Red Triangle-No OBD2 code?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Longinus876, Jul 30, 2025 at 10:32 PM.
  1. Longinus876
    Longinus876 Member
    105
    Long Island
    Got the RToD but no obd2 dtc. What the heck is that about???
  2. ChapmanF
    17,479
    Most often it's about the scan tool you used to try to read the DTC. Not all generic scan tools are able to show you the DTCs that cause the triangle to light.
    Toyota Techstream on a Windows laptop definitely can, and so can some of the alternatives reviewed in this thread:
    Gen2 OBD2 app review | PriusChat
    TL;DR the Autel MaxiAP 200 is a choice that gets a lot of love in that thread.
    If the triangle only flickers briefly as you swing around corners, check the engine oil.
    Brian1954 and PriusCamper like this.
  3. PriusCamper
    PriusCamper Senior Member
    12,134
    4,923
    Pacific Northwest, USA
    What app are you using? Or is it an old handheld device? Also you can have problems triggering a red triangle for the brakes that won't show up on most error code reading apps and you have to clip two pins together in obd2 port to read and those error codes via blink codes. I think @ChapmanF above has some links for how to do that. Or just do a google search with these keywords "priuschat read clear blink codes"
  4. Brian1954
    Brian1954 Senior Member
    1,867
    736
    South Central PA, USA
    Back on March 12,2025 you reported having the red triangle and another warning light in this post, https://priuschat.com/index.php?posts/3522267
    You were given the same advice about needing a more capable scan tool to read the trouble codes.
    Did you ever fix the problem that you were having back in March? Is this new thread just a continuation of the problem that you first reported in March?
    #4 Brian1954, Jul 31, 2025 at 2:07 PM
    PriusCamper likes this.
  5. ChapmanF
    17,479
    It's right on the PriusChat wiki: Blink (a/k/a Flash) Codes – How to. | PriusChat
    You can get brake system codes that way (and several other systems). But, generally, codes that light the red triangle, you can't. You need a capable scan tool.
    #5 ChapmanF, Jul 31, 2025 at 3:36 PM
