Cleared check engine light by battery disconnect now locked out
Discussion in 'Prius v Technical Discussion' started by steppin, Aug 2, 2025 at 1:18 AM.
  1. steppin
    steppin New Member
    Saturday
    AZ
    I replaced water pump and then removed negative battery cable to clear the code.. now all my warning lights all stay lit up on the dash and it won’t let me place car into drive or reverse.. I have tried reset this several times by same procedure with no luck.. I know I must of re set all defaults and lost communication with computer. Now I can’t even move the car.. how do I get this all synced again?
    51,274
    i think you are going to have to scan for trouble codes to find out why it is complaining
    Mendel Leisk and Brian1954 like this.
  3. ChapmanF
    17,508
    i think what bisco thinks
  4. steppin
    steppin New Member
    Saturday
    AZ
    It had a code .. is why I had to replace water pump
  5. bisco
    51,274
    if you have trouble lights, you have more codes. could be related to the pump or the install.
    use tech stream or autel
  6. steppin
    steppin New Member
    Saturday
    AZ
    Not more codes .. just everything on instrument panel is all lit up and I can’t get into drive or reverse.. it locks me out
  7. bisco
    51,274
    load test the 12 volt, and check the connections, especially negative to ground.
    BiomedO1 likes this.
  8. BiomedO1
    2,887
    1,541
    SacTown, Ca
    Are you getting the green 'ready' lamp? It doesn't seem reasonable that you don't have any more codes and yet the car won't go into gear. Why would the ECU lock you out if everything is READY????????
    Use a better OBD2 scanner....
  9. Air_Boss
    Air_Boss Senior Member
    4,148
    1,162
    New Yawk
    Did you remove and replace the HV interlock when doing the water pump service?
