Alarm keeps randomly going off. Help
Discussion in 'Gen 3 Prius Main Forum' started by Zradub, Oct 5, 2020.
Tags:
  1. Grit
    Grit Senior Member
    6,566
    4,223
    Wilkes Land
    Since we don’t own the car and haven’t armed the alarm itself with our own fingers, we’re just speculating how a quick fix would have entailed. If my neighbor or tenant that had a alarm that goes off randomly, I’d yanked the negative lead and say all good because it would annoy the hell out of everyone.
    BiomedO1 likes this.
  2. BiomedO1
    3,119
    1,656
    SacTown, Ca
    The horn is under the hood; the alarm control box is usually under the dash board. If you consider disconnection the horn a FIX - then it's fixed. If you try to use your panic alarm or expect the alarm to stop a car thief - that isn't going to happen - No more alarm or flashing lights.
    ASRDogman likes this.
  3. Grit
    Grit Senior Member
    6,566
    4,223
    Wilkes Land
    Let me be blunt. He most likely pulled the power lead going to the alarm horn. It won’t make any audible sounds anyMore.
