Auto-folding mirrors and turn indicators part numbers
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Hammersmith, Jun 24, 2023.
  1. KMO
    KMO Senior Member
    1,897
    648
    Finland
    2023 Prius Prime
    Basically all the world apart from North America uses the UNECE regulations I was referencing including Japan. So EU and Japanese Prius lights are the same, I believe.
    Maybe the side signals on your 2010 were a brighter US spec.
    Or maybe they're faulty, or some sort of wiring problem. If you're not being hyperbolic with 'can barely tell it's lighting up at all,' maybe check the voltage at the connectors.
  2. Hammersmith
    Hammersmith Senior Member
    2,228
    2,231
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm not saying this is the reason, but I wired my lights exactly like the wiring diagram, which means I effectively tapped into the violet and pink wires before they went into the PDBA and became the yellow and blue wires. The biggest reason I stuck to the wiring diagram was my OCD/desire to make future service easier, but I also wasn't absolutely certain if the PDBA did anything to the signal. After all, Toyota could have easily run the wires back to the rear light straight from the junction connector, but they chose to run them to the PDBA for some reason.
    It's remotely possible there are some resistors in the PDBA that are reducing the strength of the signal for some reason. You're already working with K21 for the folding mirrors, maybe try switching to the violet and pink wires to see if that makes a difference.
  3. jtchinoy
    jtchinoy Member
    89
    37
    Hayward, California
    2024 Prius
    The US Prius gen 3 and 5 don't come with side blinkers, so there isn't a US equivalent regarding brightness for them.
    After cleaning up the wiring by putting it through the proper connectors the blinkers look brighter during the day. May have been poor connections when they were barely twisted together.
    Just need to troubleshoot my left BSM signal then everything will be back to normal except the power folding which I'll finish later. Might have to run a new wire if there's a break in the positive wire, but hopefully it's just a small section I have to rewire.
  4. jtchinoy
    jtchinoy Member
    89
    37
    Hayward, California
    2024 Prius
    @Hammersmith Looking over the write up you gave, I realized I haven't grounded anything noted to need to be connected to a ground. If it's noted to need to connect to ground, even if the ground wire exists, did you mean to ground it to another ground wire or to a chassis ground?
    Example:
    O9 - 9 - Ground - white/black - connect to a ground - I think this already exists
    I think if I ground the b/w in the driver side passenger well, it might fix my BSM indicator error. I've been troubleshooting it in my spare time and as far as I can tell all of the runs have no breaks, but the error is persisting.
  5. jtchinoy
    jtchinoy Member
    89
    37
    Hayward, California
    2024 Prius
    Despite a few hours of trying to figure out why I can't complete a circuit with the wire from the BSM sensor to OR2, it seems wiring in the folding mirror connections to OK2 and the controls made it happy and my BSM error's magically gone.
    Just need to wire the driver folding mirrors to K21 and tap the passenger side to those. Unfortunately that's the hard part. hah.
  6. jtchinoy
    jtchinoy Member
    89
    37
    Hayward, California
    2024 Prius
    Power folding is up and running! If you remove the lower section of the dash and knee impact guard bar, then disconnect the ECU from the bracket it becomes pretty easy to work under the dash. K20 and K21 grounds were already there, so I just needed to do the power mirror connections and tap them with the passenger side.
    It's pretty cramped in the K21 harness so I removed the first piece of tape keeping it together.
    Glad I finally finished this project and happy I did it!
    tat2boy and otatrant like this.
  7. Hammersmith
    2,228
    2,231
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry I disappeared for a bit. Life got in the way of regular posting for a while there. I suspect you'll enjoy the new features. I think you can understand why I don't recommend the project to most people, but they sure are nice if you're willing to commit to a whole lot of work to get them. I'm pretty sure we're the only two people in the US and Canada that have them.
  8. jtchinoy
    jtchinoy Member
    89
    37
    Hayward, California
    2024 Prius
    @Hammersmith I absolutely love them and I'm really grateful for all your help getting me started!
    If I were to add tips, it would be:
    Tape all the new wires together so they have more support when routing them.
    You possibly can save the pins from o9/n9. I pushed one out and it looks the same as what we added.
    I agree doing K21/turn signals taps into the relay should be done together. just remove the entire lower dash and dismount the ECU. Saved so much time.
    Replace the new mirrors with your originals as their reflections are inverted as well.
    Buy a cheap multiplex controller from japan to take the folding controller PCB and buttons and transfer to your own.
    Video of mirrors in action:
    otatrant and tat2boy like this.
  9. Hammersmith
    2,228
    2,231
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Regarding taping wires together to route them easier:
    In my case, I actually pulled the door harnesses, unwrapped them, added the new wires, and taped them back together again. And for crossing the dash, I put the new wires into braided wire loom, then ran that alongside the main dash harness and secured it to it with zip ties. Made for a super neat finished job, but the effort vs. result means I wouldn't recommend it to any but the most OCD-types.
    Also, tesa tape for the win.
    otatrant likes this.
  10. Hammersmith
    2,228
    2,231
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    A couple months back, I decided to try adding front side radar to my Limited w/Adv Tech. It hasn't gone well.
    Physical installation was a breeze. Maybe two hours to pull the bumper cover, install the sensors, and replace the bumper cover. I got warning lights, but that was expected as the sensors have their own ECUs that need to be programed. That should have been easy: plug in GTS+, program the ECUs, then calibrate them. And that's when we hit a brick wall.
    GTS+ has a bug with these sensors and a handful of cars(gen5 Prius, Grand Highlander, TX, RX) and it can't program them. There's a workaround, but it involves a Toyota department called TAS(Technical Assistance System(?)) that can only be used by dealerships.
    So I went to the larger dealership close to me thinking they'd have more diagnostic techs and maybe more pull with TAS as they're one of the larger dealership chains in the Rocky Mountain Region. I took them all the info they'd need to do the job, but they went nowhere with it. I got the feeling they never actually listened to me and got sidetracked with inconsequentials. They eventually stopped communicating with me unless I actually went to the dealership and asked, but they never had any new info.
    After about three weeks of nothing happening, I tried the smaller dealership in my area. By luck, I ended up dealing with the service manager instead of one of the advisors. She actually listened to me and was helpful(about halfway through she jokingly offered me a job - lol). But she had to run the creation of the TAS case through her Field Technical Specialist(basically a high-level tech that works for Toyota corporate and advises dealerships), and he doesn't think they can help as it's against policy to use TAS for any modifications even though they're OEM parts on a car that was designed to use them.
    I even threw a hail mary and reached out to TCCN to see if they could help, but it turns out TAS is only available to dealerships, not independent shops at all.
    So I continue to be stuck for the moment. The second dealership hasn't officially said no yet, but it doesn't sound good. I've got a second hail mary in mind, but it will require a copy of TechStream v18 that isn't filled with malware. If anyone knows of a good source, I'd love to hear. The other option is just to wait until GTS+ is fixed. It's updated about every three months, and the last update was July 1. But I think this bug has been around for quite awhile, so I don't hold out a lot of hope of it being fixed soon. Assuming none of the other options work, I'll probably disconnect the sensors after the next GTS+ update if they haven't fixed the bug.
    It's just frustrating that something so easy has turned out to be so difficult, just because of a software bug. If not for the bug, I would recommend the upgrade to DIYers with Limiteds with the Adv Tech Package. Roughly $500 including parts, shipping, and the cost of 1hr dealership service for the ECU programming to get Front Cross Traffic Alert and Lane Change Assist.
    Julio_E and otatrant like this.
  11. otatrant
    otatrant Active Member
    257
    166
    San Francisco
    2023 Prius Prime
    XSE Premium
    One long shot idea would be to find a Toyota field technical specialist on linkedin, facebook or other social media site to see if they would be willing to help.
    Here is one I found performing a quick search on LinkedIn.
  12. Hammersmith
    2,228
    2,231
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I had some more communication with my service manager this afternoon and she's going to contact TAS directly to see if they'll just send the needed file. I jokingly suggested I hit my trash cans so we can claim it's collision damage. lol
  13. Hammersmith
    2,228
    2,231
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Well, my service manager gave up too much information to TAS and the request was denied. I think if she wouldn't have mentioned it was a modification and just submitted the minimum information it would have worked. So now I'm waiting for Toyota to just fix GTS+. Next update should be in Sep/Oct, so I'll leave the sensors in until then. If they don't fix it in the next update, I'll probably remove them just to get rid of the warning lights. Then I'll try again if they ever fix GTS+(my luck it will be the following update in Dec/Jan when it will be too cold to pull the bumper cover again, and I'll have to wait for spring).
  14. Julio_E
    Julio_E Junior Member
    37
    Michigan
    2024 Prius Prime
    XSE Premium
    Re: this hail mary, just wanted to mention that possibly installing a "best" copy of this software in Linux Virtual Machine (VM) might facilitate your objective. Installing a copy of linux in a VM can help alleviate the malware concerns, depending on how severe they might be. I also googled that some suggest installing it on a 2nd laptop with no online connection. Both the VM software (VMWare or Oracle) and a Linux OS installation (like Ubuntu or others) are free. You probably already know this and there's probably more involved than I know as to why this may not help.
  15. Hammersmith
    2,228
    2,231
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    My biggest problem on this front is that I'm 99% sure I'd have to be connected to the internet to do this job.
    What GTS+ is supposed to do in this case is get the basic information from the car and the new ECUs. It then sends that info to Toyota's computers. Toyota then either retrieves the proper config file or builds a new one(I'm not sure which) and sends that back to GTS+. The tech then uses a different program(CUW+) to take that config file and write it to the new ECUs.
    The bug is that GTS+ is either not properly sending the files to Toyota, or Toyota's computers are not responding like they should be. Either way, GTS+ doesn't get the config file back like it's supposed to.
    So if the problem is within GTS+, I was thinking I could use Techstream v18 and see if it could send the request for the config file. But I've had a couple communications with the dealership(plus a couple comments from TCCN in his videos) and it sounds like Toyota has totally shut down support for Techstream. That means even if I had a legit copy with a real access key(via professional diagnostic subscription), Toyota's computers wouldn't respond to any request made by old Techstream. So I'm back to square one.
    Old Techstream will still work for local stuff(scan error codes, programming of stored options, etc.), but it apparently no longer works when you need to exchange data with Toyota's servers. Only GTS+ works for that now.
