Slightly peculiar 12V battery observations
Discussion in 'Gen 2 Prius Technical Discussion' started by pasadena_commut, Aug 3, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,670
    791
    Southern California
    The 12V in our 2007 was charged to full with a Battery Tender Jr. yesterday. Measured at the jump point before charging it was 12.54V (at around 70F). That is around 75% SOC on most AGM tables. This particular charger maxes out at .750A, and in this case after starting it rapidly climbed to .578 A at 13.48 V and then over the next 3.75 hours the current fell to .549 A while the voltage rose to 13.67. This was 2:00 PM and it was starting to get really hot out, so paused until the car was in the shade of the house, restarted at 5:15 PM (12.73V measured right before) and by 6:15 PM it was flashing green (13.57V, .53-.56A oscillating), and at 6:50 PM it was solid green (float) at 13.13V and the current varying rapidly between 0 and 0.6A. I have no idea what the shape of that waveform is.
    Anyway, let it sit overnight and it was 12.69V at 8:15 AM (70F), but down to 12.57 V at 14:24 (at the jump point), it is a hot day and it was at least 85F by that point. It was not driven today. Then a battery test (HF electronic battery tester) was run on the battery in the car. SOH 85%, SOC 100% AH 43 Volt 12.66 Internal R. 8.56 mOhm. Typical for this battery recently.
    So the peculiarities...
    1. Using an IR "gun" thermometer measured the temperature in the car through the 1" gap at the top of a window as 115F. However, the temperature of the battery (gun aimed right at it at close range) was only 105F. The battery was on the north side of the car, so the sheet metal right next to it was not in direct sun. Anyway, there can apparently be quite a substantial difference between the 12V temperature and the cabin temperature for a Prius parked in direct sunlight, with all 4 windows rolled down one inch. Intrinsically - there were no fans going.
    2. Measured voltage and current at battery with UT210E multimeter and found 12.65 V (same as the tester) but only 13 mA. I have only ever seen 25 mA (car inactive for a while) or more (door open or car active). Current test was repeated 2 more times with the same results.
    The second of these is more interesting. Some possibilities are:
    A. Heat affects car and/or battery so less current drawn. Never measured on this hot a day before. Boring.
    B. Heat affects multimeter Again, never measured on this hot a day. Boring.
    C. Recently started turning off the cabin fan before turning the car off. The car somehow knows this even when off and uses less current. Not Boring.
    A and/or B are more likely, but C would be interesting if true. I started turning off the fan because of the observation that under normal operating conditions (car fully warmed up, in D or P) the inverter puts out 14.1V or 13.6V, depending solely on whether or not the cabin fan is going. This is a binary decision, it is 14.1V for any fan speed even though the current used varies tremendously. I figured that if the cabin fan is initially off it should lower the startup current from the 12V battery, in whatever period the cabin fan was working off the 12V battery before the inverter took over, which would be better for it long term. I didn't expect that the fan position would matter while the car was off though. Probably it doesn't, but it would be fascinating if that actually makes a difference.
  2. ChapmanF
    18,251
    Interesting thought. I think I agree with the two observations you make leading in: that the car uses cabin fan status to influence a binary decision about the DC/DC converter output voltage to request, and that the actual cabin fan current isn't binary, but varies tremendously by fan speed.
    I think I would be surprised, based on those two observations, if the difference between fan-off and fan-low, say, had much effect on the current from the battery during the period before the converter output takes over.
  3. pasadena_commut
    2,670
    791
    Southern California
    Whatever states the conventional relays are in for 13.6 vs 14.1 would presumably evaporate when the car turns off - all those relays should fall back to their "no power" positions. That's why that low "off" current is strange. Bistable "latching" relays maintain state when the power is off, but I don't know if they are ever used in cars. However, if they are, the Prius is a likely candidate. One advantage these have is that they take less current to maintain (one) current state than a conventional relay. So while Toyota was massaging out every last bit of lost power to improve efficiency, they might have put these in somewhere. Or not. If not and the observation is due to the fan state it would have to be something very strange, like a FET being "on" for the 14.1 V state, even when the car is off, and that enabling around 12 mA of current draw.
  4. ChapmanF
    18,251
    I'm not prepared to say exactly what you're overthinking, but I'm pretty sure it's something. :)
  5. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    I don't doubt you've observed this behavior, and I now am prepared to say that these observations are not what should be happening, now that I have had a chance to test the scenario on two Prii.
    I have set the A/C fan on different speeds, and it has had no effect on the voltage displayed. So something is going on with your vehicle.
    My voltage was 13.1 V and remained at that voltage regardless of the fan setting.
  6. pasadena_commut
    2,670
    791
    Southern California
    On my car it is best thought of as "fan on vs. fan off". Note that only happens once the car has reached some warm up point that is marked by I have no idea what. It happens after driving the car for a while, but not right at start up. Until that point it stays at 14.1V no matter what.
    Oddly there are only those two voltages, highest fan speed or lowest fan speed it is still 14.1V, but fan off drops instantly to 13.6 V, and turning it back on jumps instantly to 14.1 V. I have never seen our 2007 running with the 12V as low as 13.1 V. Right at startup it kicks up to 14.5V for a nano second (gone in a blink) and then falls in a few seconds down to 14.1V. It sometimes takes a minute or two to get there if the battery was more substantially depleted at start, like at 12.3 V. Immediately after completing a full charge of the 12V battery with an external charger, so as close to 100% SOC as I can get it, it will still be at 14.1V (after a short time) at start up.
  7. dolj
    dolj Senior Member
    8,450
    4,291
    I meant to state my testing included OFF when I said I have set the A/C fan on different speeds.
    As I mentioned, I don't see these anomalies when the car is warmed up, so I am still leaning toward there being something not right in your car.
    Mind you, I don't often see the charging voltage at the high end as I regularly charge the battery externally, and more so if I observe charging voltages in the 13.9 V+ region.
  8. pasadena_commut
    2,670
    791
    Southern California
    This video
    shows (by accident) a similar behavior as described here:
    Oddity with 12V battery voltage measurements andtranmission | PriusChat
    but I think entirely in the "fan off" state. (At least I would not have the fan on when making a video to cut down on background noise.)
    He is showing how to use the MFD diagnostic mode and while driving around in that mode it switches between 14.3 and 13.7. That would most likely be the "warm up" point described in the thread above. Look around 2:00 minutes in the video. He also demonstrates that in P it gives the higher voltage and in D the lower at 2:20 in the video. He started with 12.6V with the inverter not on, which means the auxiliary was probably around 12.7 V or even 12.8 V open circuit, so at or very close to 100% SOC. 14.3V is "charging" for an AGM battery (up to 100F anyway, where it falls) but isn't "float" for an AGM until it is <50F. Since he is in short sleeves and outside the car is dry and sunny I'm gonna go out on a limb and guess ambient temperature was at least 70F.
    So again the mystery, why is the car putting a "charging" voltage on a 12V which is already at 100% SOC?
  9. dolj
    dolj Senior Member
    8,450
    4,291
    Your assumption that 12.7 V is "pretty close to" charged is erroneous. 12.7/12.8 V equates to about 70/75% charged. 13.2 V would be considered fully charged for a healthy AGM battery.
    12.6 V is ~63%.
    From my observations, the Prius will not go into float charge until the battery is charged to around 13.2 V.
    Furthermore, once the car moves from ACC to IG-ON, the voltage will drop further to the 11.x V range, so it is quite conceivable that the charge voltage will go to 14.3 V.
    The SoC charge I mentioned comes from the top line (Gel/AGM) on the graph below:
    Pb:A voltage band (SoC).jpg
    [EDIT] PS, In the video to which you linked, he mentioned that you can infer that the hybrid vehicle (HV) battery was good by looking at the charging voltage. I don't know where he got that idea, but you cannot make any such inferences just from looking at the 12 V reading. There is no link between the two.
    #9 dolj, Aug 15, 2025
  10. pasadena_commut
    2,670
    791
    Southern California
    Manual HV - P112 Hybrid Vehicle Control on page 29 describes this line which carries the "Two-stage selector signal":
    VLO (H16-31) - GND1 (H14-1)
    L - W-B Two-stage selector signal
    Converter switching to 14 V output
    13 to 14
    Converter switching to 13.5 V output
    Below 0.5
    However, I searched all the manuals I have and nowhere does it say anything about the logic that determines when VLO is hi or low. There is AFAIK no public access to the software that runs in the ECU, so figuring out why and when the ECU tells the converter to switch from one state to the other is likely to remain a mystery. That it does do so is I think established though.
    Also we already know that "13.5" and "14" are not etched in stone, the system adjusts both of these values based probably mostly on the state of the auxiliary battery. Since I have personally observed 14.1 V to 14.5 V for what is probably the "14 V output", but nothing above or below, that may well be the range. Maybe it can really go down to 14.0. For "13.5 V output" I have seen 13.6 V and the video shows 13.7 V.
    I do have a theory for why this switches states when loads are added, or in the case of the fan speed, potentially added. I suspect that the "13.5 V" output stage just has a much lower output current limit than the "14 V" output stage does. So if there is any chance that it is going to come up short, even hypothetically, it jumps to the higher range. I bet that turning on the headlights with the fan off will push it back up to the "14" state. Maybe the rear defroster or the windshield wipers will do the same thing.
  11. pasadena_commut
    2,670
    791
    Southern California
    It could well be that a healthy AGM battery at 100% SOC and no load at all can stay at 13.2 V for long enough to matter. The 4 year old battery in our car will reach 13.1 V when the charger says it is full, but by the next morning it is always down to to just below 12.7 V. Parasitic draw is still 20-25 mA (measured again recently) which is normal. From there it falls around .03 V to .05 V per day when not driven. (Not entirely inactive. Car is unlocked, windows are rolled down in the AM and back up in the PM, then relocked. It is much too hot to leave the windows up while it bakes in the sun.)
    I guess the main issue is that the AGMs in this car don't stay healthy long. We don't drive it enough for the car to keep it fully charged all the time and the environment here is very hot for half the year. Before we replace this 12V I will get a better battery tender so that from new the next one never gets very discharged. Perhaps that will help. Wouldn't be surprised though if the damage from the heat cannot be overcome that way.
    gdanner likes this.
  12. dolj
    dolj Senior Member
    8,450
    4,291
    I think you have your answer here. An AGM battery that can only be charged to 70% of full capacity is on its way out.
  13. pasadena_commut
    2,670
    791
    Southern California
    That's the problem. Auxiliary batteries on our car spend most of their lives at reduced capacity.
    We bought the car used. I tested the voltage on the battery in it on the lot to be <12V and asked them to test it. It failed their tester so they replaced it. I don't know that the one they put in was a new battery, but probably. It died in 2 years, stranded the wife after a short drive from home, and that was what alerted me to problems keeping these expensive AGM batteries alive, at least if the car isn't driven a lot.
    The 2nd battery was definitely put in new, I picked it up and installed it myself. Made a point of driving it more frequently, checked the voltage to make sure it never went very low. Yet at two years of age (also two years ago) while our little electronic battery tester rated it as 100% SOH at 100% SOC and showed 45Ah in its test it was still not charging to 13.x V and staying there, and the number of Ah needed to push it to 100% SOC from a starting voltage did not match up with the AGM tables, it was always much lower. So oddly, it tested as a good AGM battery but didn't function like a good AGM battery. Good enough to keep the car going for a while though. Now even the electronic battery tester says this battery has lost a step, with 85% SOH at 100% SOC and 43 Ah capacity. (I don't think it is even close to that capacity when used in the car.)
  14. ChapmanF
    18,251
    There aren't two distinct output stages, though, just a change in the output voltage target used in the PWM control feedback.
    Perhaps it is just trying to avoid too much voltage sag in parts of the distribution system subject to voltage drops. I'm just guessing too.
    gdanner likes this.
  15. pasadena_commut
    2,670
    791
    Southern California
    I ran Techstream on the car today and poked around looking for a live data variable corresponding to "current in/out of auxiliary battery" but didn't find it. Is there one?
    There is no current sensing clamp or power shunt for this measurement near the battery, is there maybe one in the converter section of the inverter?
    Failing a direct current measurement, maybe the converter uses the difference in voltage between what it is pushing out and what it measures on the thin sensing wire from the battery to estimate the current? Doesn't seem likely either since the voltage drop along that thick cable is going to be tiny, a car is an electrically noisy environment, and the sense line wire does not appear to be sheathed.
    There is also no temperature sensor near the 12V battery as far as I can tell. (The ones in the HV pack don't count.)
    All of which makes me wonder how the car knows when to shift from charging to float (14 -> 13.5) to keep from overcharging the 12V battery.
