Question about underhood wiring
Discussion in 'Prius v Technical Discussion' started by Centerpunch, Oct 19, 2019.
  1. Centerpunch
    Centerpunch Active Member
    148
    138
    OH / NC
    2017 Prius v wagon
    I just recently bought my 2013 v 3. The car had the original 12v battery, so I replaced it today rather than waiting for it to fail at an inopportune time. While I was connecting a 12v power supply to the jumper connection in the fuse box (to maintain the voltage while I changed the battery), I noticed a broken or cut wire in the bundle next to the fuse box.
    I was surprised to see these tiny wires out in the open unprotected, and not covered by a plastic shroud on the end of the wire bundle. There's another area that's the same way.
    Is that normal, or does my car have parts missing?
    (The "power" mode on the car doesn't work- I'm thinking maybe it's the cut green wire. Fortunately the car has Certified warranty, so it will get fixed free regardless.)
    Juggernauutt likes this.
  2. Elektroingenieur
    2,515
    3,279
    Three Touring
    It’s normal for individual wires to be exposed, as long as the insulation on each wire is intact, and the wires are sufficiently bundled that they don’t chafe or get entangled in anything. Notice how each wire has a rubber seal to keep out dust and moisture where it enters the connector.
    For reference, the wire harnesses, clamps, and protectors are shown in parts catalog Figure 82-02, Wiring & Clamp; be sure to click through all twelve images.
    Correct. The Electrical Wiring Diagram (more info) shows that the green wire at connector A57, terminal 46 goes to the power mode switch.
  3. Centerpunch
    148
    138
    OH / NC
    2017 Prius v wagon
    Thanks!
    I just stepped back in from repairing the cut wire, and as you say, that fixed my non-working Power mode switch.
    Elektroingenieur likes this.
  4. bisco
    51,364
    parents watching over a teenage driver?:cool:
  5. Centerpunch
    148
    138
    OH / NC
    2017 Prius v wagon
    Maybe mice. If you look at the gray connector latch next to the cut wire, it looks a bit nibbled.
    #5 Centerpunch, Oct 20, 2019
  6. bisco
    51,364
    oh boy. hopefully no other damage
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,367
    2,357
    Taylors, SC
    The cover for these wires is included on Lexus hybrid models.
    It is Lexus Part #82821-76010. It can be ordered at any Lexus dealer.
    I installed on my 2012 Prius v nearly seven years, ago. I have uploaded photos. Prius Gen 3 ECU connector cover Lexus #82821-76010.jpg without cover large.jpg with cover large.jpg
    Air_Boss and Elektroingenieur like this.
  8. Centerpunch
    148
    138
    OH / NC
    2017 Prius v wagon
    Thanks, I will definitely order that! (I can't believe they didn't include that on these cars.)
    Is there also one for the other unprotected connector?
    #8 Centerpunch, Oct 20, 2019
  9. Georgina Rudkus
    3,367
    2,357
    Taylors, SC
    I covered all of those small wires by wrapping them with 3M fiberglass electrical tape.
  10. Centerpunch
    148
    138
    OH / NC
    2017 Prius v wagon
    Great, thanks.
  11. Juggernauutt
    Juggernauutt New Member
    Hey, did you ever get a response on the other connector? I would like to buy it as well.
  12. Juggernauutt
    Hey, Were you able to determine the second connector part number? The one for the exposed wires next to the air intake filter?
  13. PriusCamper
    PriusCamper Senior Member
    12,229
    4,962
    Pacific Northwest, USA
    It's so weird how much thought was put into making Gen2 Prius look beautiful when you pop the hood for people and by the time they were done with Gen3 design it's like they forgot that final step of making the engine compartment look pretty. Thank goodness for Lexus making compatible parts!
    When I finally get my plugin Gen3 I'm working to get I'm excited to add some photo contributions to discussions like these.
