Help! ABS code that won't go away!!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Boognish, Jul 30, 2025.
  1. Boognish
    Boognish New Member
    usa
    Hello beautiful people and community:
    I have a 2013 Prius 5 with 200k miles. I bought this car with all the lights on the dash lit up like xmas tree. I had to replace the steering rack as soon as I bought the car, as it wouldn't drive straight. I have C1464 code for my front right ABS sensor. I verified on techstream that it is reading 0mph. I replaced the ABS sensor, still didn't fix it. I replaced the wheel bearing (thinking maybe tone ring issues) and still didn't fix it. I unplugged the connector from the ABS module, and verified that the wire is in good condition, and both front ABS sensors reading around 1.2-1.9 megaohms.
    I really don't know what else to replace. I know these cars have issues with ABS, but not exactly the module going bad. Of the more than 4 dozen cars i've had in my life, this is the first time I'm suspecting an ABS module just going bad, and not reading ABS sensor anymore.
    Is there anything else I can test here before just buying another ABS module and pump assembly? What is the best source for those things?
    Thank You, and be safe out there
  2. Tombukt2
    13,058
    2,340
    The ABS modules two of them go out on this car all the time you can read hundreds of posts about just that .
  3. ChapmanF
    18,257
    If the only code you have is C1464 for a specific wheel sensor signal, have you followed the full troubleshooting procedure in the repair manual for that code?
    Toyota Service Information and Where To Find It | PriusChat
    There are probably more answers besides "replace the sensor" or "it has to be the ECU".
    There's a PDF of the 2010 manual floating around but doesn't have that code in it. It may be a code added in a later model year. Might have to go on TIS to read about it.
  4. Boognish
    Boognish New Member
    usa
    is that just the gen 2, or gen3 also has same issue?
    I don't have the full repair manual, so... but really there isn't too much involved. I just find it crazy it would be the ABS module
  5. h1ph0panonymous
    258
    36
    Try replacing the pigtail even if it reads good, the terminal could be bad itself.
  6. Tombukt2
    13,058
    2,340
    The gen3 has two pieces on firewall that separate the pieces. It's recommended to replace both on gen3 see bulletins. We won't worry about gen2
  7. ChapmanF
    18,257
    Yeah, seeing that the only trouble you have is for a single wheel sensor signal, and you have none of the codes associated with the way the module usually wears out, I would for now keep focusing on the troubleshooting steps for the code that you have.
    Even that code's troubleshooting could, possibly end up back at the module (once you're sure you have conclusively ruled out the sensor and all of the wiring), but that isn't common.
  8. Boognish
    Boognish New Member
    usa
    Just an update -
    I changed out the connectors, crimped on new ones on the ABS sensor side AND on the car wire harness side
    paperclip in the OBD connector to reset the ABS, hit brake pedal 8 times, wait a long time...
    and it came right back. Still getting the code that it is not getting any speed measurement from front ABS sensor.
  9. ChapmanF
    18,257
    Can you help us compare the tests you've already conducted to the ones in that code's troubleshooting section in the repair manual?
    If you don't have access to the repair manual yet (you mentioned on July 30th you didn't), this page explains how to get that.
    h1ph0panonymous likes this.
  10. h1ph0panonymous
    258
    36
    Crimped on?
    Boognish likes this.
  11. Boognish
    Boognish New Member
    usa
    Yes, Crimped on, and then heat shrunk for waterproof connection.
    I haven't followed the rest of the guide yet. Honestly kinda a lot of hoops to jump through to get the manual :( the source i found, breaks out each section to a billion different PDF's, making it fustrating to navigate. But i'll get to it soon I promise, it's really bugging me not having cruise control and regen braking... and driving all my friends prius's that do!
