P1121 Fail fix
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PrestonH2O, Aug 10, 2025.
  1. PrestonH2O
    PrestonH2O New Member
    Philadelphia
    I tried to fix my p1121 error code by replacing the 3-way coolant control valve. I even got OEM.
    I ended up spilling all the coolant on the ground. I also had to take one of the hoses off the coolant pump which I then forgot to put back on when I started the car. I then put it back on once I realized my mistake. I have refilled, and possibly overfilled the coolant system but the coolant doesn't seem to be circulating. The coolant system also seems to be making a weird noise like it is trying to pump and getting nothing? Could there be air in the system?
    I am having the following error codes now:
    P0117
    P1121 - still, even after clearing code
    P0A0D - I triple checked the service plug and I am pretty sure its all the way in and pushed down! The red triangle goes on and off.
    Any idea what the problem could be? Did I break the pump or put air in the system?
  2. PrestonH2O
    Philadelphia
    Update: I am now ONLY getting P0A93. Also at one point all the lights on the dash went on including the E-break light and it started beeping really loud but that stopped and hasn't happened again.
  3. Tombukt2
    12,554
    2,228
    Take rad cap off . If coolant is not sitting at top of neck you is not full now pour a stream of red in neck . Sloooowly. When you finally get it to stand at the top of the neck for 5 minutes you're full that's going to take you 40 minutes and a quart or better of coolant let me know you gonna be pouring 20 35 min . It goes slow . Obviously make sure all hoses are on and clamped not hanging
  4. dolj
    dolj Senior Member
    8,291
    4,232
    Wellington, New Zealand
    By chance, did you unplug the inverter coolant pump and overlook reconnecting it?
    saneesh8 likes this.
