RTOD – how bad can it be?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jim x 3, Jul 12, 2025.
Tags:
  1. T1 Terry
    T1 Terry Active Member
    852
    434
    Next chance you get, go over all the module nuts and check they are tightened to 49in/lb by using a 1/4' drive in/lb tension wrench and 8mm socket ..... every chance the problems were caused by poor compression on the contact surfaces .....
    T1 Terry
