Must I use the gas??
Discussion in 'Prime Plug-in Charging' started by Kiana, Jul 26, 2025.
  1. Kiana
    Kiana New Member
    Honolulu
    2025 Prius Plug-in
    I get FREE charging everyday. I could run only on EV forever, but my dealer said that I must use the engine. Is this true? Can I use my engine just a little bit so that it warms up and that go back to EV mode? I have a 2025 Plug in prius. Thank you very much!
    52,286
    i would only keep a few gallons in it, and run through it once a year
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You should have bought a EV instead of a PHEV. Since you have a gas engine, you still need to run it periodically and do all the maintenance (oil, filters, coolant, etc.) you've done with all other gas cars.
  4. ETC(SS)
    7,312
    It is a little curious that you're hauling around hundreds of pounds and ten thousand of dollars worth of drive train components that you don't want to use - and let's face it.
    It's not like you're going to be taking any weekend road trips in this car.
    Put a half tank of gas in the car and run the engine every now and then to and keep the "change owner light" from illuminating in order to maintain the car's value.
  5. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Have you ever heard of the phrase "Use it or lose it"? That's what will happen to the gas engine side if you let it sit unused.
    Try to keep the gas tank about half full and run your engine to full warm-up BEFORE shutting down, at a minimum. This should probably be done every other week, in your high humidity climate. You see how fast things rust around you; what do you think is happening to your engines' internals if they don't move?
    Good Luck......
  6. Mendel Leisk
    41,824
    Do you have a regular, 5 day a week commute? In your shoes, I’d purposefully run it like a non-plug-in hybrid, using the engine, one day per week.
  7. FuelMiser
    1,349
    929
    Monument, CO
    I've read recently that it takes a drive of 1 hour to properly heat the engine enough to keep away harmful buildups in the oil, plugs, etc.
  8. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    That might be true for something older or larger like a commercial truck, but you can get a small auto engine as featured in your Prius through a full warmup in just a few minutes.
  9. BiomedO1
    4,019
    2,109
    SacTown, Ca
    There's an exhaust gas heat exchanger to speed up the process and the ECU controls all the ICE operations parameters. Running the car for an hour, even in HV mode wouldn't help all that much - because the ECU controls how often and long the ICE will stay on. There's only so much you can do, when "Skynet" over rules you.o_O:oops::sleep:
    You can place the car into maintenance mode; but to me that's a waste of time and gas. Actually running the car and placing a "load" on things would work better - IMHO.
    #9 BiomedO1, Jul 28, 2025
  10. FuelMiser
    1,349
    929
    Monument, CO
    Yes, this heats the engine coolant. I was referring to getting the engine oil up to full temp. This is needed to keep harmful contaminants from building up in the oil. Of course, the computer controls ICE operation in HV mode, but steady driving will keep the ICE engaged pretty much all the time at highway speeds. Also, I believe that putting a Prime in Charge Mode will run the ICE continuously.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes, keep it reasonably full of both fuels as much as possible. Ask the drivers who spent 3 hours to travel 12 miles in Honolulu yesterday trying to avoid a possible tsunami if having enough fuel during an emergency is a good thing.
    Fuel maintenance software will run the engine (ICE) to keep the fuel from going bad if you don't use enough in time. It's rare to see reports from Prime owners but longer range phev's like the volt, clarity, etc dealt more with this.
    BiomedO1 and ETC(SS) like this.
  12. ETC(SS)
    7,312
    THAT was timely 'eh?
    TWO fuels are ALWAYS better than one.
    I learned that lesson the easy way while dodging Hurricane Hugo in Charleston in 1989.
    I gambled and went South in US-17 based on a WAG from our weather-guessers, and enjoyed a beautiful sunset in Jacksonville.
    MOST people went NW and many became gridlocked on I26 - and had a less enjoyable evening.
    It will not cost you much to keep your tank full and go on a scenic drive every now and then enjoying Hawaii's natural beauty.
    NOT doing so could be expensive!
    Tsunamis are not the only reason to bug out......
  13. BiomedO1
    4,019
    2,109
    SacTown, Ca
    While I agree with you, OP is on an island and keeps the traction battery topped off. There's a lot of stop n go traffic over there. The fact that they are asking this question, tells me that they don't know how the car operates, so I was just trying to keep it simple. FWIW; what does a gen5 do if the battery is more than 80% SOC and you try to put it into charge mode?
    They can burn down the traction pack a bit by blasting the AC and taking it out of ECO mode.
  14. pasta4breakfast
    113
    Anaheim, CA
    2020 Prius Prime
    Based on a couple of drives in nice weather with my OBD scanner plugged in, it only took about 6 minutes in HV mode at 60 mph to get the engline coolant temp up to 190-195 degrees F. When I drove it on the highway for over 40 minutes in HV mode, it still never got above that.
  15. Mendel Leisk
    41,824
    Is it enough to just have coolant temp plateau though?
    our ‘10 is not a plug-in (obviously), but similar situation, we’re both retired, nowhere we have to be daily, but with various obligations and appointments there’s invariably a decent length drive once a week on average. Sometimes more, sometimes less. Which keeps the engine, and brakes and whatever, happy.
    pasta4breakfast likes this.
  16. bisco
    52,286
    o/p has left the island
  17. Mendel Leisk
    41,824
    Tribe continues to debate, undeterred
    #17 Mendel Leisk, Jul 31, 2025
