Need some help tackling a rear ABS wheel speed wiring harness replacement.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Aug 4, 2025 at 8:33 PM.
  1. PriusCamper
    PriusCamper Senior Member
    12,152
    4,933
    Pacific Northwest, USA
    I've no intention of cutting anything... But Toyota's advice often tends to be bias towards corporate profits and they aren't in any way unbiased experts... I've done 5 minute repairs with battery packs thanks to PriusChat and if you took that same problem to Toyota they'd tell you the whole pack and other components need to be replaced for $5K because those lies are entirely embedded into their culture of making as much money off of repairs as possible and caring about saving the customer money isn't a priority for them.
  2. PriusTech
    PriusTech Member
    139
    71
    Reno
    I either read it somewhere or an instructor told me. And it's just common sense from a tech standpoint. It's hard to get to a factory quality level in the field when it comes to modifying wiring, and it's a mission critical system. There's few if any solder connections and crimps need to be absolutely water tight, especially exterior.
    I think it was a V6 Camry, there's a EFI ground wire on the back of the intake, doing an intake gasket or something like that the bolt for the wire on the manifold is very hard to access. Going back together I put it on a easier to access bolt about 6 inches away from the original. Same size bolt on the same aluminum part of the manifold. It was a comeback, it threw a ECU code and had to call Toyota Techline and they had seen it happen before.
    #22 PriusTech, Aug 5, 2025 at 9:47 PM
  3. PriusTech
    PriusTech Member
    139
    71
    Reno
    Yes, I'm in the middle of 2 DIY hybrid battery reconditions .
    Agree about the profit bias, although it's more so the dealers and the techs that are greedy. At one point corporate told the dealers, hey we can make vehicles with near zero maintenance, the dealers came back, please don't we make money from maintenance. Toyota cares about their reliability, quality, and will they be able to reliably warranty a repair. It's also a lawyer / insurance thing. Replace a harness with a factory harness, that's Toyota factory level. Splice a harness, now you are talking Chrysler.
    #23 PriusTech, Aug 5, 2025 at 9:57 PM
  4. ChapmanF
    17,533
    Toyota provides extensive instructions on how to splice their wiring harnesses. The online Electrical Wiring Diagram lets you pull up the Toyota part numbers of repair terminals and the correct parallel crimp sleeve to use with each one.
    The only admonitions I've seen against splicing in any Prius repair manual published by Toyota have been those for the bright yellow airbag-system wiring and for the orange high-voltage wiring.
    The technology of the wheel speed sensors changed between gen 2 and gen 3.
    Gen 2 sensors produce sine waves whose frequency and amplitude correspond to the wheel speed, so the signals get more faint at lower speeds.
    Gen 3 sensors produce square pulses whose frequency corresponds to the wheel speed but whose amplitude stays constant. The signals don't grow faint at low speeds.
    It's possible there could have been more potential issues with splice quality for the old type of sensor. (Though even the gen 2 manuals, IIRC, did not make any special notes about splicing them.)
    The signal-check mode was definitely provided for every technician to use after every job involving a bearing or speed sensor. Skipping that step can result in a comeback, even if nobody spliced anything.
    It seems like Toyota decided that having a performance standard for the circuit, and a built-in confirmation test to make sure your work meets it, would be a more practical way of preventing comebacks than just loading you with dos and don'ts.
    h1ph0panonymous likes this.
  5. rjparker
    9,681
    5,967
    It's aftermarket undercoating. The gen3s have nothing protecting the bottom panels or cables other than weatherproof connectors and rubber grommets where cables go inside the cabin. Once in the cabin the connectors are simpler.
    This part of the circuit is a simple 2 wire non-shielded cable. Since yours is aftermarket encapsulated, splicing to the remaining portion makes good sense. A decent splice will not impact the signal. You can prove it with the simplest crimp butt connectors (use the heat shrink type) or my choice, a soldered joint with heat shrink cover. Others routinely do a splice and it works fine.
    Brian1954 and h1ph0panonymous like this.
  6. h1ph0panonymous
    254
    34
    Maybe model 4’s and up get that undercoating? The previous owner before me, the original owner that is, had bad brake jobs got done, can’t imagine they requested undercoating in the wheel wells if they had shit brake jobs done (missing shims and rattle clips). I’m just going to cut through it from the inside of the trunk and find something to patch it up, maybe a grommet the size of the hole I cut.
  7. xliderider
    xliderider Senior Member
    8,086
    3,238
    Honolulu, HI
  8. PTS
    PTS Member
    Austin, Texas
    2013 Prius v wagon
    You will have to remove half of the hard plastic interior panels in the hatch to access the connector which was shown above. Similar to the prep needed to remove the hybrid battery.
    Trim 4 does not come with factory undercoating.
    Splicing using a piece of a $25 replacement wheel sensor harness is the smart move.
  9. PriusTech
    PriusTech Member
    139
    71
    Reno
    If you're going to splice on the exterior do it right, the wheel well gets blasted with road spray. Use a heat shrink (epoxy lined) butt connector. Use the correct crimper tool that does not cut through the heat shrink insulation. You want the connection to be water proof.
    Don't know about the 3rd gen. The CT200H connector was accessible with just the floor items removed, you can reach under the side panels.
    #29 PriusTech, Aug 6, 2025 at 12:58 PM
  10. PriusTech
    PriusTech Member
    139
    71
    Reno
    He's in Minnesota, if that splice isn't waterproof it's not going to last.
    With the advent of cars having more electronics Japanese metallurgy on their copper wires has made their wire considerable thinner (weight savings) while retaining capacity. There's almost no factory solder connections anymore, I think it's because the thin wires are adverse to heating. The last place they soldered was splices, now it's all crimp.
    #30 PriusTech, Aug 6, 2025 at 1:14 PM
  11. ChapmanF
    17,533
    Toyota's instructions for a good splice are in their Wire Harness Repair Manual.
    For whatever reason, Toyota prefers parallel splices instead of butt splices. It's a little inconvenient because, in most general auto parts stores, the only splices you find for sale are butt splices. The ones you buy at the Toyota dealer are parallel splices. You can also get them from TE using the part numbers in this post.
    The parallel splice has you insert the wires overlapping (just the way they look in the top of the photo above) into the crimp sleeve, so that you end up with a direct copper-to-copper connection inside the sleeve when you crimp it.
    The sealant-lined sleeves are nice, but a Toyota repair would still overwrap them with the self-fusing silicone tape.
    Toyota uses crimp connections and not solder on flexible stranded-wire connections because soldered ones aren't flexible anymore and so aren't suitable for a vibrating environment. Same reason the rest of auto, marine, and aerospace makes the same choice.
    They do use plenty of solder in appropriate places, like components on circuit boards inside ECUs and such, where everything is rigidly fixed in place.
    PriusTech and h1ph0panonymous like this.
