3D Printed Spoiler for 5 gen prius
Discussion in 'Gen 5 Prius Accessories and Modifications' started by priusasa, Jun 23, 2025.
  1. priusasa
    priusasa Member
    104
    53
    2023 Prius
    There is a spoiler for Camry, I like that one and I wanted to make something like that. I printed 8 parts and combined them later. Material is Petg. Also, I will use 3M double sided tape for the bottom part. That's why I made bottom surface area big, because I wanted it to hold the car strongly. I Haven't fully combine yet
    What do you think? Did it even look good?
    Off course aerodynamic is very important but I dont have much information about that and I did not do any simulation test.
    20250623_205929(1).jpg 20250623_210010(2).jpg 20250623_210034(1).jpg prius spoiler.PNG prius spoiler 2.PNG
    #1 priusasa, Jun 23, 2025
    Jayct and Xov’ze like this.
  2. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    Looks pretty sick, do you have any pictures other angles? Side profile and front 3/4s view are important to me when I mod my car
  3. priusasa
    priusasa Member
    104
    53
    2023 Prius
    I will take more pictures during the day. But I need to sand and paint it to get better look.
    Xov’ze likes this.
  4. Blackat
    Blackat Active Member
    479
    342
    Colorado
    2023 Prius
    Limited AWD-e
    Dig it!
    Looks way better than the little lip add on.
  5. Perfectpacman
    Perfectpacman Junior Member
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    Looks way too 'performance' related for the Prius. Not my thing. Sorry
    nukejello likes this.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    IMO it would look better without the winglets(?) at each end. Also, maybe make it wider, front to back, on the actual spoiler, the base looks fine. As it is, the spoiler looks kind of thin (front to back).
    GcinFl likes this.
  7. priusasa
    priusasa Member
    104
    53
    2023 Prius
    yes I was thinking to design wider. Because this is pretty thin. I dont use it by the way, I just put there to see.
    GcinFl likes this.
  8. DreadCatCleo
    DreadCatCleo New Member
    Cincinnati
    2025 Prius
    Are you willing to share the files for these or are they uploaded on any STL sites? It looks pretty sick, I’d like to print it in ABS.
  9. priusasa
    priusasa Member
    104
    53
    2023 Prius
    I didnt finished that project, I just stopped doing it. If you want I can send the scanned data, If you are into modelling
  10. samlevy0515
    samlevy0515 New Member
    United States
    2012 Aqua
    That’s an ambitious print! Joining PETG parts can be tricky—if you haven't already, consider using a compatible adhesive (like PETG-specific glue or careful welding with a 3D pen) along with mechanical reinforcement inside for strength. A wide base with 3M VHB tape should hold well on clean, prepped paint.
