Headlight Cover for both sides
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Sublina, Aug 7, 2025.
  1. Sublina
    Sublina Junior Member
    Tulsa
    My headlights are hazy and hard to see through at night. I am looking for new ones and the price range is very large. I would like to know if anyone has purchased new ones. I would like your information please.
    Burna J likes this.
  2. Tideland Prius
    16,621
    Are you able to clean/polish it off? You can buy a headlight restoration kit off the shelf. Make sure it has a UV protector wipe or similar to keep the headlight you just restored looking new.
    Burna J likes this.
  3. BiomedO1
    4,148
    2,173
    SacTown, Ca
    If your going to buy the entire assembly; you'll need to determine if it's a halogen or HID setup. The halogen is usually the cheaper option that can be replaced with LED lamps.
    Hope this helps...
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Gen3 USDM prii had halogen or LED headlights in the level 5 trim. The OEM LED headlights cost over $1000 each, that's probably why the OP noted the wide discrepancy in prices.
    AFAIK, only the JDM Prius G's had HIDs.
    +1 on getting the headlight covers cleaned/resurfaced and restored and using a UV protectant to keep the plastic from yellowing and getting hazy again.
    Burna J likes this.
  5. Mendel Leisk
    41,907
    I was speculating this morning, if there'd be a market for headlight covers, similar to windshield covers, say with magnets around the edge. For UV protection. Kinda nuts, to have a need something like this. Maybe they'd get swiped too often. :(
    Never happened when they were made out of glass.
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    If you cover up the headlights while driving, you’ll get a ticket. Only led bars are to be covered up while driving on roads.
  7. Mendel Leisk
    41,907
    I’m thinking for when parked.
    #7 Mendel Leisk, Aug 8, 2025
  8. CharcoalGrillMaster
    CharcoalGrillMaster New Member
    Anywhere my prius takes me
    I tried to restore my headlights after they got hazy. Did a lot of sanding and they ended up not looking much better. Also ended up spraying them with uv resistant polyurethane i got from advanced auto parts which I had to sand off because it made them worse (orange peel texture). If you're really good at sanding and polishing I'm sure you could do it but it's quite difficult as I learned. I even sanded it with up to 6000 grit i think. Just my two cents.
