How to wire Prius C battery fan to run during Battery reconditioning?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by 9Shenandoah, Dec 22, 2024.
  1. 9Shenandoah
    9Shenandoah New Member
    28
    Washington State
    2014 Prius c
    I'm trying to wire the Prius C battery fan to run during Battery reconditioning. Will applying 12 VDC from a DC power Source at the across B and L in the attached diagram accomplish this? pruis c fan.png
  2. PriusCamper
    PriusCamper Senior Member
    12,967
    5,275
    Pacific Northwest, USA
    The one time I charged and balanced a Prius C pack I couldn't figure out the 3 prong plug and just used a Gen2 fan that only has a 2-prong plug and blew the air in through the exhaust port. It worked well... However if you do a Google search on Gen3 maybe you can figure out how to spin this fan?
    Sure wish it was easier to wire up a Gen3 & Prius C fan. Maybe this is the thread that we finally figure that out?
    Maybe @ChapmanF can help?
  3. PriusII&C
    PriusII&C Active Member
    426
    145
    San Jose, California
    Have you figured it out? Is the Prius C fan pinout the same as Prius'?
