Home Solar
Discussion in 'Environmental Discussion' started by bwilson4web, Nov 24, 2024.
  1. bisco
    51,256
    george washington got off easy
  2. Trollbait
    12,380
    Same mindset that toppled the Joshua tree and that balanced boulder.
  3. John321
    John321 Senior Member
    1,393
    1,363
    Kentucky
    Look at this video of a California arsonist being stopped by hikers and arrested recently for setting a wildfire on a popular trail, believe it happened yesterday:
    what is this arsonist motivation - what in the world is he thinking?
    #123 John321, Jul 16, 2025
  4. bisco
    51,256
    i suppose there is some type of mental illness issue going on
  5. frodoz737
    frodoz737 Top Wrench
    4,573
    2,455
    33
  6. Trollbait
    12,380
    "going on"?
    There's always been an issue with mental illness and other behavioral issues. It's just that we hear about all incidences happening across the country and the other side of the world with little effort on our part these days.
  7. bisco
    51,256
    i don't doubt it. and i think addiction plays a big part in it as well
  8. tochatihu
    tochatihu Senior Member
    9,593
    3,703
    Kunming Yunnan China
    2001 Prius
  9. bwilson4web
    16,042
  10. T1 Terry
    T1 Terry Active Member
    778
    412
    I hope they have improved both the unit itself and where it's mount in regards to the DC to AC mini inverters.
    The only Australian solar panel manufacturer, Tindo in an Adelaide South Australia suburb, ended with many containers full of their early 250w panels, purely because the micro inverters failed. The systems were under the 25 yr warranty Tindo offers with their system installs, but to reduce the losses, they removed the 250w panels and replaced them with higher output panels and the system owners only had to pay the make up cost between what they paid for each of the original panels and the supply only cost of the new bigger panels.
    I bought a lot of these 250w panels for $100 aud, they still work faultlessly even though they were 10 yrs old.
    Made for building a fairly cheap and reliable off grid system on two of my motorhomes and the house.
    All gone now, lost one motorhome when the workshop burnt to the ground, the second when the house and motorhome burnt to the ground ..... gotta find time and the weather to cooperate to fit a system on this latest 31 ft motorhome .... no, none of the fires were related to solar or lithium batteries, the grid connection meter box on the side of the garage at the house went up, the motorhome was parked between the garage and house and the wind was blowing across the river, pushing the garage fire onto the fibreglass panels on the motorhome, the diesel fuel tank on the other side of the motorhome caught fire and the wind pushed the fire onto the house.
    The first motorhome, sadly, was in the workshop because I was doing an oil charge and planned to finish it in the morning so we could head off for a 3 mth holiday that afternoon ..... I believe that one was arson, robbed the place and burnt it to the ground to hide any evidence, we were already supposed to be on the road that morning, so we wouldn't have known about it for at least a few days ......
    T1 Terry
  11. bwilson4web
    16,042
    Bummer. I understand @hill had a fire problem with a renter in Nashville.
    Looking at my production for July 1-30:
    • Assembling parts for solar linked J1772 adapter - this will change the EV charging to the solar panel output minus 1-2 A for the house load. Perfect following load that matches the solar panel output. This should reduce battery in-out loss and over generated load to grid.
    • Two new fire and carbon monoxide detectors - one for attic and the second the hallway. Just too darn hot after 10 AM.
    • Plan to install lightning rod higher than the solar panels - told not necessary, I'm a belt and suspender engineer and the best way to motivate me is to tell me not to do it. Plus all the news stories about lightning strike injuries and fires.
    My roof has 400 W panels with 300 W micro inverters mounted in the air gap under the 16 panels. This gives a peak 4.8 kW during the summer. The 13.5 kWh storage battery is mounted under the shadiest eave and is less than 1/2 the peak, daily production, ~30 kWh. charging the EVs is my buffer to avoid over charging the battery and dumping excess into the grid.
    #131 bwilson4web, Jul 31, 2025 at 7:56 AM
  12. T1 Terry
    778
    412
    That is sort of the plan when the new house is built, or when we find one somewhere else that we like that is for sale. DC via the DC section of the CCS 2 in the MG4 to give me 51kwh LFP storage and the 7kw V2L back to the Victron inverter/charger to top up the 20kwh house battery when/if needed and supply the house ..... when we use the car, the 20kwh house battery will supply the house battery and the solar will revert back to being fed through the 250/100 solar controllers to charge the house battery ...... and I'll probably plug one of the other MG4s into the system if it's not just a run to the shops.
    The V2L has worked excellently with this Winnie 31 ft motorhome when free camping in the freezing cold (well, by Aust standards, dropped to -2*C one night) and kept all the 240vac appliances, water heater and roof top rattler on heat cycle running for 3 consecutive nights without needing to recharge ..... and was still above the 20% minimum that the MG4 cuts the V2L off.
    T1 Terry
