MaH and household batteries
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Aug 1, 2025.
  1. cyberpriusII
    1,157
    1,833
    Hyampom
    Sick of leaking alkaline batteries. I gave up on Duracell several years ago. Have mostly used top of line Ray-o-Vac or AC Delco. Still some leaks, but mostly not as bad.
    Don't recommend I get rechargeable as for several reasons they don't work for me.
    But just purchased 32 lithium metal AA. I had a choice, $1.21 a battery for 3000 MaH or $1.44 each for 3500. Went with the 3500. Bevigor brand, or something like that.
    Meh, not a lifechanging question, just curious was the 3500 the better choice. Seemed I might get an extra hour or few out of them and since we lose power frequently, seemed like they might mean somewhat less hassle.
    Guess I am looking for a break even point, if you know what I mean. In other words were the 3000 and the 3500 basically the same price considering the 3500 is a little more, but will last a little longer so less swapping out depleted batteries.
    Yes, I did scan the web, but lots of conflicting info. Wow, Reddit forums are fun -- not.
    kris
    #1 cyberpriusII, Aug 1, 2025
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    Lithium metal cells are known for holding a steady voltage and current right up to exhaustion. They are often used in portable electronics which might malfunction given the steady voltage drop of alkaline cells. If you know the operating current of the particular appliance you can estimate about how long the battery or batteries will last. The higher mAh cell will usually last longer. And you're right, they won't leak
    cyberpriusII likes this.
  3. ChapmanF
    18,486
    3000 mAh ÷ 1.21 dollar = 2479 mAh per dollar.
    3500 mAh ÷ 1.44 dollar = 2431 mAh per dollar.
    The 3000 mAh are priced better if all you care about is how much energy you get per dollar you spend.
    If it would please you to get the 17% longer life before having to replace them, or to contribute slightly fewer old cells into the waste stream, that might make the 3500 mAh the better deal for your purposes.
    cyberpriusII and AzWxGuy like this.
  4. ETC(SS)
    7,331
    They don't work for MOST people.
    That's why most first responders don't use them....even the military.
    EXCEPTING for the $$$ Li-Ion flashlights everybody is carrying these days.
    I can't tell you what my company uses (it was ray-o-vac last time I ordered some) because I don't care what they use, and I dang sure don't USE what they use.
    I use Energizer Max because (a) I can get them everywhere and (2) because they work.
    At 0200 in some remote town where they roll all the sidewalks up at 2100 I don't have time to deal with batteries.
    I have a recycle bin in my office for dead alkaline (and other) batteries but it doesn't get used much.
    Too much paperwork.
    I gather them in my bin and dump them at the recycle drop at a work center or on a military base.
    RECHARGABLE cells can (and SHOULD) be dropped off at most of the big-box home improvement places.
  5. cyberpriusII
    1,157
    1,833
    Hyampom
    Hey folks.
    Thanks for putting up with my battery banter.
    Great price breakout, Chap.
    Considering my feeble math skills, it is a wonder how I managed a master's in the sciences...well not really; it took a lot of hard work and more than a little luck and prayers.
    Start new job Monday, so won't have much time to make irrelevant comments here.
    Not looking forward to this position, but needed something after losing my "dream" job to DOGE.
    Love Engergizer batteries, but trying to cut some costs.
    As some may know, live out in the forests of Oregon, we don't take power or phone service for granted and can lose electric for a couple of weeks while being stranded with the only way to town being a cold, wet footslog of several miles
    kris
    #5 cyberpriusII, Aug 2, 2025
