seeking assistance troubleshooting intermittent brake warning c1241, c1256
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by deadmandave, Jul 30, 2025.
Tags:
  1. deadmandave
    deadmandave New Member
    Portland or
    Greetings,
    My 2009 Prius has a very intermittent brake issue. maybe 3 times it has done the following:
    "Brake" light on dash illuminates, ! Abs shows up on the touchscreen and a loud alarm is sounding.
    This is resolved by a shutdown and restart. However one time there was no safe area to pullover and after a few minutes of driving with this alarm, brake power was reduced but not gone altogether.
    I took the car to a shop to run techstream and they found c1241 and c1256 and quoted 2600 to replace the brake actuator.
    The brake actuator acts normal at all other times imo. It runs for a few seconds on startup and when the brake pedal is depressed then it holds pressure and won't run again until a few minutes later. brake pressure is consistent and trouble codes/lights are not a common experience.
    I've checked what Ive thought of or what's easy,
    Brake juice is full
    Brake pedal switches are within spec
    12v battery is charged and healthy
    Engine ground is good
    This car has 130k miles. Had a new hybrid battery put in last year (maybe that's when the issue started?)
    Often the display screen is restarting (annoying yes. Related?)
    Possible water damage in the car? Slight rust/corrosion on some components in engine bay
    W hat else can I check before replacing the actuator, or should I just replace it? Abs module ground? Loose connections?
  2. Tombukt2
    13,867
    2,520
    I'm going to have to guess a used actuator maybe? Because the 56 ending code is pressure in the system pump or accumulator..... Pressure issue .
  3. ChapmanF
    19,038
    I would lean toward troubleshooting the C1241 first: inadequate electrical power getting to the brake components.
    Electrical power is needed to keep the pressure up, so having a second code about the pressure doesn't have to mean something else is wrong too.
  4. deadmandave
    Portland or
    I agree that the low or high voltage could cause a drop in pressure.
    Any advice into how to troubleshoot the c1241?
    We bought this car used with 115k miles on it. Not sure if the accumulator was ever replaced but my gut feeling is that it's original.
  5. Tombukt2
    13,867
    2,520
    So the question remains is your power to the brake system stable your 12 volt is it worth a darn . This is important in the Prius this can mess everything up you'll be chasing $1,000 parts and only need a $300 or less battery so.
  6. ChapmanF
    19,038
    C1241 is a code about the electrical power reaching the brake hardware. I'm not saying it can't ever have to do with the 12-volt battery, but (especially if you get the code when the car is READY and the power isn't coming from the 12-volt battery) it can just as easily be about wiring anywhere on the path to the hardware under the hood.
    The troubleshooting steps are in the repair manual under C1241.
    Toyota Service Information and Where To Find It | PriusChat
    There should be threads about it here if you search.
    If I remember right, the gen 2 skid ECU is structured as a redundant pair of systems that monitor each other, and have their own separate electrical supply connections, and the INF codes for C1241 help to tell you which system was detecting a weird voltage reading for the other.
  7. Tombukt2
    13,867
    2,520
    But the brakes run on the 12 volt battery not the HV or I guess when ready they can run off the little black box and the not 12 volt because the DC to DC doodads making ya 14.5 as long as cars on. Probably not a superpower hog like the headlights I guess.
  8. ChapmanF
    19,038
    Right, nothing in the car is running off the 12-volt battery when the car is READY. Because the DC to DC doodads.
  9. Tombukt2
    13,867
    2,520
    Maybe animal chewing . Holey Jesus . And wer they chewing the whole dash etc is coming apart I less extremely lucky . Verify . And I move everything to another chassis probably . We ain't doing that
  10. deadmandave
    Portland or
    Thanks. Good info.
    I will begin troubleshooting per the repair manual. After a quick read thru of the c1241 diagnostic steps, one of the steps is to test voltages and grounds on the skid ECU.
    Looking thru the manual about the skid ECU, it's removal instructions are to first remove the steering column.
    Do y'all know if it's possible to reach these connectors for testing, without removing the steering column?
    I'll report back after I have a chance to get in the car.
    Thanks again.
  11. Tombukt2
    13,867
    2,520
    I've had the skid control hanging without having the steering column out it's a pain in the but it can be done.. I'm not sure you need to take it out to get it to power conn.
  12. deadmandave
    Portland or
    Quick update, I was able to get tech stream running and connected. I wanted to look at the ff data from the c1241 code to see if I could sleuth anything out...
    A couple things were interesting, it listed voltage of the accumulator at the time of error as 3.29 which seems fine so not sure what low or high voltage it was registering but it probably wasn't the accumulator.
    The other interesting part that leads me to believe the c1241 code is unrelated is the vehicle speed at time of error was 0. Whereas when the c1256 error appeared it happened when the vehicle was in motion.
    So I think it's safe to say the accumulator did have an error and it would be worth replacing.
    Anyone know where to find a new accumulator for the gen 2? I can find rebuilt, used or buy from the dealership ($2200). A local shop will replace the accumulator with an oem 4 year warranty part for 2700 installed.
    Would possibly consider doing the replacement myself but want a new part.
    Thanks again
