12.4v at battery, 11.8v in car, no ready
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LKasdorf, Aug 2, 2025.
  1. LKasdorf
    LKasdorf Junior Member
    77
    24
    Waterford, VA USA
    My son's 2005 Prius is doing something odd.
    It is acting just like a low 12v battery, and the maintenence console as well as a voltmeter in the cig lighter show 11.8 - 11.9 v.
    The car will not enter the ready state- i.e. lots of lights on, and if you try to put it in D, you get red triangle.
    The strange part is that the 12v battery is in excellent condition. Reads 12.4v at the terminals (not 11.9). I checked it on my bench with a load tester and an Ancel battery tester. Execellent condition.
    So- how can the battery show 12.4, but only 11.8 be getting to the guts of the car? I cleaned the battery terminals very well and used contact cleaner on the 2 white plugs on the battery harness.
    I am puzzled.
    BTW, it doesn't show any battery or engine error codes in Dr Prius. I will connect Techstream and see what it shows.
  2. JC91006
    JC91006 Senior Member
    16,780
    8,575
    how old is the battery? You need to read the codes, there should be a reason to all the issues and lights.
    Brian1954 likes this.
  3. bisco
    52,069
    might be worth trying another battery, or a jump with that one disconnected
  4. pasadena_commut
    pasadena_commut Senior Member
    2,694
    804
    Southern California
    What state is the car in when 12.4 V is measured at the battery?
    I'm assuming "off".
    What state is the car in when 11.8 V is measured at the power outlet (it is not a lighter) under the dash?
    Must be "IG-ON" or "ACC", otherwise the outlet has no connection to the battery.
    How much current is pulled out of the 12V battery at off?
    Roughly 25 mA. Is that enough to reduce the open circuit voltage? Not significantly.
    How much current is pulled out of the 12V battery at "IG-ON" or "ACC"?
    Several Amps with "IG-ON" pulling less than "ACC". With "ACC" if the cabin blower is on drains over 20A are possible. Is that enough to reduce the open circuit voltage significantly? Yes.
    Ever look at the voltage on a regular car when the starter is used? Down to nearly 9V is OK on a good battery. That is a 3V drop due to a very large current. Here it is only 0.6V.
    The 12v battery voltage is not the problem (although a loose or missing ground somewhere could be). The OP needs to get either techstream or a Prius compatible code reader like the Autel AP200 and read the codes. (There is a thread somewhere discussing these devices.)
    Edit: Gen2 OBD2 app review | PriusChat
    It wouldn't hurt to put the 12V on a charger in the meantime. Since the car isn't running it cannot charge it up itself, and the OP is likely to run the battery down further diagnosing this issue.
    #4 pasadena_commut, Aug 2, 2025
  5. Mendel Leisk
    41,628
    Did the Ancel show it's as-tested CCA?
  6. PriusCamper
    PriusCamper Senior Member
    12,840
    5,203
    Pacific Northwest, USA
    How old is the battery? It is NOT in excellent or even good condition!
    Anything below 12.7volts with car off is either a discharged battery that needs to be charged with a legitimate charger or a battery that needs to be replaced.
    Basically this 12v doesn't have enough power to turn on the computers, nor turn on the high voltage relays.
    If you were to connect this battery to a regular car and try to start the engine the battery wouldn't be able to even turn over the starter motor.
  7. LKasdorf
    77
    24
    Waterford, VA USA
    I work on batteries- this one is perfect. I took it out, put it on the bench, load tested it, checked with battery tester. All good.
    Like I said, 12.4 at the battery and 11.8 everywhere else!
    The voltage at the fuse box is the same as at the battery- a solid 12.4v, which is plenty. But the cig lighter outlet reads 11.8 and the service mode display says 11.8.
    I will try to get my techstream computer going.
  8. LKasdorf
    77
    24
    Waterford, VA USA
    The ancel tester showed 330 CCA on a 325 CCA battery.
  9. JC91006
    16,780
    8,575
    I'm confused why you started this with a possible bad battery problem, when you work on batteries and have determined that not be the issue.
    The answer is just getting the codes, techstream is not needed, many scanners can do this function.
  10. Hayslayer
    Hayslayer Active Member
    415
    243
    You
    Where do you get your information?
  11. ChapmanF
    18,300
    Toyota's repair manuals often have notes like this:
    Which, of course, means that below 11 V it's worth taking the time to charge it better so it doesn't have to be on your list of suspects while you're troubleshooting. It doesn't mean you're sure to have problems at 10.9 or anything.
    Some of the car's ECUs will start logging "hey, did you notice the voltage got low?" codes, generally at around 9.5 V. They don't stop working at that level, they just do their jobs and also log the code so you know.
    The times I've had real trouble making a Prius READY have been below 8 or 9 volts.
  12. Mendel Leisk
    41,628
    That’s borderline, at least in my uneducated experience. An “in the pink” battery usually shows tested CCA good bit above spec, say 370ish in this case.
    seems borderline and heading down.
  13. bisco
    52,069
    rodente?
  14. Paul Gregory
    Paul Gregory Senior Member
    2,177
    576
    Alberta
    2024 Prius Prime
    XSE
    Funny things can happen with poor connections. I'd start by tracing the connection from the battery to the main terminal. Use something that draws a bit of a load if possible.
    Danno5060 and Mendel Leisk like this.
  15. LKasdorf
    77
    24
    Waterford, VA USA
    I am trying to locate a VCI cable so I can run Techstream. I have 2 of them- somewhere in my stuff... anyway, I ordered a third.
    In the meantime, here is the update.
    I have swapped in another good 12v battery- same symptoms.
    Lots of lights, then if you try to put it in drive, red triangle and a constant beep.
    Dr. Prius gives me a P0AA6 code - which I can clear, and the triangle goes away, but still won't work.
    I've seen lots of info about this error- I need techstream to get the subcodes to see if it is a leak inside the battery, or an inverter problem, or whatever. Apparently there is a 14v regulator module that can cause this?
    Also- what is the box next to the 12v battery? I have a parts car, so I could swap that.
  16. JC91006
    16,780
    8,575
    Ahhh finally a clue P0AA6. This is your problem, not the battery
  17. BiomedO1
    3,777
    1,969
    SacTown, Ca
    The 11.8 VDC is normal, that's your car systems drawing power from the aux. battery. P0AA6 indicates a problem with your traction battery. Check the safety interlock, inverter coolant pump, AC compressor and fuses. Your DC-DC converter isn't operating.
  18. Prodigyplace
    12,593
    11,791
    Central Virginia
    I was going to suggest checking both ends of the battery ground cable.
  19. LKasdorf
    77
    24
    Waterford, VA USA
    Battery terminals, connectors, and ground connection are pristine and the first thing I checked. Thanks
    Prodigyplace likes this.
  20. JC91006
    16,780
    8,575
    The problem is not with your 12v battery. The P0AA6 points to several areas, sub codes like 526, 611, 612, 613, or 614 will help pinpont your issue.
    This could be as minor as a leaking module in your HV battery, or it could be a problem in your transaxle, which is a lot more complicated to fix.
