2007 Prius. Hybrid battery (original) failing...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Danica, Aug 6, 2025.
  1. Danica
    Danica Junior Member
    31
    I was driving home from some errands this morning, almost home with perishable groceries in the car, hot day, AC blasting -- and the car starts going crazy on me. AC stops working, the car is beeping, brake light coming on, and the red triangle. Then the car literally would not go.
    Because of the heat and the groceries I just wanted to get home, which I somehow managed to do by turning the car off and on again a bunch of times. Each time the car would go maybe a couple of hundred feet before failing again. Once I got home, I had the car towed to a local mechanic, who just called me with the news.
    He said their diagnostic tool registered a large power drop-off, and since the regular battery is fine, it must be because the hybrid battery is going bad.
    I know this is a long shot, but I don't suppose there is any other possible explanation for the power drop-off?
    At any rate, I'm at a loss as to what I should do next. One mechanic told me that nobody in my area (Coachella Valley) has the ability to replace a hybrid battery. He said I would need to have the car towed to a neighboring county, and then the new battery would cost me at least 5K. I see cheaper prices on the internet, but have no idea if any of them are trustworthy.
    At that price, am I just better off getting a new (used) car? My Prius seems to be in good shape otherwise, in spite of being old.
    How do I even find somebody who can reliably replace the battery? Just call every mechanic in the area until I (hopefully) find somebody?
    Any suggestions or advice would be greatly appreciated. Thank you.
  2. Hayslayer
    Hayslayer Active Member
    390
    220
    It sounds like they didn't actually read the codes supplied by the car. They're guessing. You need to find someone who can actually read hybrid codes. THAT is your number one priority.
    Sounds to me like possible your inverter cooling water pump failed. This causes the inverter electronics to overheat and the car will protect itself by killing the AC and power to the transaxle. Pull over, turn it off, let it sit for a few minutes, it cools and allows you to drive again, for a short bit, then heats up again.
    Go pick up the car, but leave the AC off and stay under 35mph. This usually allows you to drive many miles before it gets hot. See if it works.
    I didn't see the part where you mentioned the brake light being on. Probably not the ICWP. BUT, you still need actual codes, not guesswork.
    Brian1954 and Danica like this.
  3. JC91006
    JC91006 Senior Member
    16,767
    8,564
    The 2nd generation prius is very reliable. But there are 2 failures that are pretty much guaranteed. The brake actuator/accumulator pump and the HV battery. Seems you hit one of the failures and the brake failure won't be too far behind. Both of these are high ticket items. So if you decide to fix the battery (let's say the current price is $2500 for a new one), prepare yourself for another $2500 for the brake actuator that will follow. If you're not willing to spend that type of money, best you just sell the car now.
    I use to help install these batteries and brake actuators, but I've since taught a nice apprentice to do this work. If you would like someone to go to you and install these items (you purchase them through the dealership), he can do it at a very low price, compared to a shop.
    gdanner and Danica like this.
  4. Danica
    31
    replying to Hayslayer...
    Hmmm, interesting. The mechanic did say something about the codes, but I didn't follow that part. Just the part where he said there was a big power drop-off that he couldn't explain through the regular battery.
    It WAS a very hot day today, and I was driving uphill. And the car was acting normal again when the tow truck driver drove it onto his truck.
    I'm just so nervous to drive it again on any kind of busy street, after what happened today.
    But thank you very much! I will definitely look into it.
  5. Danica
    31
    Thanks for the response. You've given me a lot to think about. I will consider this.
  6. Tombukt2
    12,924
    2,322
    My friends lil daughter could change the hybrid battery with a piece of plywood avail on side o road in lots places but yeah it's like 87 pounds. When you starting stopping going 50 feet . Did maybe try n turn power rubbing devices off possibly it's a long shot I know . But it's a thing . Yeah and o7 w original being tested on the heat will bring it down quickly . And make it time.
    So before 3K on a real battery . Is really time to think is this model really needed her or? 3K can put you in a nice Yaris that requires none these antics . Near similar mpg . Seriously.
    #6 Tombukt2, Aug 7, 2025
    Danica likes this.
  7. Danica
    31
    If I'm understanding your question correctly...
    Yes, I turned the car completely off each time. I counted to around 20 or so, then I would try to turn it back on again, got the red triangle, then I would turn it off and count to 20 again, etc. It usually took about three or four tries before the car would properly start again. Then I could drive maybe 200 feet before the car would start failing again.
    FWIW, i was driving up a steep hill, and it was 105 F outside.
    After I finally got home, the car started acting normal again after it had been off for awhile. It acted normal when the tow-truck driver started it up and drove it onto his truck.
    There is no way I could even begin to install a new battery myself. I'm in my 60s and disabled. The problem is, I'm completely at a loss as to what to do next. Hayslayer has given me a tiny ray of hope that MAYBE it's not the hybrid battery after all. Old as the battery is, I've been trying to take good care of it (driving the car frequently, trying my best to keep it cool) and the car was still getting good mileage before this happened.
    I've talked to two mechanics; the first one told me that NOBODY in my area can replace the battery, and the second mechanic had no suggestions for me. I have to make some big decisions quick, and this whole thing caught me completely off guard, and now I'm just feeling overwhelmed and out of my depth and I don't know what to do.
  8. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    Can you scan and post the actual error codes? How many miles on it.
    I bought the 2009 model year last year with 147k from a dealer 55 miles away from home. While driving back home, all the lights came on, A/C quit. I was almost half way. Just drove back. Other than the A/C, i didn't feel much difference. Came home, scanned it and it was the Inverter coolant pump. Once replaced (OEM), everything is fine. Then the actuator which was making noise every few seconds, i just replaced it proactively. $1300 later, that is also fixed.
    I think OEM battery is like $1.7K at dealership. There are lots of aftermarket options. Some of them come to your home and fix it.
    Regarding scanner, i used Autel MaxAP200. It also have special functions to bleed the brakes after actuator replacement. Something like this -> Autel AP200 OBD2 Scanner Bluetooth - Full System Diagnostic Tool, 19 Reset Functions, AutoVIN, Check Engine Code Reader for iPhone/Android - Walmart.com
  9. Carall
    Carall Active Member
    308
    104
    Harrisonburg, VA
    If the owner of the prius had scanned the codes in the first place and used the search on this site, I think he would not even have had to start a new thread... about guessing.
  10. Danica
    31
    Well I don't have the car with me anymore (it's sitting in the mechanic's parking lot) but as I recall it had about 130,000 miles on it. I don't drive a lot. Just mainly for errands and such, but living in California I do feel like I need to have a car.
    I'll have to call the mechanic to ask for the codes.
    Is the OEM battery reliable?
    Thanks!
    Correct, except that I am a she. I have very little in the way of auto-mechanical knowledge. which is why I'm posting here. I have some big decisions to make, and it seems like I'm going to be out thousands of dollars no matter what I do, so I am desperately looking for any advice I can get, to help me make the right decisions.
    I called the mechanic. The Code is T3011. After a quick search, I think I misheard and he actually said P3011.
    And he said there is a red light on the dash saying "check hybrid system."
    #10 Danica, Aug 7, 2025
    Carall likes this.
  11. bisco
    51,882
    look around for a used corolla. for the amount of driving you do, the prius is costing you money, and the corolla doesn't have the expensive hybrid systems, and can be easily repaired by any mechanic.
    all the best!
  12. Danica
    31
    Forgive me, but I don't understand. How is the Prius costing me money? I bought the car used in 2017, and aside from routine stuff like oil changes, I've hardly had to spend anything on car repairs up till now. If I can get an OEM battery for less than $3K, and then get another 5-10 years of reliable driving from it, that seems reasonable to me. The car only has about 130,000 miles on it, and the Prius is a very reliable car.
    I'm willing to consider all options, but a quick look at my local listings shows that used Corollas start at around $13K, with most of them going for considerably more.
  13. JC91006
    16,767
    8,564
    If your car has only 130,000 miles, I would suggest fixing the car and driving it. There's not much out there that you can buy for $5000-$6000 (the price you'll end up paying for 2 expensive parts). Hopefully nothing else major will fail (like engine and transaxle). Just keep up the regular maintenance and it should be reliable. Fixing it is probably the best route with a low mileage reliable car.
    xw20_driver and Danica like this.
  14. Hayslayer
    390
    220
    The P3011 code is for block 1 becoming weak in your hybrid battery.
    here's the basics. Your hybrid battery is built using 28 individual 7.2 volt battery modules in series. This gives you a 201 volt big battery. It's just like if you put (2) 1.5 volt D cell batteries into a flashlight, they act like (1) 3 volt battery.
    The car needs to monitor the condition of the battery, so they connected a sensor wire to every other module so the computer can get a voltage reading. Module 1 and 2 are considered block 1. Modules 3 and 4 are Block 2, and so on, until modules 27 and 28 are Block 14.
    The P3011 code is telling you that the computer is sensing Block 1 is getting weak. This means Module 1 or Module 2 is likely failing.
    I wish you lived near me, I would fix this for you for a few hundred dollars. Unfortunately, Toyota fixes this only by replacing the entire battery. BUT, it will last as long as the original. There are many HV battery repair companies that will swap your battery with one of their rebuilt batteries, even coming to your house and doing it. Reputable ones will even verify the codes when they get there.
    Danica likes this.
  15. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    130k is nothing on it. Mine is like 154k now. The key is to keep it rolling as much as you can. Don't let it sit for days. Check in Craigslist or online options first. Will be cheaper than OEM.
    Once the battery is replaced, keep driving it. Also there is a cooling fan for the battery. Make sure it works fine and clean and not clogged. You can see its vent on the rear passenger side at shoulder level. Also replace all the fluid that needs replacement or you don't know when it was replaced last time. Brake actuator, if it fails, part is is $1.2k at dealer.
    Battery at local dealer here in North Texas. $1.7K.
    Brake actuator.. Just FYI.
    Danica likes this.
  16. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
  17. Danica
    31
    If anybody is still reading this thread...
    I've been checking around, and my local Toyota dealer says he has a brand new Generation 2 hybrid battery available for $2,462. Installation would be just over $1K. I asked if there were any other charges and they said no, save for tax. I would have to get the car towed to the dealership, which would be another $150. With tax, I'm guessing maybe about $3,800 total? But I would have a brand-new Toyota OEM battey.
    I also called Greentec. They have a 48-month battery with all-new cells. With the mobile install and tax the grand total would be $2,700. Significantly cheaper, but I've heard mixed reviews about the reliability of the Greentec (and Green Bean) batteries.
    Any advice? I'm leaning toward the Toyota battery, for the extra peace of mind and because the price wasn't quite as bad as I feared. But I would be grateful to hear what any of you all think.
  18. Danica
    31
    I posted this before I read your response. I'm in the Coachella Valley, FWIW.
  19. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    OEM battery will be the best one. Try other dealers within say 100-200 mile radius. Each one charges different rates. Also make sure that they clean the battery fan / vent when replacing the battery. If they charge too much for this, get it done by your local mechanic. Not difficult to do.
    Toyota Dealer Locator | Find a Toyota Car Dealership Near You
    Danica likes this.
  20. pasadena_commut
    pasadena_commut Senior Member
    2,608
    771
    Southern California
    For those of you not familiar with Coachella, it can get ridiculously hot in the summer. National weather service forecast for today is 116F (47C), probably close to that yesterday. A marginal HV pack is not going to do well under those conditions, with the AC running full blast, or the pack running very hot if it isn't. It may run OK once the car cools off to something more reasonable, like 75F, although it might not get that low. Palm Springs is nearby, but Palm Springs is not where you would look for a good deal on, well, anything.
    So for the OP, here is the situation. If that code is correct you probably need a new HV pack. (Does the OP have a dog, does it ride in the car, has the pack fan ever been cleaned? The pack fans are notorious for jamming up with animal hair leading to batteries overheating. Look on youtube for videos.) The price of the pack varies by hundreds of dollars from dealer to dealer. To find the best price one must check the Toyota Dealers "nearby", and that means well into LA. Some of them have Web sites which will give the price, others you need to phone. Price can vary by hundreds of dollars, and supply varies, there are periods where they have so many they drop the prices low, and at other times it is hard to find one. Then you need to get somebody to install it. (Not something a person should try who does not already have tools and at least some experience working on cars. It isn't all that hard, just not a job for a complete newbie.) Note, the pack comes in a shipping case which resembles a coffin - it is very big and very bulky. It won't fit in a small car like a Corolla (unless it is a hatchback), but it will fit in the back of a Prius with the rear seat down. Dealers will not ship them, one must take delivery at the parts counter. There is a core charge as some parts of the old battery must be returned. The core charge is refunded when they get the core back - in the big shipping crate.
    The primary advantage of going to a Toyota dealer is that the warranty on the pack would be longer. However, I would suggest looking for independent shops in Riverside and San Bernadino, and if necessary working west from there. The installation cost should be lower, and if it is an OEM battery, it will be the same battery as from a dealer. Experienced mechanics can get one of these packs in and out in like an hour (maybe a little longer if it is 116F!), it isn't rocket science, and practice makes perfect. (It took me much longer as I had never done one before.) See if you can find somebody who can pick up an OEM battery at a dealer, bring it to you, and install it. Or you might have to have the car towed to them. Possibly you can drive there if the car still works late at night when the temperature is low. You do have to look at the pack first and see if it is the OEM battery because you need some of the parts from inside, the replacement battery does not have the electronics and some of the air control bits, those need to be moved over. If the pack is painted a bright color it is not an OEM pack, if it is a metallic gray it might be (but without a full history no way to tell for sure without opening it.)
    I don't know where GreenTec gets its "all new cells". In fact, I don't think I have ever seen a picture of the inside of one of those packs. It might not even be the same technology. Toyota NiMH batteries use Prismatic modules (rectangular) whereas Honda and some others used cylindrical sticks. The Toyota OEM modules were a better technology and their packs lasted much longer than the Honda packs of the same age. There have been people who sold packs for the Prius using those cylindrical cells, perhaps it turned out well for some people. There was a Lithium based pack available, now I think a Sodium one, I do not recommend those unless you are into experimenting on your car. Not a good choice if this is the only car you have. I don't recommend any of the options with used modules.
