Shaking when ICE kicks in
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Aadilish, Jan 29, 2024.
  1. Aadilish
    Aadilish Junior Member
    DUBAI
    2018 Prius
    Four Touring
    I have a 2017 prius with about 42k miles on it. My wife drove it through a puddle about a couple of months ago. The engine light came on. I was traveling so I asked her to park the prius and drive the other car. When I got back 10 days later I could feel moisture in the floor mats and the check engine light was on. I started the car and drove it about 50 miles and the engine light went away. However, I could feel a shudder/shake everytime the engine would kick in especially if you keep a light foot on the gas.. With a light foot it is a sustained shake. If you accelerate hard, the shake goes away. There is zero shake whe the car is running on electric motor. I have also notices that the shake is minimal when the car is cold. The translation from ICE to electric and back is smooth. I took the car to a local garage. The plugs got replaced, coils are also fine, air filter replaced. They even opened the inspected the transmission damper but no issues were detected. There are no error messages when you put the scanner in. Any idea what might be the cause? Thanks
    51,535
    how is the engine coolant level?
  3. BiomedO1
    3,154
    1,668
    SacTown, Ca
    Check the fuel trims and temperature sensors for proper operations. The CEL should be in your scan tool history, see what code was initially tripped - that may give you a clue to what's going on. Or you may just have a bad tank of fuel - dump some injection cleaner in the tank and see what happens.
  4. ChapmanF
    17,763
    The shaking at moderate load, not at heavy load and not at idle, can be a strong suggestion to clean the small EGR passages found in the intake manifold.
  5. Aadilish
    DUBAI
    2018 Prius
    Four Touring
    Steady no visible loss over the last 2 months
    Steady level. Have observed no reduction.. tx
    Coolant level steady and no reduction observed.
    #5 Aadilish, Jan 30, 2024
  6. bisco
    51,535
    Odd for 42k
  7. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    :coffee:
    A puddle ?
    carpet was wet?
    is the carpet dry now?
    2011 Throwing Codes After Driving Through Puddle | PriusChat
  8. Aadilish
    DUBAI
    2018 Prius
    Four Touring
    Thank you. Have checked plugs, coils and all relevant sensors still the same. As a last resort, am have the ecm looked at for potential transistor misbehavior. Will update ASAP. Thank you for your inputs
    vvillovv likes this.
  9. Aadilish
    DUBAI
    2018 Prius
    Four Touring
    Adeendum: The shaking clearly is on account of engine misfiring at low rpms.. unfortunately it is at the sweet spot where all the gas savings are. If you keep rpms high misfiring disappears ....will update soon. Thanks again
  10. vvillovv
    4,320
    1,508
    NY
    If you are able to post and Diagnostic Trouble Codes specific to your Prius issues, that could help us reading your thread understand, why the puddle and wet carpeting observations lead to the misfire at optimal RPM and disappearing at higher RPM.
    If it's extra work or worry, please don't feel obligated in any way.
    And thank you for updating your thread with what you have already learned.
    #10 vvillovv, Feb 10, 2024
  11. Mendel Leisk
    40,983
    Try cleaning the intake manifold?
    Note, in the attached, Toyota doesn't make any mention of of torque for throttle body hold-down nuts/bolts. FWIW, for 3rd gen the value is 7 lb/ft.
    #11 Mendel Leisk, Feb 11, 2024
  12. Aadilish
    DUBAI
    2018 Prius
    Four Touring
    Hello folks. A very late update. We tried everything but the shaking persisted. About 2 days ago my mechanic closed the airflow for the egr valve and viola the shaking/misfiring disapperead. The car is at 62k miles now. while it's a relief but I am thinking driving with the egr feedback pipe blocked might cause some long term issues? Also since blocking this pipe has solved the problem for now, what do you think the permanent fix could be? Is there some.egr sensor or something that might need replacment? Tx
  13. bisco
    51,535
    that hasn't caused any trouble lights?
  14. Aadilish
    DUBAI
    2018 Prius
    Four Touring
    We have run multiple scan ls but no errors at all. Stopping exhaust gasses from being fed back has solved the problem somehow. Want a permanent fix as now inclined to sell the car and don't want to sell the car to a new potential buyer before solving this issue first. Coils, plugs etc all had been replaced not too long ago.
  15. BiomedO1
    3,154
    1,668
    SacTown, Ca
    Your EGR valve is stuck OPEN. It's suppose to close while idling - mixture too lean.
    fix that, your problem will go away.
    Good Luck.
    PS, use better motor oil and change as recommended. The early clogging is due to poor motor oil quality and possibility poor maintenance intervals.
  16. Aadilish
    DUBAI
    2018 Prius
    Four Touring
    Thank you. Will try the fix you recommended and report back.
    Service intervals are regular and I use the recommended grade Motul oil, so decent quality.
    My wife had driven through a pool of rain water some 2 years ago when this problem started. Could that have caused it?
  17. rjparker
    9,884
    6,092
    It will code with the egr flow blocked.
    Change the egr valve. Problem solved.
    You might want to change your mechanic as well. There is an egr step test run by a scanner that would have identified a sticking open egr valve without opening the hood and certainly before changing plugs, turning a wrench or checking the damper.
    #17 rjparker, Aug 5, 2025
    BiomedO1 likes this.
  18. BiomedO1
    3,154
    1,668
    SacTown, Ca
    I'm pretty sure using the correct OBD2 scanner should've picked up that error. Someone in the UK had a similar issue, but had more than 250K miles - not km on that car. That valve was also suck open and clogged with carbon deposits.
    Driving through a puddle two years and 20K miles ago has nothing to do with this. Any moisture or contaminate would've been burned away long ago, when the engine got up to temperature. Also leaving the car out in the Dubai sun would've done the same.
    I'd seriously consider switching mechanics, things here isn't lining up and this doesn't normally happen to properly maintained cars at this low mileage. If you didn't buy this car NEW from Toyota, could this car be a salvaged car - pieced together from multiple wrecks, using the ECU with the lowest mileage on it?
    Good Luck.....
  19. Aadilish
    DUBAI
    2018 Prius
    Four Touring
    Thank ypu.
    Changed the EGR valve and issue resolved. Took almost 2 years to get to this. But thank God back to driving like a dream. Thanks.for everybody's input.
    bisco and Brian1954 like this.
