max tire size
Discussion in 'Gen 3 Prius Main Forum' started by JeanLuke, Aug 10, 2025.
  1. JeanLuke
    JeanLuke Junior Member
    Austin TX
    I'm checking to see if anyone knows max tire size for Gen 3 Prius
  2. Tombukt2
    12,957
    2,325
    You mean like before they start rubbing? Well 195 65 15 can rub going over train tracks . W a 40 mm lift 215 65 15 won't rub over same tracks gas mileage like 39 best . So it depends what you're looking to do
  3. PriusCamper
    PriusCamper Senior Member
    12,751
    5,160
    Pacific Northwest, USA
    People create more problems than they solve when they use the wrong tire size... But if you can let us know more details about the reason you want bigger tires we could probably help you satisfy that need in a way that doesn't create new problems.
