Cleared check engine light by battery disconnect now locked out
Discussion in 'Prius v Technical Discussion' started by steppin, Aug 2, 2025 at 1:18 AM.
  1. steppin
    steppin New Member
    Saturday
    AZ
    I replaced water pump and then removed negative battery cable to clear the code.. now all my warning lights all stay lit up on the dash and it won’t let me place car into drive or reverse.. I have tried reset this several times by same procedure with no luck.. I know I must of re set all defaults and lost communication with computer. Now I can’t even move the car.. how do I get this all synced again?
    51,278
    i think you are going to have to scan for trouble codes to find out why it is complaining
    Mendel Leisk and Brian1954 like this.
  3. ChapmanF
    17,511
    i think what bisco thinks
  4. steppin
    steppin New Member
    Saturday
    AZ
    It had a code .. is why I had to replace water pump
  5. bisco
    51,278
    if you have trouble lights, you have more codes. could be related to the pump or the install.
    use tech stream or autel
  6. steppin
    steppin New Member
    Saturday
    AZ
    Not more codes .. just everything on instrument panel is all lit up and I can’t get into drive or reverse.. it locks me out
  7. bisco
    51,278
    load test the 12 volt, and check the connections, especially negative to ground.
    BiomedO1 likes this.
  8. BiomedO1
    2,888
    1,543
    SacTown, Ca
    Are you getting the green 'ready' lamp? It doesn't seem reasonable that you don't have any more codes and yet the car won't go into gear. Why would the ECU lock you out if everything is READY????????
    Use a better OBD2 scanner....
  9. steppin
    steppin New Member
    Saturday
    AZ
    Yes have green ready light.. and green light at start button but when I put into any gear it immediately turns amber and locks me out .. once I set parking brake again that light will turn back to geen
  10. Air_Boss
    Air_Boss Senior Member
    4,148
    1,163
    New Yawk
    Did you remove and replace the HV interlock when doing the water pump service?
  11. steppin
    steppin New Member
    Saturday
    AZ
    Yes .. the orange plug
  12. steppin
    steppin New Member
    Saturday
    AZ
    Ya know what.. when I plugged it back in.. I did t know to slide it to the right until it clicks.. seen that on another YouTube video.. everything works fine now… thank you guys so much for your time and input.. these forums rock
  13. bisco
    51,278
    good call AB!
  14. BiomedO1
    2,888
    1,543
    SacTown, Ca
    a better OBD2 would've told you no traction battery power.
  15. ChapmanF
    17,511
    If the orange plug handle wasn't slid to the right, the code was P0A0D for the safety interlock circuit (that handle is part of that circuit). So reading the code would have identified the issue with no need to guess.
  16. steppin
    steppin New Member
    Saturday
    AZ
    Ok thx… that would of been my next move.. appreciate you guys
