one for a pre-purchase inspection.
    With gasoline prices as low as they are right now, the extra fuel costs are pretty small vs. the risk of expensive failure in a complicated car, at least until you are driving a zillion miles a year.
  6. c.ortiz108
    70
    NM
    I've been without a car for a while, just relying on my bike and public transport. But I have an aging parent I'd like to visit more often, and it's 2,300 round trip. I expect to do that at least twice a year, maybe even thrice. Plus another 1,500 mile trip once a year, and generally take advantage of having a car which I've been without for a while. No daily commute, but I think the difference in MPG with a Corolla or whatever would add up pretty quickly.
    I live in the SF Bay Area, so I'm guessing there are plenty of mechanics who know these cars here. There are tons of Prii on the road.
  7. Leadfoot J. McCoalroller
    7,905
    7,375
    Pennsylvania
    2018 Prius c
    That's not nothing, but for many drivers the real savings a Prius gives you don't arrive until you're driving upwards of 15,000 miles per year. And that's for a new one with extremely little likelihood of an expensive problem.
    Also consider that while Prius mechanics are easy to find near home, it'll be the opposite when you are out on your trips.
  8. PriusCamper
    12,121
    4,912
    I'm same but opposite... Up in the Seattle area and elderly parents in California and 2400 mile round trip... Prius are great cars for taking the cost and hassle out of dealing with elderly parent visits. And freeway driving puts way less wear and tear on the the car than driving in SF Bay area traffic commuting long distances every work day and parking in a big parking lot with no shade is really hard on a hybrid car.
    All that being said, let talk more about this 2014 with only 120K... Why is the price so low? We'd like to help you decide on if that's the right car to buy so please give us as many details as possible!
  9. c.ortiz108
    70
    NM
    If I want to stick with a Prius (which I kind of do), I guess it boils down to how much better a Gen 4 is compared to a later Gen 3, considering the price difference. For example there's a 2017 with 152,000 miles for $10,800; a 2017 with 225k for $10,500, etc.
    Another issue is that I need to keep the car in a driveway, and I think I've read that Gen 4s aren't targeted as much by thieves for their catalytic converters? I had one stolen of one of the Gen 2s that I had, after midnight, in a foreign country, 2 hours from home. It was a nightmare.
  10. c.ortiz108
    70
    NM
    I've messaged him for the VIN, but in the meantime he says clean title, great condition etc. But actually, looking at it again, he said "It has the new engine with 120,000 miles" -- so maybe that's the miles just on the replacement engine. I'll clarify with him.
  11. Leadfoot J. McCoalroller
    7,905
    7,375
    Pennsylvania
    2018 Prius c
    My other advice for Prius-shopping: buy the youngest one you can afford and ignore the odometer, for the most part. Prius hybrid batteries will go bad over time whether you use them or not, so get a fresher one that has more future utility left.
    As far as catalysts go- I understand the one in the 2nd generation cars was particularly desirable due to its large size and relative ease of access.
    It's smaller in the newer models, and at least somewhat harder to get to.
  12. c.ortiz108
    70
    NM
    That's what I'm thinking -- good to have it validated. I'll be going to Santa Fe with a dog who get really distressed when he has to fly, and costs $300 to ride in a carrier under the seat. There are no direct flights to Santa Fe from here, which means flying to Albuquerque, then taking an Uber to the train station, an almost 2 hour train ride, then a 40 mile Uber ride once I get to Santa Fe. Then a hotel stay on the way back because the flight is so early. What should be a short trip ends up taking the best part of a day, and being pretty expensive.
  13. PriusCamper
    12,121
    4,912
    Gen2 Prius take less than 60 seconds to steal a cat... Gen3 and Gen4 are much more difficult to steal and were mostly done mistakenly because thieves didn't realize that the Gen2 cats are the ones with the most precious metal in them. In general we're past the cat theft days because all the primary buyers got taken out so thieves can't find people to turn them into cash quickly anymore.
    Once you get the VIN# it'd be worth paying to get the service history through car fax business, but first try to enter Vin # at Toyota Owners Portal & Account Access | Toyota.com because they'll have the same information for free.
    If the engine was replaced we definitely need more vehicle history information. It'd be ideal if the engine swap was done recently...
  14. PriusCamper
    12,121
    4,912
    Yep... When you're dealing with parents that are starting to fall apart with old age you need those visits to feel as affordable and effortless as possible because there's already going to be lots of stress in having to watch parents get old and deteriorate. Also if you can drive mostly at night that can greatly limit the wear and tear on the vehicle in the Southwest.
  15. Grit
    Grit Senior Member
    6,470
    4,199
    Wilkes Land
    Turd gens are ticking time now. Go with a 4th gen with bat man tail lights or gasser. If you don’t want to wrench away on the turd gen, stay away.
  16. Andy Pants
    Andy Pants Junior Member
    31
    WIsconsin
    If you get a 3rd gen get a 2015, that's the only year that got revised piston rings and that seems to have increased reliability of the engine. But that does nothing for the potential brake booster issues. The holy grail prius would be a 2022 as that was the last year of the 4th gen, not much that can go wrong with those but they are pretty pricey for a used prius.
  17. Mendel Leisk
    40,666
    ^ Hoo boy…
