Gen 3 Jacking Points
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zack Jones, Aug 6, 2025.
  1. Zack Jones
    Zack Jones New Member
    Good Evening! I’m working on a head gasket and need to Jack the front of the vehicle up. I have a floor jack, jacks stands (2) and wheel choks.
    I am wondering if anyone has had any success or suggestions with different jacking points? I know the pinch welds are what’s reccomended, but I can’t seem to figure out how to Jack up the car from the pinch welds and lower it on to a stand in the same location. I tried jacking it up a bit further back on the pinch weld and it started to bend over, so I didn’t continue. Should I just plan on trying to Jack it up from the subframe at that point?
    Thanks!
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    What kind of jack are you using on the pinch welds, scissor, hydraulic floor jack? Do you have a pinch weld adapter, if you are using a floor jack?
    Jack at the pinch weld on each side, then place the jackstands under the front of the side rails that run along each side of car. The frame rails are a little farther inboard from the pinch welds, they are mostly covered with plastic, but they are exposed in the front, they are about 2 inches wide and have a flat, beefy surface underneath, perfect for jackstands.
    I'm sure Mendel will be along shortly with the picture showing the front and rear locations for jackstand placement on the Gen3.
  3. xliderider
    8,140
    3,277
    Honolulu, HI
    NVM, I have indicated where to put the jackstands in this picture with the orange arrows. Screenshot_20250807_081251_Gallery.jpg
  4. Mendel Leisk
    41,907
    Borrowing the above pic, position the jack stand cradles as shown:
    I believe it was PriusChat member @hobbit that worked this out on a gen 2, and it's equally applicable on gen 3. The scissor jack points are totally inadequate for safety stands. If you place the scissor jack there and start running it up, you'll see it barely touches that crimped edge, just cups around it, and actually bears on the sheet metal behind. And dimples that...
    They'll ride over the plastic slightly, no matter. And there's a specific position tor the floor jack cradle, from page 423 of Owner's Manual*:
    It's about 15~16" back from the face of front bumper, slightly towards drivers side. There's a circular opening in the plastic engine bay underpanel. It's a black-painted bump on the underside of a sturdy cross-beam. You can't miss it...
    Good that you've got wheel chocks. When raising the front, you want to place chocks firmly on both sides of each rear wheel, then release parking brake. That way the rear axle is free to "hinge" as you raise the front.
    BTW: take a look at my signature, there's several relevant links, for EGR clean and head gasket replacement. Oil change link has more info on jacking and jack stand placement. Note: last link is the full engine section from the repair manual. (If you're on a phone, turn it landscape to see signatures)
    A few oil change pics attached:
    *I If you don't have the Owner's Manual, you can download a pdf from Toyota. One source is Toyota Tech Info (just google that), under the "Manuals" tab.
    #4 Mendel Leisk, Aug 7, 2025
    xliderider and NutzAboutBolts like this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,734
    1,771
    Bay Area
    This is where I jack up in the front
  6. Mendel Leisk
    41,907
    The state of that black plastic piece directly behind front bumper is telling, it’s so low-slung it invariably scrapes on concrete wheel stops, then snags when you back off.
    (the protruding, horseshoe-shaped end sections used to be bonded to the bottom panel, acting as stiffeners)
    #6 Mendel Leisk, Aug 8, 2025
    NutzAboutBolts likes this.
  7. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    Careful with the front middle one (which is the best way to jack up the front), mine collapsed a bit at some point over the years. It still works it's just a bit of a bummer. I think it was when I tried to use wood between the jack and the jack point to try to gain extra height.
  8. NutzAboutBolts
    1,734
    1,771
    Bay Area
    yep, that whole front plastic trims gone, the only thing that’s holding the other plastic piece up is because of the screw that goes through it, or else it’s gone. I should replace it but meh :ROFLMAO:
