What's the newest data analysis and results? --- EGR clean prevents HG gasket or is it inevitable
Discussion in 'Gen 3 Prius Main Forum' started by Eun yushiro, Jun 20, 2025.
  1. Eun yushiro
    Eun yushiro Junior Member
    Van Nuys, CA
    2014 Prius Plug-in
    Our 3g's have hit high mileages now and even more sample sets of data...
    Does the EGR + intake manifold clean actually help prevent Head Gasket Failure - or are those that saying it's Inevitable the HG fail --> Correct?
    Wondering what the conclusion is in your opinions given that we've had much more miles put on our cars
    Why is this important. Can help others know if they should just preventatively change the head gasket now, as well as do the EGR clean, or really just do the EGR clean and be done with it
    My prius is at 128k miles
    Just got the EGR valve and cooler out -- Took me 1 month with the car sitting in the garage. I'm learning how to work on cars (i'm a hospital therapist by trade) -- none of this is easy and takes me 10x longer to do
    Please do share the data. I'm wondering if I should just learn how to change the head gasket now to Fel Pro but it seems way over my head and I don't have the time to just sit hours in the garage. Have a beautiful young baby daughter I spend all my time with and would prefer it that way
    52,362
    unfortunately, there is no data. data requires controlled testing and record keeping, of which we have none.
    what we do have is a lot of experiences reported, good and bad. we do know that not every head gasket blows, if you put some mileage/time on the answer.
    toyota says it is badly designed water pump speed software, for which they offer an update (in europe only?)
    many guesses here include egr and related assemblies, defective head gaskets, 10k oil changes, infrequent coolant changes or even ph testing, poorly designed pistons and rings, and etc.
    how to make sense of all that?
  3. Mendel Leisk
    41,873
    A lot of the naysayers give examples, owners that clean their EGR when the odometer's into six digits, and maybe even exhibiting head gasket failure symtoms, such as cold-start shakes, losing coolant. The concept of "interference engines" comes to mind, basically something advantagious is applied to an engine, with the caveat that something else is implemented, to allow that application to work safely.
    With 3rd gen Prius, better mpg (a tenth or two of a mpg) was achieved, by running it leaner, and to keep the engine from overheating the EGR system was added. If Toyota had bothered to run a few test cars for 200k miles, we likely wouldn't be where we are.
    Same could be said for the low-friction piston rings. Anyway:
    ^ A lot of times the naysayers will say "I cleaned the EGR, and head gasket still blew". When asked at what miles, it's typically around, well, your miles. Bottom line, just from reports here, my take is it needs every 50k miles, or less. Any more than that, the EGR is compromised, has reduced flow, unbalanced flow and/or overheated flow. Likely all three.
    Belated cleaning is still good to do, but definitely don't get complacent. Our third gen YouTube guru @NutzAboutBolts cleaned his EGR and intake manifold around 120k, and is now having head gasket failure, around 180~190.
    See the top two links in my signature*, also see this workflow summary (just for the EGR side of it, not the intake manifold).
    * on a phone turn it landscape to see signatures
    Not sure if it's mentioned in any of the above links, but exclusively for the EGR cooler, I'd recommend a lye solution soak, for fast/thorough cleaning. It's stainless steel, impervious to lye, and really needs something strong, due to the internal radiator labyrinth. For everything else brake cleaner, brushes and rags will do. You definitely DO NOT want to or need to use lye on anything else. It will react with aluminum, non stainless steel.
  4. Eun yushiro
    Van Nuys, CA
    2014 Prius Plug-in
    Have watched your posts for many years, thanks for your helpful comments.
    I'm about to do the strut/spring with KYB's, and the sway bar end links (oem)
    Bought LBJoints but don't want to deal with it this time around
    I'm doing spark plugs (original PIP size was 15mm, new updated item# was 14mm)
    Looks like the data that I've gathered from here, reddit, and FB prius groups is that the HG tends to fail at a high rate at 180-200k miles.
    That'll be 5-6 years for me, and I'll revisit the headgasket job in doing it myself
  5. Mendel Leisk
    41,873
    My unsubstatiated hunch: with regular/complete cleaning of the EGR system, at least every 50k miles of the car's life, the head gasket is much less prone to fail.
  6. ChapmanF
    18,513
    That misstates what it's for, though. The EGR is primarily there to reduce NOx emissions, by reducing peak instantaneous temperatures reached in a very brief part of the stroke. NOx is only formed when the instantaneous peak goes above a certain temperature.
    Over the several decades of cars having EGR, the manufacturers did figure out how to get MPG improvements from it also, by tricks like using it to reduce power without closing the throttle as far, so less work is done pumping air across the throttle. That made it no longer a necessary-evil tradeoff of MPG for antipollution, and instead a win for both (a big and important antipollution win, and a more modest MPG win).
    It's important to think separately about "instantaneous peak temperatures" and "overheating". Overheating is a macro phenomenon, what temperature the engine materials and coolant reach. The cooling system is what controls that, and it takes in stride bigger changes in heat production when you accelerate, coast, or go from downhill to uphill, than any difference the EGR makes.
    If it were not so, you'd be able to use the coolant temperature reading to know when your EGR needed cleaning.
    Mendel Leisk and Brian1954 like this.
  7. wheelsup
    wheelsup Member
    103
    Raleigh, NC
    I'm under the impression that it's the thermal cycling that is causing the HG issues. EGR blockage will increase crankcase pressure but typically that will result in oil being blown out of seals like the RMS or similar.
    You can test for this condition by putting a glove over the oil fill hole and running the engine.
    If concerned you could always remove the dipstick and run a heater line tube off it and route it under the vehicle to vent excess crankcase pressure. Just remove prior to your annual inspection :D.
    Also, replacement of coolant in regular intervals should reduce its acidity and its ability to attack the factory HG.
    On our vehicle specifically, early replacement of the engine coolant pump (electric) is also needed as I do not believe we have any sort of CEL or light if it fails.
    I read a writeup from someone who worked at an independent Toyota shop that stated that 90% of the HG failures in their shop were accompanied by the coolant pump failure.
    #7 wheelsup, Jun 26, 2025
  8. ASRDogman
    ASRDogman Senior Member
    7,796
    3,976
    It's likely a combination of things. And the pcv valve takes care of the pressure.....
  9. wheelsup
    wheelsup Member
    103
    Raleigh, NC
    You'd hope. I have no idea where it is on the Prius but in an older vehicle, the PCV would clog and blow the RMS.
  10. ASRDogman
    7,796
    3,976
    Underneath the instake manifold, on the front of the engine block.
    wheelsup likes this.
  11. Mendel Leisk
    41,873
  12. Mendel Leisk
    41,873
    EGR is the one potential culprit that seems to have a direct corellation to the regular-as-clockwork failures at cylinder one: the intake manifold's EGR capillary passage at cylinder is usually the first to fully clog. Behind the scenes Toyota maybe had a similar inkling, they revised the way those passages split off the intake manifold's main EGR gallery.
  13. ChapmanF
    18,513
    They did that for the snorts-condensed-water-after-cold-soak issue though.
  14. CR94
    CR94 Senior Member
    2,741
    1,198
    Northwestern S.C.
    ...and don't forget the coolant pump impeller hypothesis.
    Meanwhile, in hope of forestalling head gasket trouble, I'll watch coolant temperature, clean out the manifold EGR passages occasionally, and monitor EGR flow test results the car reports. I also try to avoid working the engine hard when it's cold (to minimize rapid temperature swings). So far, so good...
  15. Andy Pants
    Andy Pants Member
    36
    28
    WIsconsin
    I think that like most things in life the HG issues are from the combination of all these factors. The only one that we really can't do anything about is the frequent thermal cycling from being a hybrid. List of things to help would be: buy a 2015 so you start with better piston rings (lol), clean egr like Mendel says, change coolant every ~50k miles, 5k oil changes, use a scan gauge to monitor water temps (I preventatively changed my water pump at 173k miles and it was still in almost brand new condition, so might be better to just monitor vs replace), and inspect/replace pcv valve. I wouldn't preemptively replace the head gasket as it's a big job (easier when compared to many other cars but still very time consuming) and there's always the chance the hybrid battery, brake booster or inverter fails and then you have a broken down car with a fresh head gasket that needs another expensive repair...
    Merkey likes this.
  16. Mendel Leisk
    41,873
    To clarify, I think you’re saying to occasionally clean intake manifold’s EGR passages, but leave the rest of the EGR components? What’s the miles on it?
    That is the Toyota* recommendation, for both inverter and engine coolant, after the initial changes. Well 50k miles or 5 years, whichever comes first.
    * Toyota USA and Canada
    Merkey likes this.
  17. Leadfoot J. McCoalroller
    8,137
    7,642
    Pennsylvania
    2018 Prius c
    This is someplace where data would really help.
    Cylinder #1 is closest to the water pump, so heat distribution issues can be implicated with equal weight as the first-blocked EGR passages, IMO.
  18. CR94
    CR94 Senior Member
    2,741
    1,198
    Northwestern S.C.
    Yes, as long as the automated flow test shows very little overall restriction.
    Engine oil consumption is still lower than that of any other vehicle I ever knew.
    The odometer recently passed 159k miles (as noted in my signature).
