Prius HV Battery Dr.prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 123omari123, Jul 31, 2025 at 8:26 AM.
  1. 123omari123
    123omari123 Junior Member
    30
    Georgia,Tbilisi
    Can anyone tell me in short is this stats normal or does my HV Battery have any problem?
    First screenshot > engine is not turned on. Second and third screenshot > Engine turned on and then A/C, headlights turned on:
  2. Tombukt2
    12,321
    2,177
    So with the AC and headlights turned on you're just sitting there in the parking lot the engine running AC on heads don't really matter. And I'm assuming you're in the red or the pink? On MFD?
  3. bisco
    51,256
  4. Brian1954
    Brian1954 Senior Member
    1,868
    736
    South Central PA, USA
    I am curious why you are asking. Do you get any warning lights on the dash?
    The third Dr Prius screenshot with the AC turned on shows a voltage difference of 0.41 volts when the hybrid battery is discharging at 12 amps. That is a sign of a hybrid battery that could have problems. The trouble code P0A80 will be activated when the voltage difference between battery blocks is greater than 0.30 volts for a certain period of time. Toyota does not say how long that time peroid is.
    What year is your, Prius, and how many miles?
  5. 123omari123
    30
    Georgia,Tbilisi
    I didn't understand what do you mean?
    Because I think my HV battery discharging fast during driving, and in the city it often shows 30 mpg. I think resistance is very high, am I write or not? especially on 5fth module. Can you tell me what are these three temperatures?
  6. Brian1954
    1,868
    736
    28 milli-ohms on the 5th battery block is not a concern for me. I would be concerned when the battery block resistances gets to 30 milli-ohms and higher.
    There are three battery temperature sensors located along the battery pack. Sensor #1 is located closest to the end of the battery where the cooling air is forced into the battery for cooling. Sensor #2 is located at the center of the battery pack. Sensor #3 is located near the end of the battery farthest from where the cooling air is forced into the battery. The battery temperatures shown in the screenshots look fine to me.
    To get a better idea of the health of the hybrid battery, you need to be driving the car and look at the Dr Prius data when you are using maximum acceleration. The discharging current of the battery will increase to 50 to 80 amps. Then, look at the voltage difference value to see how high it gets.
    The other way is to pay the Dr Prius fee and run the Life Expentancy Test.
    What year is your Prius, and how many miles?
    123omari123 likes this.
  7. Grit
    Grit Senior Member
    6,480
    4,201
    Wilkes Land
    The 3 snap shots looks normal and are not conclusive evidence of battery life. It would be like showing 3 still images of a heart sonar sonar view. You want to actually see the video capture of the heart beating for a minute under various stress levels
    #7 Grit, Aug 1, 2025 at 12:51 AM
  8. Carall
    Carall Member
    275
    75
    Harrisonburg, VA
    You need to restore the capacity in your battery before it's too late, if the mileage is not too high.
    You're from Georgia, you should understand russian.
    This video shows how to do it, in this part (part 1) and in the second part (part 2).
  9. 123omari123
    30
    Georgia,Tbilisi
    2010 , 160k mile. What will be abnormal, if discharging current will be more than 80 amps during driving? and what will be normal voltage difference at this time too?
    Yes I'm from Georgia but I know english better :) , Thanks for info, I will show others who knows Russian.
