Cruise Control
Discussion in 'Gen 5 Prius Technical Discussion' started by maiki, Aug 9, 2025 at 3:20 PM.
  1. maiki
    maiki Member
    157
    22
    I just got a 2025 Prius Plug in XSE Premium (with advanced technology package, and every premium feature) about a week ago, and am trying to figure things out? So please forgive newbie questions.
    I tried to use Cruise Control last night while driving on an LA freeway. I pushed the Cruise Control button, and got an error message, and it did not work.. (I forget what it said, something about look in the manual.)
    Shouldn't it just work? Is there some kind of pre-condition for it?
  2. soft_r
    soft_r Active Member
    161
    119
    Beverly Hills
    2024 Prius
    Maybe you should look in the manual like it told you to.
    Maybe you should try it more than just the one time and then if the error message comes up you should try committing the message to memory for later to help you resolve the issue.
    Maybe you should also consider post subjects that clearly define your post.
    But then this is just standard Cali driver brain I guess.
    PrimeDan and LRO like this.
