Front Wheel bearing replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ccna101, Jul 26, 2025.
  1. Tombukt2
    12,349
    2,183
    Yep clean as hale should have take about 46 min to get to first picture . I'm using cheap TRQ and lesser. Some w 100K.on the lesser no issues yet . They're so quick to change I could do it every 8 months . But I'm glad I don't have to.
    ccna101 likes this.
  2. ccna101
    ccna101 Member
    118
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Finally received the new axle nut, reinstalled everything and all is good. I have to massage the brake shield to keep th squeaking noise down but other than that, it is a decent task and I will not replace the driver side and will keep the spare wheel hub...
    I still think TOY is screw up of making the bearing fail so early : among the ABS, Hybrid, bearing, MFD, dash display, ... ... this is a very complex and high maintenance car !! without DIY, I dont think normal driver can take care of it ...
    I think I dodge a bullet since this car is basically live in FL and CA ... In MD area where I also live, I am sure it will be a nasty fight to get them -unbonded- .... and with the humid, snow and salt , ... man oh man ... I feel for my people in the east coast :)
    EV-
    #22 ccna101, Aug 2, 2025 at 12:20 AM
  3. Tombukt2
    12,349
    2,183
    Mine fall apart md to NC areas don't even have to hit em hard
  4. Mendel Leisk
    40,707
    Wonder why, maybe a bearing style that sacrifices longevity for lower rolling resistance (mpg brownie points)?
    ccna101 likes this.
  5. Mendel Leisk
    40,707
    Small mercy: cars in the rust-belt completely implode from rust in a decade, head for the wrecking yard, taking the near-failing wheel bearings with them.
