AM2 fuse blown and bad smell 2005 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Meeker128, Aug 9, 2025.
  1. Meeker128
    Meeker128 Junior Member
    Tucson, AZ
    Tldr: How do I disconnect the inverter pump so I can get my car home and then what?
    I know there's a lot of information on this out there, and I apologize, but I'm having a really hard time mentally because this is the third problem in a few months.
    I had my car running and I ran inside a store and when I came back I had the red triangle of death. I don't remember how I touched it but as soon as I did it turned almost off. I assume that was the am2 fuse blowing.
    There was a horrible plastic smell, and when I would try to turn it on, the dash would flash squares around the transmission position indicators, and the power would flash amber. I tried unhooking the 12v for a while, nothing changed except my clock :{
    I have a code reader, but the only info I could get with the state it would turn on in was to tell me that the 12v battery was at 12.6-7v. That was with Hybrid Assistant.
    I remembered from other problems to check the am2 fuse and saw it was blown. I cannibalized one and put it in and turned on the car and it came on with the red triangle for barely 2 seconds and popped again. I then decided to go home.
    I read somewhere to unplug the inverter pump to see if that keeps the am2 from popping. If it does, I don't know if it's safe to limp home after that. I didn't look specifically for instructions to unplug the pump yet.
    I just replaced the hybrid battery a month ago (it's very poor. My old one was healthier except for one cell), and cleaned the battery fan. Then my car wouldn't start reliably, so I put a new 12v from Walmart in there.
    I was low on inverter coolant so I topped that off and saw turbulence inside when the car was on.
    I was checking everything with the hybrid assistant app, and everything seemed fine except the battery running a little hot. Like 125 f. But after reading that the fan doesn't come on full speed until 134°, I decided to stop worrying. My car ran for about 3 weeks before this happened.
    My car is about a mile and a half away. I can take back streets home. I only have to cross 2 major streets.
    I am comfortable replacing the inverter coolant pump and burping the system, but not the harness or anything else this could be. I used to replace parts on my 85 Toyota Celica and 88 suzuki samurai, but the troubles in past few months are the only things that I've done with this car. I didn't even change the oil myself. My dad just showed me 2 months ago. I thought there was some hybrid magic involved for some reason.
    I went to my dad because my dash panel was going black and the car wouldn't turn off. A friend of his added another capacitor to the circuit board, which seems to have solved that.
    I'm concerned about the bad plastic smell and could use some reassurance. I don't have much money on my own and am borrowing from my parents. I'm a Doordash driver and a bit neurodivergent. I've had the car 7 years and my dad had it for maybe 9 years before that.
    Assuming I can get it home, I'm considering ordering the pump (from Amazon?), and taking out the headlight to replace it myself. With everything that's happened though, I'm getting concerned. I don't want to spend money on towing(especially) or mechanics unless it will be very helpful. I don't have a backup car.
    Thank you...
  2. Brian1954
    Brian1954 Senior Member
    2,414
    969
    South Central PA, USA
    Picture posted in another thread on this forum.
    Do yourself a favor and do not buy a cheap aftermarket inverter water pump. They will only last about one year. Buy the Toyota OEM inverter water pump and do the job right the first time so that you do not have to do it again later.
    #2 Brian1954, Aug 10, 2025
  3. Tombukt2
    13,472
    2,421
    Undo that black plug at the very top of the fuse box there's nothing else there except that silly black plug in the picture in the blue . Unplug replace Am2 and drive .
  4. Meeker128
    Tucson, AZ
    How do I delete this? It took so long to get approved that it's not relevant anymore.
  5. PriusCamper
    PriusCamper Senior Member
    13,080
    5,306
    Pacific Northwest, USA
    Actually I've had those $25 dollar inverter pumps last many, many, many years... And even it they fail once the cost of two of them is still way less than 1/2 of what you'd pay if you wasted your money on an OEM one.
  6. Tombukt2
    13,472
    2,421
    I've had others fail in 30 days I just use piaggio scooter pump barbs are all correct on pump drop in connect to 12 v switched one in 5 yrs now .
    PriusCamper likes this.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,867
    860
    Southern California
    Can you post a link to one of these scooter pumps? Curious what they look like. Wouldn't expect one to mount the same way, do you just let it hang?
  8. pasadena_commut
    2,867
    860
    Southern California
    Wait until the temperature drops to 70F or so and then drive it below 40 or so and it should be fine. Don't try driving on the highway, that makes the inverter work much harder and it will overheat. Anyway, while driving keep an eye open for the red triangle, and if it pops up just pull over and let the car cool off for a while, maybe open the hood for better ventilation. It is common for people's pumps to go out and they don't find out until it either gets hot or they drive on the highway (or up a steep hill, or something like that.)
  9. PriusCamper
    13,080
    5,306
    Soon as I saw that mention I did a google image search on the term... Because it is designed to pump hot oil it should do pretty good over time with hot water.
  10. Tombukt2
    13,472
    2,421
    I'll try and round you up a link in a few it's microscopic compared I took can of foam made a lil blob on gold bracket in car set pump in foam 20 min you can't budge it . I put a plug in orog socket then to new pump so it can reverse to stock config .
  11. Tombukt2
    13,472
    2,421
    Hot oil as in engine oil absolutely not possible this plastic water coolant pump.only . It's used on all kinds of power sports equipment . Many companies make similar.
  12. Meeker128
    Tucson, AZ
    I ended up getting an Aisin pump. I removed the headlight and it was really easy to access. I hope that's the last of the problems for a while. I'm starting to lose confidence in my car.
  13. bisco
    52,404
    at 20 years old, that's easy to understand
